Looking for a board feet calculator app
Started by Southside, December 06, 2013, 09:51:58 PM
Southside
Well, I broke down and got a smart phone - only because my old flip phone died.  Must say I am pretty impressed with the thing, got a Samsung S4 for $0.96 at Sam's. I found an app to tell me the height of a tree and would like to find one to calculate the BFT in that tree.  Anybody have any suggestions? Any other helpful apps you would suggest?
Jim
White Oak Meadows
Lots of good stuff under the Extras tab. Everyone should check it out.
Southside
Thanks Jeff - can I put that on my phone as an app?  Sorry, technology and I do not have the best relationship.
Jim
White Oak Meadows
There is a mobile version of the forum, with a mobile version of the tool box.  :)
wmrussel
Mobile Forum?  Now I need to get that......I don't log on here enough.
My name is William, but people call me Pete.  Long story......
wmrussel
 8) Just checked out the toolbox on the mobile site.  Calculated the BF in a 2x4x8.  Pretty nifty.  Y'all do a good job on here!
sshier
Check out the handy man calculator in the android store its free and i use it alot have a great holidays
ancjr
Quote from: sshier on December 07, 2013, 06:52:18 PM
Ditto.  Has a lot of other flunctions, which are related to light construction.  But, when I'm on the 'net, I use the forum tools too.
wmrussel
I'm installing it now, thanks for the heads up!
jonnywood
what app are you using for the tree height?
Southside
Jonny, I found an app called "Smart Measure" on the Google Apps Store, pretty easy to use and so far is quite accurate.  Trying to find one for basal area as well but the only one I found was in Russian.   >:(
White Oak Meadows
KBforester
Norwood has an app for log volumes... its pretty good. Has numbers for Doyle, Scribner and International 1/4. It also weights and lumber.
Trees are good.
Westernstarfan51
Quote from: Southside logger on December 08, 2013, 07:12:31 PM
Basal area is very simple, DBH*.005454
clearcut
QuoteBasal area is very simple, DBH*.005454
DBH^2*0.005454 = Basal Area in sq ft.per acre
DBH^2*0.00007854 = Basal Area in sq m per hc.
Carbon sequestered upon request.
Westernstarfan51
Quote from: clearcut on December 09, 2013, 11:28:06 AM
oops that's my bad forgot the ^2, I didn't know the sq m per hc, we only use sqft. thanks for fixing that.
Southside
Math class was a long time ago, what function is the ^ ?
White Oak Meadows
It is the logarithmic function.  Like raising a number by a power, in this case, the diameter squared.  If the diameter (DBH) was 12, then DBH^2 would be 12 x12 = 144
ancjr
x^y is exponent function, log x(y) is the reverse of the exponent function.
10^3=1000
log 10(1000)=3
clearcut
The ^ is the symbol used by Excel and most other spreadsheet programs to indicate exponents. Subscripts and superscripts do not always translate well. The asterisk * indicates multiplication. This avoids the confusing X for times or X=some unknown number.
     DBH^2*0.005454=BA
would traditionally be written:
     DBH20.005454 = BA
with the squared term indicated with a superscript and multiplication implied.
Elements of the first equation could be copied and pasted into a spreadsheet cell.
