Dynamic Green Products Inc.
Author Topic: Sundogs in the frozen wasteland  (Read 879 times)
Offline rmack
  • Woodmizer owner
« on: November 23, 2013, 10:01:20 AM »
took a picture of these the other day, the two dogs on the outside looked like a pair of junior suns to the naked eye. picture taken just before noon.
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
Offline Chuck White
  • Sawing Mobile since 2005
Re: Sundogs in the frozen wasteland
« Reply #1 on: November 23, 2013, 10:52:33 AM »
That's a really good pic, we see them here once in a while!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Red Good
    • www.cycleonemanufacturing.com
« Reply #2 on: November 23, 2013, 11:33:07 PM »
My old man used to say some really cold weather coming when we saw those .
Stihl 211C saw
Massey 135 deisel tractor with a front loader
Can Am 800 max quad
2001 Chev S10 pick me up
Home made log arch
Offline Ianab
« Reply #3 on: November 24, 2013, 12:41:26 AM »
Ice crystals high in the air I think, so that would fit in with the cold weather theory  ;)
Offline WildDog
« Reply #4 on: November 24, 2013, 02:21:12 AM »
Interesting, nice pic. I can't recall ever hearing of Sundogs or even seeing them.
If you start feeling "Blue" ...breath    JD 5510 86hp 4WD loader Lucas 827, Pair of Husky's 372xp, 261 & Stihl 029
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: November 24, 2013, 10:07:36 AM »
I think that we don't have them in Mississippi.   ;D
Offline Autocar
« Reply #6 on: November 24, 2013, 08:14:41 PM »
Ive seen them here in Ohio.
Bill
Offline rmack
  • Woodmizer owner
« Reply #7 on: November 25, 2013, 08:22:11 AM »
It did get quite cold the next day. I think the same holds true when you see a halo around the moon... cold weather coming.
Welder Bob
1972 Patrick AR-5
Belsaw Boat Anchor
Offline WmFritz
« Reply #8 on: November 25, 2013, 08:35:02 AM »
That is a great photo. Funny though, at least for me... my natural instinct is to look away from the bright light.  :D
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
Offline rmack
  • Woodmizer owner
« Reply #9 on: November 25, 2013, 10:15:04 AM »
what can I say... I'm a welder.
Welder Bob
1972 Patrick AR-5
Belsaw Boat Anchor
Offline mesquite buckeye
  • Trees are good- even ones with stickers
« Reply #10 on: November 25, 2013, 10:37:55 AM »
When it gets really crazy, you can get a full ring with sun dogs on either side, then above and below, then a ring curving the opposite direction the same distance as from the sun to the main ring away from the ring.
Also can get a cross running from the sun to all the sun dogs and beyond them.
Offline Ianab
« Reply #11 on: November 25, 2013, 02:12:59 PM »
A halo around the sun (or moon) is a similar effect, but the sun is higher, and shining down through a high layer of ice crystals. Sun dogs are when the sun is lower, and comes though a lower layer of crystals, so you only see the halo on each side of the sun.
So sun dogs are more common in the higher latitudes, where it's more likely to have that cold layer near the ground, and hence it's also a sign of cold weather.
In warmer climates you don't see them, just the halo from ice up at 30-40,000 ft. Where it might be -50C, even when it's a summer day on the ground.
moved
MOVED: Sundogs in the frozen wasteland
Started by Ianab on Sawmills and Milling
Last post November 24, 2013, 12:42:04 AM
by Ianab
Frozen Red Oak
Started by Knute on Sawmills and Milling
Last post October 08, 2010, 08:16:50 PM
by red oaks lumber
Frozen Wood
Started by JimFX on Sawmills and Milling
Last post April 25, 2013, 10:52:35 PM
by beenthere
question
Frozen logs
Started by sdunston on Sawmills and Milling
Last post December 27, 2009, 05:13:07 AM
by ladylake
