Dynamic Green Products Inc.
Author Topic: What size breaker for possible future lathe?  (Read 1149 times)
Offline OneWithWood
  • I am happy!
« on: October 03, 2013, 12:12:08 PM »
I am wiring my new shop addition.  I want to incorporate an outlet for a lathe I hope to own in the near future.  Problem is I don't know which lathe it might be.  If I put in a 240v-20a breaker will I have it covered?
One With Wood
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
Re: What size breaker for possible future lathe?
« Reply #1 on: October 03, 2013, 12:19:57 PM »
Be sure the wire to the plug is heavy enough and you can size the breaker later  :)
Offline warren46
  • Been involved in sawing most of my life.
« Reply #2 on: October 03, 2013, 12:52:14 PM »
Since this is woodworking forum it is safe to believe that this will be a lathe for wood.  It is very unlikely that you will need more than 20 amp at 220 V to run such a lathe.
Warren
Warren E. Johnson
Timber Harvester 36HTE25, John Deere 300b backhoe/loader.
Online Ianab
« Reply #3 on: October 03, 2013, 01:47:36 PM »
Yeah, 2hp is a BIG wood lathe & 240 @ 20a would easily cover that. That circuit would supply almost 5,000w. Plenty of power for any small ww machine.
Offline SPIKER
« Reply #4 on: October 03, 2013, 10:02:56 PM »
One possibility is to wire a 50amp outlet and put in plug so you can plug in welder etc, on the machine you plug into it can have it's own fuse then.   Basically a universal plug and on each machine you add to the shop the units are wired for self contained fuses..
I'm looking for help all the shrinks have given up on me :o
Offline scsmith42
    • Whispering Pines Farm
« Reply #5 on: October 03, 2013, 10:41:18 PM »
A 20A 240VAC breaker on 12/2 with ground wire will be sufficient for up to a 3 hp lathe.
A 5 HP lathe will require a 30A 240VAC breaker on a 10/2 with ground (or 10/3 with ground) wire.
Tom's 3638D Baker band mill
Offline OneWithWood
  • I am happy!
« Reply #6 on: October 04, 2013, 07:15:48 AM »
My initial thought was to wire it with 10/3 with ground and a 240v 20a breaker thinking I could always swap out the breaker and plug if I needed more.
I already have a 50a circuit wired with 6/3 with ground (if I remember correctly - I do remember it is very heavy and was very expensive) so I won't need to replicate that.
Thanks for all your input.  I knew I would get good advice quickly here.  :)
One With Wood
Offline Burlkraft
  • Professional survivor......Still a wooodturner
« Reply #7 on: October 04, 2013, 09:50:56 AM »
My OneWay is 3hp. and I have a 240  20a breaker in there.
I've never kicked it as the lathe has an overload protection breaker too.
Why not just 1 pain free day?
Milling For Future. Not Sure of Needed Size
Started by catvet on Sawmills and Milling
Last post June 20, 2008, 10:09:44 PM
by WDH
Need Info on LM 2000 > Clutch Shaft Size, Pulley Size, V-Belt Size for 23 HP BS
Started by H60 Hawk Pilot on Sawmills and Milling
Last post October 17, 2009, 07:57:09 PM
by Ironwood
back hoe breaker
Started by SawInIt CA on Sawmills and Milling
Last post November 13, 2003, 06:27:04 PM
by SawInIt CA
Circuit breaker
Started by revid on General Board
Last post February 16, 2019, 08:07:09 PM
by revid
