Author Topic: De-barker  (Read 2223 times)
Offline Gentlewolf
De-barker
« on: December 01, 2013, 10:36:08 PM »
What is the benifit to the de-barker option on the new mills?
Offline thecfarm
Re: De-barker
« Reply #1 on: December 01, 2013, 10:38:01 PM »
Gentlewolf,welcome to the forum. Are you buying a mill? Upgrading?
Offline Gentlewolf
Re: De-barker
« Reply #2 on: December 01, 2013, 10:45:52 PM »
Looking to buy a mill soon and was wondering if the debarker is a huge benifit or not, right now I used friends old woodmizer 40 but soon going to purchase a mill for myself
Offline thecfarm
Re: De-barker
« Reply #3 on: December 01, 2013, 10:53:28 PM »
While you are waiting for replies,go to the top of this page, put in debarker, into the search box,click onto the next box,I see This Topic,you want This board,we are in the Sawmill board and press search. that will keep you busy.  :D
Offline Gentlewolf
Re: De-barker
« Reply #4 on: December 01, 2013, 10:55:36 PM »
Thanks I will check it out
Offline kelLOGg
Re: De-barker
« Reply #5 on: December 02, 2013, 05:32:09 AM »
My "debarker" is one of various tools I use to peel bark off of a lot of pine I have. It extends the band lifetime very significantly. In my case, if the bark were still tight I would choose to saw right thru it suffer the consequences of sand/dirt. If I had a production mill I would certainly have a debarker.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: De-barker
« Reply #6 on: December 02, 2013, 07:43:54 AM »
My Debarker is second only to my Setworks.  I would not saw without both of them.
Offline ladylake
Re: De-barker
« Reply #7 on: December 02, 2013, 08:41:36 AM »
 I found my debarker more trouble and in the way than what it was worth and took it off, I'd never be without my sharpener, and yes a couple times a year I wish I had my debarker on. About 90% of the time I can get any dirt off in the first slab and flitch board.   Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: De-barker
« Reply #8 on: December 02, 2013, 08:50:47 AM »
My Debarker was the best think I had installed on my mill before it arrived to the farm.
It has paid for itself. I don't have to scrape bark off or wash logs……put 'em on the mill, engage Debarker and go to sawing.  8)
Offline drobertson
Re: De-barker
« Reply #9 on: December 02, 2013, 08:56:13 AM »
the advantage shows up when sawing heavily skidded logs. They are not 100% in my opinion but better than not having if the logs are dirty.  The one on my 40 is trouble free, not sure on other makes,    david
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: De-barker
« Reply #10 on: December 02, 2013, 09:06:38 AM »
I always set the log up for the first face opening according to the log, not the dirt.  That way the debarker takes care of the dirt and I get the most quality lumber from the log.  Notice the turner claw marks made when I adjusted the log.
This SYP log is set up for sawing.  The Debarker will and did take care of the embedded dirt.
Offline Chuck White
  • Sawing Mobile since 2005
Re: De-barker
« Reply #11 on: December 02, 2013, 09:40:29 AM »
Welcome to the Forestry Forum, Gentlewolf.
I would not want to be without my debarker.
I honestly believe that the debarker extends blade life about 5 times!
Without a debarker you can get into a situation where you can't saw a whole log without changing the blade, unless you scrape the dirt off!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline mesquite buckeye
  • Trees are good- even ones with stickers
Re: De-barker
« Reply #12 on: December 02, 2013, 09:53:05 AM »
I concur with what was said before. The debarker will pay for itself quickly with extended blade life and less hand cleaning time. I would also add a leaf blower to the list of stuff you need. Blows off loose dirt, use to clean up sawdust on the mill, lumber and engine. You can pick up a good lightweight one for $100-150.
Offline ladylake
Re: De-barker
« Reply #13 on: December 02, 2013, 10:47:46 AM »
 In that pic I would just give the another 1/4 turn and be in clean wood and still be cutting the same 4 faces.   Most times there are ways around dirt.  Steve
Re: De-barker
« Reply #14 on: December 02, 2013, 01:04:18 PM »
One more thought I didn't mention earlier. Lots of windblown grit gets embedded in the tree bark, so if you don't have to cut through that, the blade will last longer. The debarker can help you even if the logs look clean. Also in many species the outer bark can actually be harder than the wood you are cutting, so more blade wear that you can reduce with the debarker. I love mine. ;D
Offline Gentlewolf
Re: De-barker
« Reply #15 on: December 02, 2013, 02:42:19 PM »
Thanks for the advice, looks like the opinions sway both ways on the subject, a lot to consider
Offline Gentlewolf
Re: De-barker
« Reply #16 on: December 02, 2013, 02:51:14 PM »
I have been looking and considering the lt35 hydraulic from woodmizer is there another mill from another manufacturer that would compare
20,000 is a lot of money, but it is an investment and I want the best along with the most out of my money any ideas on that?
Re: De-barker
« Reply #17 on: December 02, 2013, 02:55:56 PM »
IMO…..go with the Woodmizer and the Debarker. You can thank me later.  ;D
Offline JustinW_NZ
  • Just Hacking and stacking.
    • Logs2Lumber
Re: De-barker
« Reply #18 on: December 02, 2013, 03:03:19 PM »
I'm in a different country and generally sawing different things but still love the debarker.
Since i'm portable sawing for others and charge by the hour I think it is a must, as it extends the time between blade changes and no time spent mucking about with dirty logs.
Also - Welcome to the forum, great place here :)
Cheers
Justin
Gear I run;
Woodmizer LT40 Super, Treefarmer C4D, CAT 528 swinging grapple, 10ton wheel loader.
Offline Peter Drouin
    • A&P Saw mill LLC
Re: De-barker
« Reply #19 on: December 02, 2013, 07:43:52 PM »
 smiley_thumbsup
A&P saw Mill LLC.
License NH softwood grader.
De-barker
Started by DonT on Chainsaws
Last post October 25, 2002, 09:19:43 PM
by Russ
Be-barker blades
Started by Joed on Sawmills and Milling
Last post March 11, 2018, 01:10:29 PM
by Magicman
Hillbilly De-Barker.
Started by Skoalbandit78 on Sawmills and Milling
Last post November 30, 2012, 07:29:53 AM
by taylorsmissbeehaven
Old Barker C4 Saw - Need Info Please
Started by KonaKustoms on Chainsaws
Last post November 17, 2013, 02:57:43 AM
by KonaKustoms
