Auto Clutch
Started by Magicman, October 23, 2013, 02:48:39 PM
I guess that it is "bout time for the ole man to start reaching for the sky and waving at no one.   ;D  That is what I have been told that I will do and with 12 years of manual clutching, they are probably right.
I read through the instruction manual twice before I began so everything was at least familiar when I began.  All of the wiring was pre-installed and stored just as WM said it was.
The clutch handle is 'bout to go.   :o
The old turnbuckles are gone and now it is time to add the new addition.
All of the wiring is completed and the new turnbuckles are adjusted.
A new switch occupies the lower left corner of the control panel.
That funny looking new box makes my old paint look.........well salmon.   :-\
I am now anxious to start waving with my right arm.   ;D
wwsjr
Having run both "pull the lever" and "flip the switch" I predict you are going to like the switch. Maybe either the Autoclutch or the mill needs touch up paint.
Willie
Retired US Army, Full Time Sawyer since 2001. 2013 LT40HD Super with 25HP 3 Phase, Command Control with Accuset2. ED26 WM Edger, Ford 3930 w/FEL, Prentice Log Loader. Stihl 311, 170 & Logrite Canthooks. WM Million BF Club Member.
POSTON WIDEHEAD
WoodenHead
Congrats!  Your arm/shoulder will thank you for it.   :)
It's a great feature.  I don't regret adding auto clutch.
Now, how many times will you reach for that lever and find it "ain't" there anymore.  ;D
Awe man, I'll get left thumb cramps.   :D
Bill Gaiche
Now you will feel more like arm wrestling Pat in the evening. bg
sealark37
And you thought that you weren't a real mechanic!
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
fishpimp
Majic man will b texting next hahaha !
I'm sure u will love that switch!
Hav u always had accuset?
woodmills1
congrats and good job
I have done so much right hand work I now need a left hand pull clutch to put that side of me back in shape :D
Quote from: fishpimp on October 23, 2013, 08:00:47 PM
Oh no I will not.  I am "text free".   :)
That is a SetWorks.  I guess that it is the first computer unit that WM used.  I understand that there are no replacement parts, but I replaced everything when parts were available and mine started doing bad things.  Hopefully it will never croak.
Brucer
Quote from: Magicman on October 23, 2013, 02:48:39 PM
I guess that it is "bout time for the ole man to start reaching for the sky and waving at no one.   ;D  That is what I have been told that I will do and with 12 years of manual clutching, they are probably right. ...
Let's see -- 3 months running someone else's mill, then 18 months running my two before I put the autoclutch on. After that it took about 6 weeks before I stopped waving :D.
I just had to replace the switch on my A/C, after 2000 hours. Other than that it's been problem-free.
Bruce    LT40HDG28 bandsaw
I was mentally going through the procedure last night.  After 12 years and over 7K hours, my hands and fingers were (are) almost robotic.  This ole dog will have to learn a new trick.   smiley_headscratch smiley_dizzy
moosehunter
MM, what is the switch in the upper right "Fast Forward" for? My super does not have that switch. Does it fast forward to the end of the day? Or move the mill head forward fast?
Higher than my expectations
Ga Mtn Man
Congrats on the upgrade MM.  Perhaps WM should sell an Ole Dog Auto Clutch Retrofit Kit...a dummy clutch lever with a switch at the end. :laugh:
Now that would work Paul.  You win the prize.   smiley_thumbsup
Quote from: moosehunter on October 24, 2013, 03:29:58 PM
MM, what is the switch in the upper right "Fast Forward" for? My super does not have that switch...... Or move the mill head forward fast?
Your second guess was correct.  It takes me to the back of the sawmill without touching the potentiometer.  LINK
You do have to read on to Reply #22 because the center potentiometer does have to be cut and wired directly to the fast forward switch.
All that I have to do is move the power feed lever forward and press the FF switch to zip me to the back of the sawmill.  I use it many many times during a day's sawing.  I also never forget to "unwind" the potentiometer and crash into the log end.   :-\    :D
