Author Topic: De-barker  (Read 2222 times)
Offline AnthonyW
  • Wannabe hobby sawyer
Re: De-barker
« Reply #20 on: December 02, 2013, 09:18:39 PM »
I haven't even cut a single slab and I'm already contemplating upgrades. But more so, saving money. For my old LT25, what options do I have for a debarker?
'97 Wood-Mizer LT25 All Manual with 15HP Kohler
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: De-barker
« Reply #21 on: December 02, 2013, 10:55:18 PM »
A debarker is a fundamental accessory.  Before the debarker, when I had a dirty log, I used to pressure wash, scrub with a brush, chop with a hatchet, and scrape with a drawknife.  Now with a debarker, I just saw.
YH
HobbyHardwoodAlabama.com
Offline Brucer
Re: De-barker
« Reply #22 on: December 03, 2013, 12:53:18 AM »
Here's the standard consultant's answer. "It depends."
I ran another guys Wood-Mizer for a season, no debarker. Didn't miss it when I was sawing Western Red Cedar. Didn't know what I was missing when I was sawing Douglas-Fir. The D-Fir bark holds a lot of dirt/sand/clay/pebbles/rocks.
My manual mill didn't have  debarker and by the time 9 months had elapsed, I was seriously regretting it.
When the opportunity came to upgrade to a hydraulic mill, the debarker was the very first option I chose. I've since added an autoclutch, a few quick-adjust outriggers, a dragback, and modified my blade lube system to make it semi-automatic. Still no setworks.
If I had the volume of work to justify it, my next machine would be a Super Hydraulic with a full set of FA outriggers, a diesel power plant, remote operator's station, autoclutch, lubemizer, and maybe setworks. But number one would be a debarker.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline customsawyer
    • The Custom Sawyer
Re: De-barker
« Reply #23 on: December 03, 2013, 03:00:51 AM »
The best example I can give is one time when Danny and I was cutting one of our many projects. We had a log loaded up with a fair amount of Ga. red clay on the outside of it. I got the log in position and Danny steps up to start cleaning the log. I motioned for Danny to get out of the way engaged the debarker and went to sawing. Danny just stood there shaking his head and said, "That one cut would have killed a blade on his mill". The debarker will not only save you money on blades but in time from not having to clean the logs.
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: De-barker
« Reply #24 on: December 03, 2013, 03:54:49 AM »
Yep…..everyone should experience some of this Southern Red Clay. Can't live without a debarked.
Offline Gasawyer
Re: De-barker
« Reply #25 on: December 03, 2013, 12:39:02 PM »
I agree that red clay is problem almost as bad as sand. I would do without set works before not having a debarker. Really depends on where you're logs are coming from on how necessary a debarker is. Most of the time I need it.
Woodmizer LT-40hdd super hyd.,Lucas 618,Lucas 823dsm,Alaskian chainsaw mill 6',many chainsaws large and small,NH L555 skidsteer, Int. TD-9,JD500 backhoe, and International grapple truck.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: De-barker
« Reply #26 on: December 03, 2013, 08:50:51 PM »
I had seven logs really caked with dried mud today.  I got 1500bf, but it took 4 blades.  The Debarker took care of it's side and we wire brushed as best we could with the off side, but it was still bad.  They looked like glazed donuts.
Re: De-barker
« Reply #27 on: December 03, 2013, 09:05:17 PM »
Just be glad you had a Debarker with all that mess!  :D
Offline Peter Drouin
    • A&P Saw mill LLC
Re: De-barker
« Reply #28 on: December 03, 2013, 09:24:55 PM »
Mud, you should try frozen gravel and rocks on a log and the de-barker rides over the rock and cleans it nice then the blade cuts the rock in half and ruins  the blade.  :D :D ;D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: De-barker
« Reply #29 on: December 03, 2013, 09:43:31 PM »
I can not even imagine the horror of frozen mud or logs.   :o
Offline thecfarm
Re: De-barker
« Reply #30 on: December 03, 2013, 09:44:55 PM »
Lucky you.  :D
    • A&P Saw mill LLC
Re: De-barker
« Reply #31 on: December 03, 2013, 09:51:14 PM »
Even the bark freezes on the log. Can't get it off either. :D :D
Offline Brucer
Re: De-barker
« Reply #32 on: December 03, 2013, 11:39:38 PM »
The one case where I'd like a debarker on the exit side of the cut is when I'm sawing an ice-covered log in the winter. More than once I've seen the sparks flying on the exit -- the blades is sawing through dirt that's embedded in the ice :(.
Offline kelLOGg
  • More is better but enough is best
Re: De-barker
« Reply #33 on: December 04, 2013, 05:45:20 AM »
OK. It's time for someone to say "it always comes down to food". I did it.
Speaking of food, the NC gathering will be Saturday IF it isn't rained out.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline JFarmer
Re: De-barker
« Reply #34 on: December 06, 2013, 02:33:58 PM »
Buy the debarker. It will save you time and money and you wont regret it!
LT40 electric,woodmizer twin blade edger,cooks catclaw sharpener,suffolk setter, john deere 450 dozer, case 90xt skidsteer, 7010 4x4 mahindra tractor
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
Re: De-barker
« Reply #35 on: December 07, 2013, 02:06:23 AM »
I use the mud saw only when logs are dirty, and have worn out the motor and both arms, ordered a complete new set up from wm.
Over the last couple months while the arms are being build, we have been sawing logs like mm pine, avoid the mud to some degree, never the less a box of saws don't got as far.
De-barker
Started by DonT on Chainsaws
Last post October 25, 2002, 09:19:43 PM
by Russ
Old Barker C4 Saw - Need Info Please
Started by KonaKustoms on Chainsaws
Last post November 17, 2013, 02:57:43 AM
by KonaKustoms
Be-barker blades
Started by Joed on Sawmills and Milling
Last post March 11, 2018, 01:10:29 PM
by Magicman
Hillbilly De-Barker.
Started by Skoalbandit78 on Sawmills and Milling
Last post November 30, 2012, 07:29:53 AM
by taylorsmissbeehaven
