Author Topic: Opinion: Band wheel w nothing btw blade and wheel  (Read 4214 times)
Offline chisel
Re: Opinion: Band wheel w nothing btw blade and wh
« Reply #20 on: June 09, 2004, 11:47:15 AM »
Hey Gipper and steveo, I was looking at the members map and there's a few more of us Ky boys than just the three of us. The rest of them must be out running their mill!
Thanks for both of your descriptions of your mill.
steveo, I may take you up on your generous offer. I'd be glad to offer my labor for a few pointers (and the opportunity to take pics of your mill). I have a full ww shop but have never run a bandmill, just seen some run by someone else.
Offline Gipper
« Reply #21 on: June 09, 2004, 10:17:52 PM »
Chisel
Though we are in the same state, there's a lot of miles between us, but like steveo, if you are up this way look me up and we will saw a log or two and talk sawdust for a while. :D (I'm only about 7 hours or so east of you.)  You can see what my bandwheels and roller guides - actually the entire mill - looks like by visiting the Cook website. www.cookssaw.com
Stevo_1  Did you escape all the bad storms in your area last week without any damage?  I was lucky, but some of my neighbors weren't.  Couple of counties around us were hit even harder than we were.  Lot of nice trees came down.  Here the first thing most people think of is firewood.  I was called about one nice Maple, but by the time I got there the best logs had been cut to firewood length. >:(
Offline steveo_1
« Reply #22 on: June 09, 2004, 11:28:08 PM »
   Gipper we had some bad storms come through but we got lucky and only lost a few limbs here and there. My uncle lives a few miles away and he got hit good,him and his neighbors lost some trees,his neighbor lost a carport, it blew out in someones field,no major damage and nobody got hurt.
Im thinking about running an add in the paper every spring to let people know i will clean up those trees to get the logs off of em,too many get chopped up into firewood. >:(
Chisel we can set up a date.Maybe send me a PM we can figure something out.After the 4th would be good for me,i got some stuff needs doing next few weekends.
got wood?
Offline chisel
« Reply #23 on: June 10, 2004, 07:09:09 AM »
Gipper,
I have the Cook's demo video and I have visited their site many times. Which mill do you have? 7 hrs. is a long way to make sawdust, but I'll think about it! Thanks for the offer.
steveo, after the 4th probably works for me. I have a sister in Louisville so it'd be great if I could visit you both in the same day. I'll send you a pm when I get my schedule figured out.
Offline Gipper
« Reply #24 on: June 10, 2004, 08:32:21 PM »
Chisel
I have the Accu-Trac 36 hydraulic mill.
Eddie
Offline MrMoo
  • Do you have a spare log dar
« Reply #25 on: June 14, 2004, 08:00:54 AM »
Kind of late replying to this one.
My Logmaster mill runs crowned steel bandwheels. The tensioning is with a hydraulic system with no spring tension or give. There is a blade scraper just before the guide on the outgoing side. So far nothing seems to have stuck to the blade & gone around the wheel. I suppose you never know though.
Offline chisel
« Reply #26 on: June 14, 2004, 01:45:56 PM »
Quote
MrMoo,
Better late than never!  :D
I'll add a blade scraper to my list of "options" on the mill I have in my head (and soon to be reality?). :)
Thanks for the info.
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #27 on: June 14, 2004, 02:26:41 PM »
  I posted on this thread waaay back. Maybe I should clarify a little. We saw logs that have loose chunks falling off (Pecky Cypress) that CAN get bounced around and HAVE gotten caught between the housing and the blade AND the wheel-tire.
 We have a wire brush-scraper mounted AFTER the fixed blade guide, so, it's possible that the pieces did NOT actually go through the guide, but, bounced around inside the housing and got jammed into the blade and tire.
 Every once in a while, we get a loud thump and see pieces fall out the top of the blade housing that's between the two wheels. Every piece does NOT go out the chute.
Width of your band wheel, width of your blade?
Started by valley ranch on Sawmills and Milling
Last post March 09, 2015, 12:41:02 AM
by valley ranch
Band wheel ?
Started by edsaws on Sawmills and Milling
Last post November 05, 2005, 11:14:04 AM
by D._Frederick
Band wheel belts
Started by Bruno of NH on Sawmills and Milling
Last post April 27, 2017, 07:42:04 PM
by Dave Shepard
band wheel size
Started by fathead on Sawmills and Milling
Last post November 06, 2011, 01:05:07 AM
by fathead
