Dynamic Green Products Inc.
Author Topic: Howdy, new member here, old AS member with questions  (Read 837 times)
Offline Hillbilly Rick
« on: November 05, 2013, 11:22:36 PM »
 I have a couple of projects going on now.
 1) I have a Stihl MS 460 that I just put a BB kit on, new oil seals and rebuilt the carb. I'm getting no spark at all, I checked the gap on the fly wheel and coil, pulled wires off the coil to see if they were damaged, they weren't. I was wondering if anyone had any suggestions on what to try before I shell out $$$ for a new coil.
 2) J'red 2145, was checking for any undue wear or damage on the piston/cylinder, had to cut a muffler bolt off. The bolt is a m5x.80 about 85mm long. I've searched three counties and no one carries it. The J'red dealer I purchased the saw from quit selling them and has no stock and since he isn't a dealer, can't or won't get them.
 Any help would be greatly appreciated,
  Thanks,
      Rick
Socially unacceptable, Politically incorrect
Stihl MS 460 magnum with big bore kit, ported
J'red 2145
Homelite XL
Older than many on this site, Homelite XL
Ford F-350 7.3 diesel crew cab, flatbed, dually 4x4
Arctic Cat 500 4x4
Offline AKDoug
Re: Howdy, new member here, old AS member with questions
« Reply #1 on: November 06, 2013, 01:51:51 AM »
Trace your wires to the ignition switch. I've grounded them out by pinching them unknowingly and drove myself crazy. Just unplug the black wire from the coil and test for spark then.
If you have a Fastenal near you, they should be able to order the bolt for you.
Offline sharkey
« Reply #2 on: November 06, 2013, 01:54:13 AM »
If your not getting spark and the wires are ok and the gap is set, you basically need a new one.
How about a piece of threaded rod from a good hardware store or auto parts place.  5mm fine should be available.
Offline shootingarts
  • Location: South of the Border, the Mississippi border near I-55
  • Came here to edit and nuth'n to say
« Reply #3 on: November 06, 2013, 05:30:31 AM »
The little yellow hardware store can probably fix you up with a bolt if all else fails. Shouldn't be hard to find enough other stuff there to make an order worthwhile.
http://www.mcmaster.com/#socket-head-cap-screws/=p9c42w
Threaded stock carried locally is usually low grade alloys, not something I would want to use for your application.
Hu
Offline goose63
« Reply #4 on: November 06, 2013, 06:36:28 AM »
These guy's are in are in Spicer Minn. thy have been good to me 320 796 2147 might have the part's you need for the jred  :snowball:
goose
thank you to all the vets
Offline JohnG28
« Reply #5 on: November 06, 2013, 08:53:08 AM »
Chainsawr, a sponsor to the left, has got me every part I have ever looked for. Good chance you can find both the bolt you need as well as a coil for the 460 if needed. Good prices, OEM parts and shipped to your door. Got me muffler bolts for my ~30yr old Jonsered 490 last year in almost new condition, so I'd imagine he can find what you b need. If you don't see it online call him,often has more that isn't listed.
« Reply #6 on: November 06, 2013, 11:28:36 AM »
 Thanks Guys,
I've looked for 5mm thread stock too, none around. Living out here in the middle of nowhere, folks still don't carry much metric stuff. Unfortunately, I didn't realize this would be so hard to find and driving all over creation looking for it has made it a very expensive bolt that I still don't have and, of course, I needed it yesterday >:(. Had I known, I would have ordered it, guess I will now.
 On the Stihl, I just realized the yellow wire is bolted through to the body of the saw and I haven't left that one off and tried to start it, I'll see if that makes a difference. That switch is just a simple contact ground type switch, other than actually breaking, I don't see what could go wrong with it, my other one was broken, this is a used one I was given. I'll go through the wires again and see if there is something I missed.
 I'll try those numbers for the bolt and switch if I can't find them today.
   Thank you all very much,
      Rick
J'red 2145
Homelite XL
Arctic Cat 500 4x4
Offline beenthere
« Reply #7 on: November 06, 2013, 12:14:22 PM »
Hillbilly Rick
Have a Deere dealer close by? They use all metric I believe, and likely have a lot in stock.
Offline sablatnic
« Reply #8 on: November 06, 2013, 02:22:54 PM »
You should be able to get the bolt from a Husqvarna dealer. Don't just use any 5*85 bolt.
The parts number is 503 20 45-87.
Good luck!
« Reply #9 on: November 06, 2013, 03:04:03 PM »
Serious brain fart on my part. You see, I'm a millwright, when I tried to remove the muffler, the bolt was stuck, I didn't know if it was the head, shaft or threads and I wasn't willing to put excess pressure on it and strip the threads, so I cut the head off with a cutting wheel. The rest then unscrewed easily, so it was on the head ;D. This morning I wondered if I could weld a nut to it without damage, then it hit me, DUH! I have a tap and die set and I can thread the top and put a nut and lock washer on it any size I need. That problem solved, but I'll still get another bolt for it, needing different size tools for too many things clutters my bench.
Sablatnic, Thank you for the part# I can call the Husqvarna dealer to order it before I waste $20 in gas.
Beenthere, No JD dealer 'round here,but thanks it's still good to know. My S-I-L is a heavy equipment mechanic for a farmer with thousands of acres, and all they use is JD. He's just 225 miles away. It's still good to know.
J'red 2145
Homelite XL
Arctic Cat 500 4x4
New member - howdy!
Started by UncleMoustache on General Board
Last post November 12, 2020, 09:09:34 PM
by SawyerTed
New Member saying 'Howdy'
Started by Oregon_Harold on General Board
Last post February 26, 2006, 05:06:21 PM
by Mrs._Stump_Jumper
Howdy! from a new member
Started by PineHill4488 on Chainsaws
Last post November 06, 2013, 07:37:40 PM
by PineHill4488
New member. Howdy all.
Started by Cool Hound Luke on Sawmills and Milling
Last post January 21, 2010, 10:54:48 PM
by Howdy
