Dynamic Green Products Inc.
Author Topic: Quarter sawing  (Read 2368 times)
Offline qbilder
  • lil helper
Quarter sawing
« on: December 16, 2013, 03:16:33 PM »
Not sure how yall do it, but I lay the log on the mill and begin my first cut just below the pith on small end, so to keep the grain running parallel to the mill bed. I take the top half & flip it, and repeat. What I have left over is a wedge shaped slab with the pith centered in it. It gets tossed and I have two halves with grain running parallel to the mill. I shave the sharp edges off then get a few wide QS boards from each half. What's left of each half I turn upright and slab through. This gives me the highest yield of wide but true QS boards, and the rift sawed boards are the narrowest.
If that description makes sense to anybody, am I doing this right? Am I missing or seeing something wrong? It seems to work very well with maple, but the wide oak boards seem to cup. Is it because they are cut too close to where the pith was? What causes the cup on a seemingly perfectly QS board? The narrow boards stay flat & straight. My problem is the wide center cut boards. Thanks in advance for any tips.
God bless our troops
Offline beenthere
Re: Quarter sawing
« Reply #1 on: December 16, 2013, 03:24:20 PM »
Why quarter saw maple?
For stability?
Just curious.
Offline dboyt
  • Log On!
Re: Quarter sawing
« Reply #2 on: December 16, 2013, 03:59:09 PM »
I think I have a picture of what you're doing, though I have never heard of anyone doing i quite the way you described.  If you look at the grain of the wide pieces, you will notice that it is NOT quartersawn near the pith, but, for a short distance is flat sawn down the center of the board.  Quarter sawn wood shrinks in width radially, and the flat sawn part is shrinking tangentially.  Since the wood shrinks more tangentially than radially, the board will have uneven shrinkage, and will warp.  Different species have different properties in this regard.  This kind of cupping gives a fairly sharp "V" cupping.  The other thing is that the only wood that you are cutting parallel to the grain is the outer wood.  As you move toward the center of the log, the slope of the grain will increase, until it matches 1/2 the angle of the wedge.
Tight strapping or lots of weight will help keep the boards flat during drying.  I'm sure others will have additional ideas.
Offline woodmills1
  • the truth shall set you free
Re: Quarter sawing
« Reply #3 on: December 16, 2013, 04:09:59 PM »
I don't cut the faces off the quarters, I cut the whole quarter as you are doing after you cut the faces off.  My quartered wood is and stays flat.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Quarter sawing
« Reply #4 on: December 16, 2013, 04:21:28 PM »
The idea of QS boards cupping I don't understand.  If your QS boards have too much juvenile wood on the edges this can cause them to crook.   Also don't understand discarding the "wedge shape slab with the pith centered in it"...if I understand what you describe,  this board would have at least several boards worth of thickness and would therefore contain some of the prime QS material on either sides of the pith.
I know it depends on the size of the log but logs that are big enough to be worth quartersawing I remove and discard the equivalent of at least a 4x4, sometimes up to 6x6 (2-3" at least from the center) of juvenile wood from the customer's boards.   I've also heard it said get rid of the first 15 years worth.
Online Ianab
Re: Quarter sawing
« Reply #5 on: December 16, 2013, 04:42:15 PM »
Quote
This is what I'm thinking too. You effectively have 2 x Quarter sawn boards there, joined with a small piece of unstable rift / flat sawn material from near the pith. The centre piece is going to (mis)behave differently to the quarter sawn section, and probably cup.
If you need the wide board, then dry it on the bottom of the stack. LOTS of weight might help.
If you need quarter sawn boards, then rip that middle section out and throw it on the firewood pile as well. It won't behave any better on it's own, but the 2 good Q-sawn boards should behave better without it.
Offline qbilder
  • lil helper
Re: Quarter sawing
« Reply #6 on: December 16, 2013, 05:35:43 PM »
Thanks, guys! Yes you are correct that the center of the board is not QS. There's about an inch or two of curved grain, and that's where it cups. From now on I will rip that area out.
I quarter saw maple for pool cues. The quarter sawing makes for very stable wood.
Offline beenthere
Re: Quarter sawing
« Reply #7 on: December 16, 2013, 05:45:40 PM »
Quote
Seems straight grain for a pool cue would be the most important wood characteristic.
I assume the are turned so end up round.
Don't understand how being from quarter sawn stock can have much of an effect unless it is easier to identify the straight grain for ripping out blanks.
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
Re: Quarter sawing
« Reply #8 on: December 16, 2013, 06:10:09 PM »
     I don't doubt you a bit.  But it seems to me that flat sawn wood would move in one direction, and quarter sawn in the other.  Am I missing something?  Maybe the quarter sawn doesn't move as much?
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Offline mesquite buckeye
  • Trees are good- even ones with stickers
Re: Quarter sawing
« Reply #9 on: December 16, 2013, 07:37:50 PM »
I'm thinking BT is right here, unless you are working with wood that is still a bit wet and will move. Are we talking a diamond distortion issue?
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: Quarter sawing
« Reply #10 on: December 16, 2013, 07:46:05 PM »
I too can not see where quarter sawn makes a difference in a pool cue or how you would ever tell once it was cut out. You rip a strip from flat or quartersawn that is roughly the size you need, and flip either a quarter turn and the one becomes the other.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Quarter sawing
« Reply #11 on: December 16, 2013, 08:04:33 PM »
This reply is enough to make me go get an Advil.
But the more I thing about it..you are right!  :D
Re: Quarter sawing
« Reply #12 on: December 16, 2013, 08:26:54 PM »
I have thought about a quarter sawn pool stick.
I have a pool table and I shoot pool a lot.
I am thinking..by quarter sawing a pool stickit is to gain stability in the pressure that goes through the stick when hitting the Q ball to break open a rack.
There are pool sticks used just for breaking a rack that are made in one piece. And usually your professional shooting pool sticks come in two pieces.
Y'all see what I am talking about?
Offline qbilder
  • lil helper
Re: Quarter sawing
« Reply #13 on: December 16, 2013, 08:46:08 PM »
Quarter sawing doesn't have any affect on the finished cue. It dries with less stress, so the tendency to warp is lessened. I could, and have, cut turning squares from flat sawn stock & it's a crap shoot on whether it'll warp or not. Many times it's warping as I am ripping it from the board. Quarter sawn wood for the most part stays true. Once turned round, there's absolutely no way to know how the log was milled, and doesn't even matter so long as it's straight. In a nut shell, flat sawn wood warps more often & more severely than quarter sawn wood. At least it does as a cue. Another benefit to quarter sawing is that the grain is on the face of the board, so I can take a straight edge & make a line parallel to the grain for ripping. This centers the grain to the line of the cue. That's also why I saw the log the way I do, cutting below the pith so that the grain of the log runs parallel to the mill bed. I even choose my trees for straightness and minimal defects. Once the cue is completed, there's no way to know tell how it was cut. Everything I'm doing just makes less waste due to warp. A finished shaft is 29" long and tapered from around 7/8" big end to 1/2" small end, and it has to be straight or else the buyers get upset.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Quarter sawing
« Reply #14 on: December 16, 2013, 09:01:16 PM »
It sounds like you have a very specialized niche' market.
Offline mikeb1079
Re: Quarter sawing
« Reply #15 on: December 16, 2013, 09:45:54 PM »
his ques are awesome!  i've seen some pics in the past but q you should post up some more!!
homebuilt 16hp mill
Offline beenthere
Re: Quarter sawing
« Reply #16 on: December 16, 2013, 11:12:04 PM »
qbuilder
That makes good sense. Thanks for the info.
Offline Nomad
  • Member
Re: Quarter sawing
« Reply #17 on: December 16, 2013, 11:51:21 PM »
     Yes, if you're ripping it to center the grain in line with the center of the que it does make sense.
Lucas DSM23-19
Re: Quarter sawing
« Reply #18 on: December 17, 2013, 08:20:33 AM »
Absolutely, wooden pool balls don't matter how they were sawn.
Offline qbilder
  • lil helper
Re: Quarter sawing
« Reply #19 on: December 17, 2013, 12:44:13 PM »
Thank you for your thoughts, gentlemen.
First quarter sawing
Started by MrMoo on Sawmills and Milling
Last post August 12, 2004, 07:33:30 PM
by Bibbyman
Quarter sawing
Started by peterduncan on Sawmills and Milling
Last post June 29, 2008, 10:11:23 AM
by MemphisLogger
Quarter Sawing
Started by Russ on Sawmills and Milling
Last post April 18, 2005, 09:51:12 AM
by MrMoo
quarter vs through & though sawing?
Started by krusty on Sawmills and Milling
Last post March 13, 2007, 01:32:47 AM
by footer
