Dynamic Green Products Inc.
Author Topic: Oregon 511AX Grinder Question  (Read 1470 times)
Offline spinner
« on: November 08, 2013, 09:11:10 PM »
So there is a adjustment for when the grinding wheel gets wore down but in the instructions It don't explain it very good. Does anyone know how to set it, perhaps a video link. thanks. Them instructions that come with the grinder are garbage.
Offline Philbert
Re: Oregon 511AX Grinder Question
« Reply #1 on: November 08, 2013, 09:47:32 PM »
I don't have this model.  And agree that the instructions are terrible - like the manual for it's predecessor, which only makes sense after you already understand how to use it.
From my reading of the manual, section 27 seems to say that you look at the grinding wheel through the clear guard (figure 34).  When the wheel diameter is reduced to the mark 'A' on the guard, it is time to adjust the vise to compensate for the wheel wear.
Loosen the 2 bolts under the grinder (figure 35), and slide the vise assembly back until the pointer lines up with the 'A' marked on the scale (figure 36).
I frequently switch wheels for different sized chains, so I guess you have to watch out for that and adjust accordingly.
Let me know if this makes sense.
Philbert
P.S. - I was unable to attach a PDF of the manual due to its size, but I found it at this location (select link for manual): http://www.oregonproducts.com/pro/products/accessories/511AXBenchChainGrinder.htm
Offline spinner
« Reply #2 on: November 08, 2013, 10:01:46 PM »
that bottom piece that you slide the pointer to "A", is always there on "A", I don't see how the wheel wearing down makes the base move off the letter "A". kinda hard to explain, wish I woulda bought a silvey grinder maybe.
Offline Philbert
« Reply #3 on: November 08, 2013, 10:24:02 PM »
I am guessing that with a new (full size) grinding wheel the pointer should be at '0'?
I know that this seems like a small adjustment.  On my 511A grinder, moving the centering screw on the vise just 1/8 of a turn makes a big difference in keeping the Right and Left cutters the same length.
(I can't figure out what the other markings on this scale are for.  Don't see anything in the manual.  Maybe it works with other attachments?)
Philbert
Offline spinner
« Reply #4 on: November 08, 2013, 11:31:45 PM »
Thanks for the help, yeah I don't know why its got such a huge adjustment scale on it. I will just keep tinkering with it. Take er easy.
Offline bandmiller2
« Reply #5 on: November 09, 2013, 08:00:50 AM »
I have one of the first grinders of that type that came in from Italy. As the wheel wears things also change. What I've always done is sharpen one side, pivot vice and readjust to take off the same amount, close enough if you pay attention to your work. You can also measure cutter length with calipers and adjust accordingly. Frank C.
Offline ladylake
« Reply #6 on: November 09, 2013, 09:32:08 AM »
 Same as Frank here, also if the cutters are hair off it doesn't matter.   steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
oregon 511ax chain grinder
Started by lmo506 on Forestry and Logging
Last post November 04, 2014, 06:49:52 AM
by snowstorm
511ax chain grinder(no longer available)
Started by 1270d on For Sale
Last post January 20, 2014, 10:13:58 PM
by 1270d
Grinder Head Angles on a TECOMEC chain saw grinder--Same grinder as Oregon 511
Started by hydro2 on Chainsaws
Last post November 29, 2005, 01:15:23 PM
by rickk
oregon 511 grinder??
Started by clyde on Chainsaws
Last post December 26, 2005, 06:58:33 PM
by Rocky_J
