Author Topic: water additive  (Read 1057 times)
Offline Qweaver
  • The cabin is done and we love it
water additive
« on: August 16, 2013, 03:36:02 PM »
I think I've been using Pinesol but can't find the bottle.  Will just any soap (laundry or dish) work just as well...or is there an even better one.  I've got a lot of pine to saw and no soap on hand.  If I'm going to run to the store I might as well get the best for the job.
Offline grweldon
    • Just Stuff! (my personal blog)
Re: water additive
« Reply #1 on: August 16, 2013, 03:44:26 PM »
Magicman uses Cascade dishwasher liquid.  I'm trying it right now and it works well.  I've also used Ajax dishwashing soap for washing dishes by hand.  It worked well also.  I would imagine most any liquid hand dishwashing soap would work.
Timberking 1400, Ford 3910 Tractor, John Deere 350B Crawler/Loader
Offline Qweaver
Re: water additive
« Reply #2 on: August 16, 2013, 03:47:15 PM »
I just happen to have some Cascade...now if I can just get it out of the house without Sarah catching me.  8)
Offline hackberry jake
Re: water additive
« Reply #3 on: August 16, 2013, 04:17:54 PM »
I believe the reason people like magic use cascade over other soap is because it doesnt foam up as bad.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: water additive
« Reply #4 on: August 16, 2013, 04:55:32 PM »
You're right Hack.....in fact, it doesn't foam at all. Walmart carries a knock off brand of Cascade that I use and it is a lot cheaper.
Offline drobertson
Re: water additive
« Reply #5 on: August 16, 2013, 05:34:12 PM »
I broke down a while back and tried Magic's recipe, and have to say it works really good, and very inexpensive, the results are excellent.   david
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: water additive
« Reply #6 on: August 16, 2013, 06:02:06 PM »
Stuff like Dawn should work well but you would need to add it after the water to prevent a bubble bath.  Cascade and other automatic dishwasher soaps are formulated to cut grease, etc. without foaming.  I add the 2 oz. per gallon to the jug before the water hose.  Filling stirs and mixes it very well.  The cost is about 60 cents per 5 gallon jug.
Offline Jemclimber
Re: water additive
« Reply #7 on: August 16, 2013, 08:15:24 PM »
I thought it was a glug per gallon??  :)
lt15
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: water additive
« Reply #8 on: August 16, 2013, 08:33:06 PM »
 :-[  Guilty as charged.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: water additive
« Reply #9 on: August 17, 2013, 04:20:19 AM »
After the fashion of Magicman, I also use Cascade, 120 oz from Walmart for $6.  Add about 5 squeezes for 5 gallons, and more if needed for pine, hickory, ash etc.  The value is in its formulation which dissolves readily in water, in addition to not foaming.  Only issue is that when it gets cold and one starts adding washer fluid, it will knock some soap out of solution which can clog the screen filter or keep check valves open on my mill.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline GeneWengert-WoodDoc
Re: water additive
« Reply #10 on: August 17, 2013, 09:50:30 PM »
These detergents also have a surfactant that is a wetting agent and helps break the normal water surface tension so that the solution wets better.
question
Water additive while sharpening
Started by chet on Sawmills and Milling
Last post September 13, 2005, 04:07:08 PM
by woodmills1
On demand domestic hot water using water to water heat exchanger?
Started by Fether Hardwoods on Firewood and Wood Heating
Last post July 26, 2015, 09:50:11 PM
by r.man
bar oil additive
Started by tstex on Chainsaws
Last post March 14, 2017, 05:31:58 AM
by Al_Smith
bar oil additive
Started by Pullinchips on Chainsaws
Last post May 23, 2005, 05:10:18 PM
by JD_Kid
