Author Topic: 100 year old white pine  (Read 1177 times)
Offline Dana
    • Green Leaf Farms
« on: August 23, 2013, 11:24:09 AM »
I'm on my way to the up to pick up some white pine timbers today. Can someone give me the dry weight of 7"x12" x24' white pine timbers?
If my calculations are right the tool box tells me that there is 168 bd ft in one timber and that it should weigh 504 lbs green. But I'm sure they lost a bit of weight in the last 100 years.
I need the number to know how many I can carry for dot loading.
Thanks dana
Grass-fed beef farmer, part time sawyer
Offline Texas Ranger
  • Forester
  • Texan, by God and by choice.
Re: 100 year old white pine
« Reply #1 on: August 23, 2013, 12:09:55 PM »
2250 per 1000 bd feet.
Offline Dana
    • Green Leaf Farms
« Reply #2 on: August 23, 2013, 02:36:06 PM »
Thanks.
Offline red oaks lumber
« Reply #3 on: August 23, 2013, 07:03:46 PM »
dry w.pine is closer to 1850 lbs./ thousand
Offline GeneWengert-WoodDoc
« Reply #4 on: August 24, 2013, 12:30:46 AM »
The reason that there are two different answers given is because the 2250 pounds is for 1000 BF that is exactly 1.0" thick.  But one BF of softwoods is not exactly that 1.0" thickness or are not full width either.  So, the 1850 number represents actual weight of 1000 BF that is 1.5" thick ( and not 2" ) and 5.5" wide (and not 6").  Note that BF uses the nominal size and not the actual size for softwoods.
It would seem that you could use the weight per cubic foot for dry pine.  When lumber is exactly 1.00" thick, then 12 BF per cubic feet.  so, Take 2250 pounds and divide by 1000 to get 2.25 pounds per bf.  then, as there are 12 BF per cubic foot, then multiply by 12 to get pounds per cubic foot, or 27 pounds per cubic foot.
Now, if the timber is exactly 7.0" x 12.0" x 24', then each timber is 7 x 12 x 24 / 144 = 14 cubic feet and will weigh 14 x 27 = 378 pounds assuming the wood is at 12% MC.  If 40% MC, 472 pounds roughly.  When green, close to 680 pounds.
Offline Dana
    • Green Leaf Farms
« Reply #5 on: August 25, 2013, 06:44:54 AM »
We got back late last night with the load of logs. Thanks to everyone who helped make sure we weren't overloaded.
Drought and heat tolerance of white spruce and white pine
Started by saskatchewanman on Ask The Forester
Last post July 04, 2019, 04:13:12 AM
by BaldBob
Free Logs; White Pine & White Oak Sebago Maine
Started by JJ on Sawmills and Milling
Last post November 09, 2016, 10:53:53 AM
by JJ
Green and white mold on Eastern White Pine
Started by AnthonyW on Drying and Processing
Last post September 14, 2015, 09:15:28 PM
by AnthonyW
Using dead standing hemlock, red pine and white pine & best transport in forest
Started by LoggingOn on Ask The Forester
Last post July 28, 2011, 03:19:12 PM
by LoggingOn
