Author Topic: setworks  (Read 2887 times)
Offline arnold113
  • In all things give praise to God
setworks
« on: November 28, 2013, 11:52:28 PM »
Last Tuesday when I got to run LeroyC's lt40 to saw up my first ever log, I got just a little taste of setworks. So now I'm going to put setworks on my diy bandmill. Being an electronics tech I shouldn't have too much trouble in designing setworks using a microcomputer. My biggest problem is I know very little about sawing. I am hoping that someone could find the time to give me a lesson on what setworks does and how it does what it does. Knowing that, I can write a computer program. Anyone's help would be great. Thanks. Arnold113
DIY band saw mill: four post, 25 HP gas engine, 32" x 18' portable, 24 vdc and hydraulic controls, pineywoods log turner, hyd log loader. RF remote controls for mill.  DIY set works.
Offline Gasawyer
Re: setworks
« Reply #1 on: November 29, 2013, 12:33:23 PM »
Depends on which setworks you ran. Simple set which was the first WM setworks(and what I have) is just a repetative stop system reading off the up/down chain. The newer setworks I haven't used is supposed to know where the bed is and do some other features. It reads of off a rod attached to the mast.  The simple set wouldn't be too hard to replicate I think.  Hope this helps.
Woodmizer LT-40hdd super hyd.,Lucas 618,Lucas 823dsm,Alaskian chainsaw mill 6',many chainsaws large and small,NH L555 skidsteer, Int. TD-9,JD500 backhoe, and International grapple truck.
Online Dave Shepard
  • Geometrically proportional
    • My homepage
Re: setworks
« Reply #2 on: November 29, 2013, 12:50:00 PM »
Bibbyman has a video of using WoodMizer's Accuset2. That should give you a good idea of what to expect. I also have Accuset2. It uses a linear transducer to tell the computer where the blade is in relationship to the bed.
Offline danreed76
  • I just need one more project...
Re: setworks
« Reply #3 on: November 29, 2013, 01:06:38 PM »
My Simpleset looks like it counts pulses from a prox switch which reads the driven pulley of the vertical drive system.  I'd say if you're using a similar setup (with a belt drive) it would be important to measure off the driven pulley so the accuracy isn't affected by belt slippage.
Woodmizer LT40 Hydraulic with resaw attachment |  Kubota MX5200  | (late)1947 8N that I can't seem to let go.
Offline Gasawyer
Re: setworks
« Reply #4 on: November 29, 2013, 02:19:49 PM »
Danreed76 what year is your mill? Mine is a 97 and it has an encoder with a sprocket that reads directly off the up down chain.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: setworks
« Reply #5 on: November 29, 2013, 02:59:56 PM »
There is a huge difference between today's SimpleSet and my '98 model SetWorks.
Offline arnold113
Apology
« Reply #6 on: November 29, 2013, 08:02:16 PM »
(Topics merged by administrator)
On Nov 28, I started a thread called 'setworks'. I believe I may have caused everyone to misunderstand what I was wanting. For that I deeply apologize to everyone. It was never my intention to try to copy any manufactures setworks. What I was hoping for was a few different people's way of preforming different task on their band mills such as a step by step list of the way they saw a log to obtain a square or rectangular cant listing everything they do for each step and why. This would be very helpful for all us newbees that doesn't know much about milling. I also thought that it might be good if these list could be put in the 'Tool Box' for future use of all newbees. Just a thought. Anyway, back to the reason I started the thread 'setworks'. After I had figured out a way that worked best for my mill from everyone's list I could then design my own diy setworks for my mill. My setworks would be a result of information from you great sawyers on the forum and not a copy of a manufacture's time and money spent to develop their setworks. I hope this explanation meets with everyone's approval, if it doesn't then I will withdraw my request for information. Thanks. Arnold113
Offline rmack
  • Woodmizer owner
Re: setworks
« Reply #7 on: November 29, 2013, 08:13:10 PM »
Welcome to the Forum  :)
btw, why the apology?
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
Offline Gasawyer
Re: Apology
« Reply #8 on: November 29, 2013, 08:28:05 PM »
OK now I see what your after. There could be a good sized book written on this question. I will try to make a short list in the morning when I'm not on this tablet.
Offline Chuck White
  • Sawing Mobile since 2005
Re: Apology
« Reply #9 on: November 29, 2013, 08:33:52 PM »
Arnold, I read through both posts and see nothing wrong with either and therefore don't understand the "Apology"!
You've done nothing wrong in my eyes anyways!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: setworks
« Reply #10 on: November 29, 2013, 08:37:11 PM »
We may drift off topic and even talk about food, but I do not believe that your intention or questions were misunderstood.  Back in my day, I would have been building, but now in my day, I am content to poke a button.   ;D
Offline bandmiller2
Re: Apology
« Reply #11 on: November 29, 2013, 08:37:17 PM »
Arny,not to worry mate most of us that have built our own mills have copied this and that from production mills.If you use ideas from production mills well and good but if you copy their ideas and sell for profit that's frowned upon.Computerized setworks are nice when everything is working but I'd also include a simple scale and pointer as a failsafe. Frank C.
Offline reswire
Re: setworks
« Reply #12 on: November 29, 2013, 08:41:33 PM »
Is it even possible to put a woodmizer or timberking setworks on any mill?  Are there any after market setworks available for bandsaw mills?  I sure am tired of bending over on my mill to see the measuring gauge.  Wish I could afford to buy setworks!! :snowball:
LT 40HDG 35, JD 5205, some Stihl saws, 15 goats, 10 chickens, 3 Chessies and a Weiner dog...
Offline arnold113
Re: Apology
« Reply #13 on: November 29, 2013, 09:55:50 PM »
Thanks everyone, I just didn't want anyone thinking I was looking for a free ride.
And yes, bandmiller2, I plan on having everything setup to work in auto and in manual, and hardwired and wireless. I just love building things but I always have to make them complicated. Arnold113
Offline JohnM
  • Sometimes its best to punt and play field position
Re: Apology
« Reply #14 on: November 29, 2013, 10:46:52 PM »
Arnold, have you met Hackberry Jake yet? ??? ;) ;D :)
Lucas 830 w/ slabber; Kubota L3710; Wallenstein logging winch; Split-fire splitter; Stihl 036; Jonsered 2150
Offline 5quarter
    • Blue Harbor Refinishing
Re: Apology
« Reply #15 on: November 30, 2013, 12:19:43 AM »
I can assure you that Jake resembles that remark very much... ;)
Offline drobertson
Re: Apology
« Reply #16 on: November 30, 2013, 07:38:38 AM »
neither post was out of line in my view, I thought about your question and could not come up with a condensed reply,, sorry,  good luck in your venture arny,    david
Offline woodmills1
  • the truth shall set you free
Re: setworks
« Reply #17 on: November 30, 2013, 02:55:54 PM »
I have accuset 1 on my lt 70, but I honed my skills at cutting on a manual LT 40
I do use the auto up and or down settings once in a while, but get the most use out of the pattern sawing
for example, I make many 4x4, so I will program a pattern that will cut one inch boards down to 4 inches
1. move blade to top of log and call up pattern, the setwork adds 4 +blade + 1 + blade etc to where the blade is
2. hit the down button, the setwork will drop to 4" plus how ever many 1" plus blade thickness are included up to the original position
3. cut off slab
4. rotate log 180 degrees
5. hit down button
6 cut off slab
I now have 2 flat faces that are 4" plus some 1" boards to remove later and 2 log faces
7. rotate log 90 degrees and go back to non setworks
8. move blade to top of log and re enter set works
hit down button and cut off slab
9. hit down button and cut one inch board  repeat till 2" from center
10 rotate 180 degrees
11. hit down and cut slab
12 hit down and cut 1" boards down to 4"
13 rotate 90 degrees and go out of pattern
14 drop blade to height of flat and reenter pattern
15 repeat steps 9 -12
this took almost as long to type as it would to cut and I left out some choices that are dependant on  variables other than the primary goal of leaving the 4x4 from the log center
the value of accuset is that I no longer have to calculate where the blade should be and no longer have to watch my scale stick to see that I am at the correct height
the other bonus is I can leave the program for a new face after rotating and re-enter and it will be ready to do the math at the new height
Offline arnold113
Re: setworks
« Reply #18 on: December 02, 2013, 04:47:24 AM »
woodmills1, how do you program setworks to cut 1" boards part way down then one 4" then more 1"?
Thanks everyone for your remarks and info. You're very thoughtful.
Thanks again. Arnold
Offline drobertson
Re: setworks
« Reply #19 on: December 02, 2013, 07:06:25 AM »
If using the auto down, one sets for one inch drops and another for four inch drops, switching back and forth on the respective saved settings.  The approach I might consider would be to use a pattern set for one inch drops stopping at four, when the desired face and section was reached, I would rotated, take the remaining one inch until the four inch mark is met,  this just gets into allot of dialog and typing explaining individual techniques, sorry,  good luck,   david
Setworks
Started by tacks Y on Sawmills and Milling
Last post July 04, 2020, 02:08:16 PM
by JB Griffin
setworks
Started by pzimmerman on Sawmills and Milling
Last post March 18, 2019, 10:23:33 PM
by Larry
Need Setworks.
Started by BBK on Wanted
Last post May 25, 2006, 05:54:30 AM
by BBK
B20 Setworks
Started by Bolson400 on Sawmills and Milling
Last post January 31, 2020, 08:10:32 AM
by tylerltr450
