Dynamic Green Products Inc.
Author Topic: WM will make it right whatever it takes!  (Read 1447 times)
Offline stavebuyer
« on: August 12, 2013, 08:03:09 AM »
I recently ordered the 12' log deck package for my LT70. It arrived Thursday before last. We tore out the makeshift deck we had been using on Friday and poured a concrete pad for the new deck. We let the concrete set up over the weekend and starting bolting the shiny new orange deck in place on Monday. We also had a new stationary leg kit to install as well as replaced the blade guides, all the drive motor brushes, mill alignment and few other tasks. It was Tue am when we got around to the final step of installing the separate loader arm stop for the stop-n-loader; it was 8" to tall to work with the mill. A call to Wood-Mizer. The deck we got was built for the working height of the 3500/4000 industrial series mills and not the LT70. They apologized and said they would build us another. We pulled out the new deck and put the old deck we had been using back in place. I get a call from WM on Wed..they have the right height log deck package available in their industrial green paint and could deliver it the next morning if I would settle for green instead of the orange paint I ordered? I told them to bring it! So we are back to deck swapping: we are becoming experts at this task by now! On Thursday the 2nd new deck arrives. Its pouring rain and we wait until Fri morning to do the deck swap. The deck height is correct but the stop height is still 8" too high. Somehow the original dimension specifications for the LT series log deck loader stop had been altered to show the same loader stop heights for both versions of the lock deck package. We rig up a makeshift loader stop out of tie blocks and make another call to Indy. This is Fri morning at about 8:15. A little after lunch I get a call from Chris with Wood-Mizer. He is on the way to KY from Indy for the 2nd time in as many days with the newly manufactured log loader stop in hand and would get to the mill around 5 Friday evening. That's over 300 miles one way from Indy.
Yes, they got it wrong twice but went to extreme lengths to make it right. The 2nd deck would have worked fine for a few days using the tie blocks for a temporary loader stop and I told them as much. Job well done Wood-Mizer.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: WM will make it right whatever it takes!
« Reply #1 on: August 12, 2013, 09:28:54 AM »
Offline grweldon
    • Just Stuff! (my personal blog)
« Reply #2 on: August 12, 2013, 11:20:46 AM »
Hmmmm.....
That wasn't my initial thought.  After clicking on the "reply" button and composing a message, when I re-read it and recomposed it several times, I just deleted it knowing that however I expressed my opinion on the situation I would most definitely offend multiple people...
Keep in mind that I work in manufacturing.  We have a program to determine the cause of things like that and the extreme majority of the time it comes down to just one thing.  I'll let y'all assume you know what it is...
"GO ORANGE"!
Timberking 1400, Ford 3910 Tractor, John Deere 350B Crawler/Loader
Offline Bibbyman
    • Warden Sawmill
« Reply #3 on: August 12, 2013, 12:23:18 PM »
I'd probably just put 8x8s under the mill to match the deck height.   That way you can let the crud build up more between cleaning.
Another thought,  maybe Wood-Mizer could have sent you the taller legs for the mill?
Sawing since '94
Offline drobertson
« Reply #4 on: August 12, 2013, 12:31:41 PM »
Glad you are happy, this is what is important, satisfaction. Still hard to get a grip on these kind of mis- CA bobbles.  I reckon this explains the effort made to rectify.   david
Offline stavebuyer
« Reply #5 on: August 12, 2013, 02:12:22 PM »
Lack of clearance with the ceiling prevented raising the mill.
We could of cut down the legs on the 1st log deck and stop, but that would have involved more lost time than the swap outs.
Offline Bibbyman
    • Warden Sawmill
« Reply #6 on: August 12, 2013, 02:43:38 PM »
As they say,  it's the thought that counts.   Probably not much considering the thought was too late and wouldn't work anyway.  ::)
Sawing since '94
Offline Finn1903
    • Sunrise Oak Farm
« Reply #7 on: August 12, 2013, 03:47:25 PM »
Could also be a Clemson Tigars fan!
From my time in manufacturing, at times orders and parts get mixed up, we typically would investigate or discuss what went wrong.  But, what counts for us out here running our mills is the level of customer service and jumping through hoops to make a mix up right.   Yes, would be better if it was right the first time, but they also could have just put the part on a UPS truck and they mill owner would have waited twice as long to get the parts. Been there too.
WM LT40HDD47, bunch of saws, tractor, backhoe, and a loving wife.
Offline grweldon
« Reply #8 on: August 12, 2013, 04:03:21 PM »
Roll Tide!
Offline Kansas
  • In the mountains of Kansas
« Reply #9 on: August 12, 2013, 04:14:52 PM »
We all make mistakes. Rumor has it I make one once or even twice a year. Its fixing the problem that makes good service. Woodmizer is a class act. It is in their best interests to eliminate problems. It costs a lot more to fix a problem than doing it right in the first place. Still, sometimes things happen. I don't have a clue how much equipment or parts they send out in a day. Somebody, somewhere is going to make a mistake once in awhile.
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #10 on: August 12, 2013, 05:39:47 PM »
Offline barbender
« Reply #11 on: August 12, 2013, 11:37:52 PM »
I have seen plenty of outfits that make mistakes, but only a few that will jump through hoops to make it right. I have to agree, WM is a class act.
Offline fishpimp
  • SawDawg
    • www.photobucket.com
« Reply #12 on: August 13, 2013, 09:26:15 AM »
I like that!
My mills hydraulics giving me fits yesterday at end of the day. Fix to call the ORANGE posse and see what's up!
Lost all controls . Log turner. Side supports. Everything. I hear a clicking like noise. Wish me luck !
Offline LeeB
« Reply #13 on: August 13, 2013, 09:29:39 AM »
Sounds like no power to the hydraulics. try moving your cutting head forward or back a little. You may have a dead spot on the contact strip. Another culprit could be the micro switch at the ffront of the hydraulics selector bar.
NY DEC takes a beating
Started by Shagy on Firewood and Wood Heating
Last post August 13, 2010, 08:23:39 PM
by petefrom bearswamp
If 3/8 takes more power
Started by kellysguy on Chainsaws
Last post May 31, 2015, 09:40:12 PM
by HolmenTree
and the saw takes a bite
Started by LeeB on Health and Safety
Last post October 14, 2010, 01:20:51 AM
by Raphael
Head cold. Make it stop...make it go away!! Man, I turn into a baby...
Started by maestro on Health and Safety
Last post September 16, 2008, 03:56:29 PM
by Riles
