Author Topic: Started the kiln  (Read 839 times)
Offline mmartone
  • I'm new! but I'm old.
Started the kiln
« on: December 11, 2013, 10:44:11 PM »
I had sawn this stuff a week or two ago, 2x10 outside edge, 1 1/2x6 joists (16" OC), 1x4 flooring diagonal.  Going to nail some 2x4 leger boards on under the 1 1/2x6's. Got some 3x3 posts sawn for the corners and going to lag bolt them to the base and the sides to them.
Remember, I only know what you guys teach me. Lt40 Manual 22hp KAwaSaki, Husky3120 60", 56" Panther CSM, 372xp, 345xp, Stihl 041, 031, blue homelite, poulans, 340
Offline bedway
Re: Started the kiln
« Reply #1 on: December 12, 2013, 12:23:26 AM »
Looking good so far, keep us posted. :)
Offline Deese
« Reply #2 on: December 12, 2013, 09:32:59 AM »
Definitely keep us posted with lots of pics  ;D
Hopefully I will be able to build mine this Spring  :-\
2004 LT40 Super 51hp diesel
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
Offline GeneWengert-WoodDoc
« Reply #3 on: December 12, 2013, 06:04:15 PM »
Looks like a long span for having four posts...one at each corner.  Better would be six, with the two extra halfway down.  Otherwise, move the corner posts in about three feet from each end.
Offline mmartone
« Reply #4 on: December 15, 2013, 09:51:53 PM »
Why are you worried about the walls moving? The big back wall is aluminum with a 3" foam core like a stand alone cooler/ freezer. The rest will be wood with appropriate framing unless we find some more panels.
Offline kderby
  • Western Juniper Sawmill
    • junipersawmill.com
« Reply #5 on: December 16, 2013, 08:21:44 AM »
The combination of heat, moisture and time are structural challenges.  Better to over-build than to see a problem develop.  The kiln is part of your system for producing quality lumber.  Like a tire that is under inflated when you want get on the road, a problem in the kiln is a problem!
You can build it how ever you choose.  Gene just picked up on the span and mentioned it.  I can see where the weight of green lumber and heat will be forces to be reckoned with.
question
Getting Started - Sawmill & Kiln
Started by BoilerUp21 on Sawmills and Milling
Last post September 03, 2021, 08:18:06 AM
by BoilerUp21
well, I started on the kiln finally.
Started by hackberry jake on Drying and Processing
Last post July 16, 2014, 08:12:31 PM
by Den Socling
Finally!!! got started on dry kiln
Started by sandsawmill14 on Drying and Processing
Last post June 03, 2015, 07:50:43 AM
by sandsawmill14
solar kiln started
Started by xlogger on Drying and Processing
Last post August 03, 2015, 07:07:37 AM
by GeneWengert-WoodDoc
