We have contest winners!
They have a date stamp when made but I've never seen an expiration date on any of them .
Do not forget that it could be leaking back through the check valve between the compressor and the tank. You will not find that with soapy water unless you crack or disconnect the line at the compressor.
Anyone feel free to correct me if I'm wrong but I think if you figure how many square inches are in your tank you then multiply that by your psi and you get the "explosion force" when it lets go . All I know is NEVER use compressed air to remove the ram from a hydraulic cylinder!!!! I still have my right hand but don't know why .
Started by yukon cornelius on General Board
Started by coxy on Forestry and Logging
Started by Paschale on General Board
Started by lowpolyjoe on General Board
