BLUECREEPER Poster Award #4!
You slide the blade across the stone manually, with your arms and hands. A smooth even stroke.
What he said above. I have that same Makita sharpener with three stones, nice rig but you gotta wear an apron, can get a bit messy. On the blade holder that slides back and forth there are adjustable stops to keep the blade parallel to the stone. If you build one you may want to incorporate this feature for repeatability.I have switched to carbide on the machines and just use the Makita for chisels and planes now.The other Larry
Started by Kasba on General Woodworking
Started by DanG on Drying and Processing
Started by Kevin_H. on Sawmills and Milling
Started by cloair on Sawmills and Milling
