Dynamic Green Products Inc.
Author Topic: What size breaker for possible future lathe?  (Read 1181 times)
Offline OneWithWood
  • I am happy!
« on: October 03, 2013, 12:12:08 PM »
I am wiring my new shop addition.  I want to incorporate an outlet for a lathe I hope to own in the near future.  Problem is I don't know which lathe it might be.  If I put in a 240v-20a breaker will I have it covered?
One With Wood
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
Re: What size breaker for possible future lathe?
« Reply #1 on: October 03, 2013, 12:19:57 PM »
Be sure the wire to the plug is heavy enough and you can size the breaker later  :)
Offline warren46
  • Been involved in sawing most of my life.
« Reply #2 on: October 03, 2013, 12:52:14 PM »
Since this is woodworking forum it is safe to believe that this will be a lathe for wood.  It is very unlikely that you will need more than 20 amp at 220 V to run such a lathe.
Warren
Warren E. Johnson
Timber Harvester 36HTE25, John Deere 300b backhoe/loader.
Offline Ianab
« Reply #3 on: October 03, 2013, 01:47:36 PM »
Yeah, 2hp is a BIG wood lathe & 240 @ 20a would easily cover that. That circuit would supply almost 5,000w. Plenty of power for any small ww machine.
Offline SPIKER
« Reply #4 on: October 03, 2013, 10:02:56 PM »
One possibility is to wire a 50amp outlet and put in plug so you can plug in welder etc, on the machine you plug into it can have it's own fuse then.   Basically a universal plug and on each machine you add to the shop the units are wired for self contained fuses..
Offline scsmith42
    • Whispering Pines Farm
« Reply #5 on: October 03, 2013, 10:41:18 PM »
A 20A 240VAC breaker on 12/2 with ground wire will be sufficient for up to a 3 hp lathe.
A 5 HP lathe will require a 30A 240VAC breaker on a 10/2 with ground (or 10/3 with ground) wire.
Tom's 3638D Baker band mill
Offline OneWithWood
  • I am happy!
« Reply #6 on: October 04, 2013, 07:15:48 AM »
My initial thought was to wire it with 10/3 with ground and a 240v 20a breaker thinking I could always swap out the breaker and plug if I needed more.
I already have a 50a circuit wired with 6/3 with ground (if I remember correctly - I do remember it is very heavy and was very expensive) so I won't need to replicate that.
Thanks for all your input.  I knew I would get good advice quickly here.  :)
One With Wood
Offline Burlkraft
  • Professional survivor......Still a wooodturner
« Reply #7 on: October 04, 2013, 09:50:56 AM »
My OneWay is 3hp. and I have a 240  20a breaker in there.
I've never kicked it as the lathe has an overload protection breaker too.
Why not just 1 pain free day?
Milling For Future. Not Sure of Needed Size
Started by catvet on Sawmills and Milling
Last post June 20, 2008, 10:09:44 PM
by WDH
Need Info on LM 2000 > Clutch Shaft Size, Pulley Size, V-Belt Size for 23 HP BS
Started by H60 Hawk Pilot on Sawmills and Milling
Last post October 17, 2009, 07:57:09 PM
by Ironwood
Circuit breaker
Started by revid on General Board
Last post February 16, 2019, 08:07:09 PM
by revid
back hoe breaker
Started by SawInIt CA on Sawmills and Milling
Last post November 13, 2003, 06:27:04 PM
by SawInIt CA
