Author Topic: Handlebar hose  (Read 1003 times)
Offline ramv102000
  • Member
Handlebar hose
« on: December 07, 2013, 02:31:38 PM »
OK, there must be a trick to this . Bought a new piece of Stihl handlebar hose but can't figure out how to even get it started over the bar , then work it all around. HELP
Randy
Online thecfarm
Re: Handlebar hose
« Reply #1 on: December 07, 2013, 02:33:53 PM »
Somewhere on Youtube?
Offline ramv102000
  • Member
Re: Handlebar hose
« Reply #2 on: December 07, 2013, 02:49:35 PM »
Tried you tube , no luck
Randy
Online beenthere
Re: Handlebar hose
« Reply #3 on: December 07, 2013, 02:51:36 PM »
Dealer have any suggestions when you picked it up?
Seems I used some detergent, and suspect it was LOC from Amway at the time.
Offline ramv102000
  • Member
Re: Handlebar hose
« Reply #4 on: December 07, 2013, 03:14:23 PM »
bought off ebay, warmed it up with a blow dryer and got it started, about 2 " worked on so far. Looks like it 's gonna take awhile.
Randy
Offline sablatnic
Re: Handlebar hose
« Reply #5 on: December 07, 2013, 03:53:16 PM »
I use an air hose, and blow air in under the edge of the handle hose. The air reduces the friction enough to make it possible to slide it on.
To be honest, I haven't tried the trick on a Stihl handle, but it does work on lawnmower handles.
Good luck!
Online Al_Smith
Re: Handlebar hose
« Reply #6 on: December 07, 2013, 07:51:27 PM »
Go to an electrical supply house and get a little bottle of "poly water " wire pulling compound which is jellied water ,industrial strength KY jelly .Friction coefficient of about zero .It's water,it evaporates .
Offline JJ
  • Gotta figure this out
Re: Handlebar hose
« Reply #7 on: December 07, 2013, 08:07:15 PM »
If it is anything like mountain bike handgrips, the bike shops use hairspray.
Soak it, so it slips on, and then it drys locking the grip in place.
          JJ
Offline AdkStihl
    • J.Miller Photography
Re: Handlebar hose
« Reply #8 on: December 07, 2013, 09:02:36 PM »
          JJ
Yup, used to do that on my BMX and then later on the MotoX. Although we found that plain old black spray paint worked extremely well too!!
Maybe try to put it in a sink of HOT water for a few mins?
Offline sharkey
Re: Handlebar hose
« Reply #9 on: December 07, 2013, 11:25:30 PM »
That Stihl handlebar hose is really hard to work with.  If you put oil under it, then its always there once you get it on and it twists.  Your best bet is to use an air line with a tubeless tire valve that will fit into the end of the hose.  Better yet is the shrink wrap kind that is a lot easier on you.
mount 330 homelite handlebar?
Started by Jim Davis on Chainsaws
Last post April 05, 2016, 11:31:33 PM
by Jim Davis
question
357XP Full Wrap handlebar
Started by Mac102004 on Wanted
Last post May 28, 2014, 06:59:49 PM
by Mac102004
Need help finding hose
Started by Dewey on Sawmills and Milling
Last post October 27, 2012, 01:02:58 AM
by giant splinter
hydraulic hose
Started by bedway on General Board
Last post September 25, 2011, 12:20:07 PM
by maple flats
