Dynamic Green Products Inc.
Author Topic: Staying Fixed  (Read 3154 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Staying Fixed
« on: January 08, 2014, 08:50:00 PM »
While sawing the Goodwill job for dablack in Texas in December I had a power feed problem that came close to making me convert the LT40 Super to a manual sawmill.  A bearing failed that I had replaced in April, 2010.  LINK  No way would I have ever imagined that I would have power feed problems this soon, but bearing failures happen.
It warmed up enough today for me to tackle the problem which first required removing the power feed motor and feed assembly.
Not much left of that bearing.
Thankfully a new bearing was available locally.
And now my power feed is happy again.   :)
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Staying Fixed
« Reply #1 on: January 08, 2014, 09:11:15 PM »
Sawing to much Sweet Gum.  :)
Offline Bill Gaiche
  • Home built bandsaw, Kioti DK4510. Sthil 211&361
Re: Staying Fixed
« Reply #2 on: January 08, 2014, 09:20:13 PM »
Glad it lasted thru the job in Tx. bg
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Staying Fixed
« Reply #3 on: January 08, 2014, 09:26:32 PM »
Bill, I was thinking about you while I was working on it.  You squirted it plenty of times with ATF.  I don't think that it did any good, but it made us feel better.   ;D
Offline drobertson
Re: Staying Fixed
« Reply #4 on: January 08, 2014, 09:44:03 PM »
You are right, bearings will fail,  and there are replacements ready.  Warm weather, or weather close enough to warm is is good enough to work through.  It seems there is never a perfect season, just  a perfect time, the present.   david
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Staying Fixed
« Reply #5 on: January 08, 2014, 09:53:41 PM »
Yes, stay away from the sweetgum, hackberry, and pecan ( smiley_devil).
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline mesquite buckeye
  • Trees are good- even ones with stickers
Re: Staying Fixed
« Reply #6 on: January 08, 2014, 09:55:59 PM »
Oh yeah!  ;D Up and running again. 8) 8) 8) 8) 8)
Re: Staying Fixed
« Reply #7 on: January 08, 2014, 09:57:18 PM »
If I thought ATF was the cure all..I'd be using it for everything.  :o :o :o
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
Re: Staying Fixed
« Reply #8 on: January 08, 2014, 11:06:57 PM »
How many trips have you taken up and down the rail over that time?
I just shortened the feed chain by two pairs of links and was looking into replacing the chain and sprokets as they are showing wear as well. May well be time to replace bearings as well. Thanks for the post.
Offline Bill Gaiche
Re: Staying Fixed
« Reply #9 on: January 08, 2014, 11:39:52 PM »
You may be right. If no oil got into the bearing at all then it was a waste of time. But it did make me feel better and was hoping it would last in which it did. From the looks of the old one it didn't have many more trips back and forth. Glad you have it repaired. bg
Offline LeeB
Re: Staying Fixed
« Reply #10 on: January 09, 2014, 04:28:05 AM »
Good thing I read the rest of the thread. When I first read the subject, I had to wonder why a man so well seasoned as yourself would need to worry about getting 'fixed'.  :D
Online SwampDonkey
  • Large Tooth
Re: Staying Fixed
« Reply #11 on: January 09, 2014, 04:55:37 AM »
Actually, my thoughts were that MM was now stationary and no more sawing marathons in far off lands. Look out sweetgum, there is now a come up'ins in store. ;D
No amount of belief makes something a fact. James Randi
Offline goose63
Re: Staying Fixed
« Reply #12 on: January 09, 2014, 06:53:16 AM »
Can I ask is hackberry hard on a band mill ? :new_year:
goose
thank you to all the vets
Offline WDH
Re: Staying Fixed
« Reply #13 on: January 09, 2014, 07:16:09 AM »
I find that it saws fine.  Just doesn't want to dry straight.
Re: Staying Fixed
« Reply #14 on: January 09, 2014, 08:58:20 AM »
How do you know?..Jake saws it.  ;D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Staying Fixed
« Reply #15 on: January 09, 2014, 09:06:34 AM »
Bill, in the first picture you can see that there were no rollers in the cage and that the end of the outer race was broken out.
Harvey, yes, the saw head makes many trips back and forth during a day's sawing.  Also the reverse "stopping" is harsh on the entire assembly.  When you release the drum switch a shunt is placed across the powerfeed motor providing instant electromagnetic braking.
Offline pineywoods
Re: Staying Fixed
« Reply #16 on: January 09, 2014, 10:05:54 AM »
Glad it didn't bugger up the shaft. Usually does when that bearing fails. I have 2 of them in my shop that came off LeroyC's super. I build the shaft back up with a wire welder and the turn back to correct size on a lathe.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Staying Fixed
« Reply #17 on: January 09, 2014, 10:25:46 AM »
In Reply #13 in the LINK you will see where the original shaft was cut down big time.  The problem was that the sprocket was also gone so my best option was a replacement from WM.  As I mentioned above, this area gets MUCH use as well as abuse.
Offline Andy White
  • I'm not so new anymore!!
Re: Staying Fixed
« Reply #18 on: January 09, 2014, 10:33:49 AM »
Lynn
I hope that repair will last another 991 thousand board feet of cutting. It will be cool to know a double million bd ft. sawyer!!! Great fix on the mill.     Andy
Learning by day, aching by night, but loving every minute of it!! Running HM126 Woodland Mill, Stihl MS290, Homemade Log Arch, JD 5103/FEL and complete woodshop of American Delta tools.
Offline GAB
Re: Staying Fixed
« Reply #19 on: January 09, 2014, 10:37:54 AM »
Magicman:
Thanks for the heads up.  I do not have a super, however am I right in thinking that the regular LT40 has the same design.  Gerald
Down in the Dumps with my Kohler Engine / Not fixed / FIXED!
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post April 09, 2016, 05:05:10 PM
by petefrom bearswamp
Has anyone fixed a
Started by DPatton on Sawmills and Milling
Last post June 30, 2018, 11:24:09 PM
by OffGrid973
Electrical HELP - FIXED!
Started by Kirk_Allen on Sawmills and Milling
Last post May 02, 2005, 05:14:45 PM
by Furby
wondering if this can be fixed
Started by chrisRBC on Chainsaws
Last post March 20, 2014, 12:21:06 PM
by chrisRBC
