Author Topic: lucas oil additive  (Read 1132 times)
Offline cutter88
  • any day you come home safe is a good day!
lucas oil additive
« on: November 03, 2013, 04:40:52 PM »
ive always been a firm believer in lucas engine oil additive from my equipment right down to even in my wifes car... my question is? is there a lucas that I can run in the tranny of my 640d john deere... the tranny feeds the winch and both diffs so I was just wondering if theres a lucas tranny additive or can I use the same stuff I run in the engine...
Romans 10 vs 9
650G lgp Deere , 640D deere, 644B deere loader, 247B cat, 4290 spit fire , home made fire wood processor, 2008 dodge diesel  and a bunch of huskys and jonsereds (IN MEMORY OF BARRY ROGERSON)
Offline Brleclaire
Re: lucas oil additive
« Reply #1 on: November 03, 2013, 07:15:56 PM »
Lucas transmission additive is the one I used on our older tj 360's. It made them smoother shifting and plugged up a few of the minor seal leaks. Look on Lucas' web site under products.
Offline timberjackrob
« Reply #2 on: November 03, 2013, 10:04:52 PM »
I use lucas hydraulic booster in all my hydraulic systems.
208 timberjack woodmizer lt28 case 455 trackloader massey 4610 ford f250s ford f700
Offline Ken
« Reply #3 on: November 05, 2013, 06:11:20 PM »
Do others use this in their hydraulic systems?  I had a local mechanic tell me to put in in the harvester and excavator but I would like to hear other opinions.
Offline cutter88
« Reply #4 on: November 05, 2013, 06:18:40 PM »
thanks guys :)
Romans 10 vs 9
Online Southside
« Reply #5 on: November 07, 2013, 09:02:38 PM »
I run about a gallon of the normal engine oil Lucas in each piece of my equipment hydraulic systems, it does help with small weeps and I have never had a problem with it.  I figure at that ratio it is basically coating all the internals and not flowing any longer.  I pulled a 6.5 out of a Chevy truck that had all but died, had not run in two weeks, when I pulled the oil pan off the cylinder walls were still coated with the lucas - that sold me on the stuff forever.
Offline Woodboogah
    • Blue Ribbon Outdoors
« Reply #6 on: November 08, 2013, 04:52:35 PM »
I use it in everything right down to mixing it with my saw gas.  Have never had a problem.  I saw an improvement in my truck after using it of .3 mpg.  This is with the injector cleaner stuff.
Keenan Logging & Tree Care, LLC
Offline gspren
« Reply #7 on: November 08, 2013, 09:42:02 PM »
  After reading this thread I decided to get some of the hydraulic booster for my old tractors, the auto parts place carries Lucas stuff but not the hydraulic booster so I tried a truck parts place and they have more Lucas products than I ever heard of so I'll need to stop back and check them out when I got more time, but I did pick up a gallon of the hydraulic booster so tomorrow I'll figure out if I can treat one or two tractors with one gallon.
Offline LaegersATC500R
« Reply #8 on: November 09, 2013, 05:54:22 AM »
I have a Posi Trac I bought back in "99". Needed it for a large job for removing logs out of tight areas. It's a great machine and served me well. Thats why I never sold it. Only 1200 hrs. on it. It has developed a leak in the rear drive motor area. Since we don't really use it a lot any more I never had it repaired. The leak always bothered me though. I'm going to use the hydraulic booster and we see what happens. I will let you know.
Morton Downey Jr. was a good man.
bar oil additive
Started by Pullinchips on Chainsaws
Last post May 23, 2005, 05:10:18 PM
by JD_Kid
bar oil additive
Started by tstex on Chainsaws
Last post March 14, 2017, 05:31:58 AM
by Al_Smith
water additive
Started by Qweaver on Sawmills and Milling
Last post August 17, 2013, 09:50:30 PM
by GeneWengert-WoodDoc
Egg Nog recipe and/or favorite additive
Started by samandothers on FOOD! FOOD! FOOD!
Last post December 24, 2015, 11:11:21 PM
by sawguy21
