Author Topic: oil  (Read 756 times)
Offline peterob
oil
« on: January 18, 2014, 09:05:44 PM »
just a question what is everyone running for oil i have a 25hp  kohler  on a lt28  thanks peter
Offline dgdrls
  • Learning the Art of Milling Logs
Re: oil
« Reply #1 on: January 18, 2014, 10:59:44 PM »
I run Full synthetic Castrol  in My Kohler 27 & Napa Filters
Check the Kohler site for weight requirement and spec/rating if you don't have your book(s)
DGDrls
Offline Chuck White
  • Sawing Mobile since 2005
Re: oil
« Reply #2 on: January 19, 2014, 07:12:11 AM »
I use 15W40!
Seems to work well, I also shut down when the weather starts to turn cold and start up again in the Spring!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline bandmiller2
Re: oil
« Reply #3 on: January 19, 2014, 07:50:35 AM »
Once A new engine is broken in on dino oil theirs no reason not to go synthetic, on this sized engine cost is a little factor. Aircooled engines run hot and the extra protection, not to mention cold starts, makes it worthwile. A little 2cyc. synthetic mix added to the gas will help the valves and the engine top end. Good engine management will extend the life of your engine. Frank C.
Offline Bill Gaiche
  • Home built bandsaw, Kioti DK4510. Sthil 211&361
Re: oil
« Reply #4 on: January 19, 2014, 09:16:06 AM »
10w-30 wal mart synthetic. Use this in all my engines except diesels. bg
Offline Dewey
Re: oil
« Reply #5 on: January 19, 2014, 09:42:47 AM »
I run Mobil One 10-30 Napa Filter I have over 6500 hrs on this motor
