Author Topic: Inboard vs. Outboard Clutch  (Read 1607 times)
Offline brettl
  • I'm new
« on: January 15, 2014, 02:27:17 AM »
I've seen this mentioned several times now. I know what they are when I look at them but not the pros and cons when used for limbing, stumping, etc. I like to know the pros and cons and the reasoning behind them to fully understand this. Thanks
Offline sawguy21
Re: Inboard vs. Outboard Clutch
« Reply #1 on: January 15, 2014, 09:53:40 AM »
I think it's just personal choice and marketing. Each will have so called advantages trumpeted however slight.. Outboard sprocket quicker to change, inboard can drive the oil pump which is simpler and cheaper.
Offline HolmenTree
« Reply #2 on: January 15, 2014, 12:36:50 PM »
Outboard clutches don't transfer heat to the powerhead's crankcase like inboard clutches do. Might explain why the heavy duty pro saws like the Stihl 090, MS200 and the Husqvarna 3120, 395, down to the 338 use it.
Outboard clutches also place the b/c closer towards the center of the saw putting the b/c in a better balanced ergonomic position.
I find their sprocket covers stay clear better when noodle splitting a block of firewood laying on its side.
Down fall is getting the powerhead off a pinched b/c in a trees backcut which I've heard from many woodcutters, but I can't comment on that because I never had to do that before. :D
Offline jdhacker
« Reply #3 on: January 15, 2014, 12:59:38 PM »
I find their sprocket covers stay clear better when noodle splitting a block of firewood with the grain.
stihl 044
STIHL ms 291
Homelite XL12 for 31 years
140 husqvarna
Offline Andyshine77
« Reply #4 on: January 15, 2014, 04:09:02 PM »
Outboard clutches also puts less stress on the crank bearing, do to the fact the drive sprocket is closer to the bearing itself.
Andre.
Offline SawTroll
« Reply #5 on: January 17, 2014, 05:48:07 AM »
 :) Yes to all that - totally agree!  8)
Information collector.
Inboard vs outboard clutch
Started by John Mc on Chainsaws
Last post May 13, 2010, 05:55:32 AM
by Al_Smith
Woodland mills clutch upgrade ??? bigger engine, but what clutch?
Started by mattyo5 on Sawmills and Milling
Last post August 23, 2016, 10:05:04 PM
by larrydown60
Outboard motor
Started by CLL on General Board
Last post June 19, 2010, 07:04:01 PM
by Toolman
Outboard oil in a chainsaw?
Started by retiredmechanic on Chainsaws
Last post January 20, 2020, 10:20:25 PM
by WV Sawmiller
