Dynamic Green Products Inc.
Author Topic: Bug problem  (Read 1038 times)
Offline rvrdivr
Bug problem
« on: May 30, 2004, 02:10:28 PM »
I have a stack of southern pine I'm about to saw up. When I stand at the pile I can hear the tell tale sound of the flat head borer bettle eating away at a few of the newest logs I just brought in.
I want to ask, If I cut this wood and mix it with the good wood in a air drying barn, will they die as the wood drys or infest the other wood?
What can I do to kill these little SOB's short of kiln drying the wood?
Thanks,
Brian
Re: Bug problem
« Reply #1 on: May 30, 2004, 03:16:34 PM »
We run into it all the time.  The only way to fight them is to cut the logs right off of the stump or submerge the logs in water (pond) until you can saw them.
Usually you will slab the bugs of of the outside of the tree.  I've sawed many flat-head borer infested logs and gotten good lumber.  Drying asap is also a combatant.  Spraying with an insecticide helps.  Getting the slipping bark away from the logs as soon as possible helps too.  The Beetles are laying their eggs on the bark and they live beneath it for quite some time.
If the wood is to be pressure treated, then you haven't much worry.  It'll kill most anything.
I have a problem problem starting Stihl ms290 chainsaw
Started by bardos on Chainsaws
Last post May 07, 2015, 08:42:26 AM
by GAB
Tic problem
Started by bluffman2 on General Board
Last post September 06, 2014, 09:34:29 AM
by pappy19
PH 260 problem
Started by ARKANSAWYER on Drying and Processing
Last post August 12, 2008, 12:06:39 PM
by ARKANSAWYER
Problem with 660.
Started by DaveP on Chainsaws
Last post March 14, 2017, 07:57:06 AM
by DaveP
