Author Topic: Race Chains versus Working Chains  (Read 2039 times)
Offline beenthere
Re: Race Chains versus Working Chains
« Reply #20 on: November 13, 2013, 07:47:01 PM »
I wouldn't do it that way, but whatever trips the trigger... go for it. ;)
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #21 on: November 13, 2013, 09:46:17 PM »
I always push the file into the tooth not leave a burr, same with a knife, ax .  :D
Offline Philbert
« Reply #22 on: November 13, 2013, 09:59:34 PM »
Oregon and STIHL recommend filing from the inside out for most cutters, but Oregon recommends filing outside in for square filed, full chisel chain.
Most people cannot keep the chisel moving in a perfectly straight line. If you screw up at the last second filing outside in, you might hook a file tooth and break off that edge you were working to build.
Not sure why this is acceptable for square filed chain. Maybe it self guides more once the edges are established?  Just speculating.
Philbert (not the sharpest cutter on the loop!)
    • A&P Saw mill LLC
« Reply #23 on: November 13, 2013, 10:08:45 PM »
Just the way I have done it for years and free hand to boot  :D
Can you use a skip tooth for a Race Chain ?
Offline Andyshine77
« Reply #24 on: November 13, 2013, 10:50:35 PM »
Inside out with round file, outside in when square filing.
Andre.
Pro chains and low kick back chains!
Started by KPSTIHLSAW on Chainsaws
Last post February 25, 2010, 12:32:34 PM
by HolmenTree
ring chains or ice chains
Started by donny hochstetler on Forestry and Logging
Last post December 28, 2009, 11:38:43 AM
by Ron Scott
Ring chains vs. Ice chains.
Started by rfm7fxfox on Forestry and Logging
Last post October 13, 2019, 10:33:04 PM
by Maine logger88
new tractor/chains or no chains
Started by BCinVT on General Board
Last post January 01, 2011, 08:06:41 PM
by Peter Drouin
