Author Topic: Have to clean out my water to water heat exchanger  (Read 877 times)
Offline furjaw
  • Member*
« on: November 04, 2013, 02:41:05 AM »
I have a Central Boiler 5036 Outdoor Wood Furnace.
My Taco Model 009-F5 Circulation Pump just died.
The plastic impeller had disintegrated and was mostly missing.
I replaced the cartridge with Cartridge # 009-021RP.
It is working but apparently the flow is obstructed.
I have a water to water heat exchanger.
My guess is that the heat exchanger is plugged up with pieces of plastic from the impeller.
Offline doctorb
  • Unofficial Team Physician
Re: Have to clean out my water to water heat exchanger
« Reply #1 on: November 04, 2013, 05:24:30 AM »
The first thing to do is check every valve in your system to make sure one is not still closed.  I am not trying to belittle you.  It's the kind of simple thing that makes us pull out our hair.
Offline Roger2561
  • Love the outdoors
« Reply #2 on: November 04, 2013, 07:40:37 AM »
This brings up a question; when do you folks think I should do a bit of preventive maintenance?  I have the same Taco pump on my E-Classic 1400, going on my 3rd year of heating with it.  Should I go on the offense and change out the impeller before it breaks?  Or, leave it alone until it does break?  What's the average live span of the Taco 009-F5?   I'm thinking of purchasing a replacement impeller really soon anyway.  Thoughts?  Roger
Roger
Offline doctorb
« Reply #3 on: November 04, 2013, 08:37:59 AM »
Roger-  a previous thread with more info. re: Taco pumps
http://www.forestryforum.com/board/index.php/topic,58825.msg856137.html#msg856137
Offline Roger2561
  • Love the outdoors
« Reply #4 on: November 04, 2013, 11:25:04 AM »
doctorb - Thanks for the link.  That was very informative.  I think all I do for this winter is purchase a replacement cartridge to have on hand for the "just in case" scenario.  The funny thing is, I have a Taco on the oil furnace and that's 20 plus year old and it has never failed me (Now that I've said that...  ;) ).  I need to seriously think about having my water tested professionally to see what I have and I'll go from there.  Roger
Roger
On demand domestic hot water using water to water heat exchanger?
Started by Fether Hardwoods on Firewood and Wood Heating
Last post July 26, 2015, 09:50:11 PM
by r.man
moved
MOVED: A little off topic. Water to water heat exchanger.
Started by chet on Forestry and Logging
Last post February 08, 2015, 11:30:45 PM
by chet
Started by lopet on Firewood and Wood Heating
Last post March 01, 2015, 03:06:24 PM
by WmFritz
Heat Exchanger Wanted - Water to Water
Started by DR_Buck on Wanted
Last post October 21, 2009, 02:48:20 PM
by DR_Buck
