what was the best most trouble free saw you ever owned
Started by treechopper40, January 23, 2014, 03:15:24 PM
treechopper40
the best saw I ever owned was a 2165 jonsered I baught it new cut 40-50 face cords of firewood a week with it and fell and limed with it on Saturday and sunday that saw ran over 3 years running 7 days a week daylite till dark was never in the shop once the only thing ever replaced was the rewind rope and bars and chains and sprockets the day the it died I was blocking wood on the landing it started making a screeching noise I was bout halfway through the tank of gas it would cut fine but didn't want to idle I knew it was getting tired anyway I ran the rest of the tank of gas out of it grabbed my 372 out of the truck that nite when I left the woods I tried to start it and it was set up tight if they were all that good !!!!!!!!!!!!!
1979 c5d treefarmer 1966 c5b treefarmer prentice g model loader 2 6100 dolmars a 6400 dolmar and a 7910 dolmar 2012 ford f 250 4x4 with a service body and 2 golden retreivers
goose63
I've got a jred2171 had it 14 years now new sprocket is all still runs like new :new_year:
goose
thank you to all the vets
gary courtney
I have several. 024 stihl 1985 model never I repeat never even as much as change a spark plug! has set for as long as 6 years and new fuel put in and fire right up and cut like new!!!  jonsered 670 super same story on it! stihl 042 6 to 7 years fire right up!
Jiles
My second chainsaw to buy new was a Husqvarna 40. Bought it in 1982? cleaned carb a few times and have worn out 5 bars, three rim sprockets and countless chains.
I have never did any other repairs and I used it yesterday. Runs same as new!
Second best, although a little heavy, is my Craftsman (Roper) 3.7 cu.
It has unbelievable torque. Only saw I have ever run that will start the chain, idling with light pressure applied while on log, when it is advanced to full throttle--Try yours, and see what happens.
Satisfy needs before desires
Maine logger88
My 2171 was by far the best saw I've ever had it was my primary saw for almost 3 years it still runs tho I retired it now cause its very tired if my new 562xp lasts that long I'll be quite happy, that is my favorite saw to run it has amazing power for how light it is and awesome throttle response
luvmexfood
Most trouble free power saw was an old Poulan circa 1975. Cant recall the model number. Absolute most trouble free saw-And old hand bow saw that dad made me cut wood with one winter. Pickup truck loads.
Give me a new saw chain and I can find you a rock in a heartbeat.
clww
Stihl 028 Wood Boss purchased new in 1987 or 1988. I have no idea how many cords of firewood.
Many Stihl Saws-16"-60"
18-Wheeler Driver
Stihl 041 30 years without a single glitch (problem/failure)
and now a Stihl MS361 ten years without a single glitch (problem/failure)
weimedog
guess being as old as I am....I have to have a pre history and current offering to this thread.
Pre history?  My Homelite XL925...that I still have and ran last fall & fired right up as I got the gas out of it so it can be yet again retired to my chainsaw rest home...
Current. Hate to say it, Husqvarna 455. So what did I do ?? Sold it and replaced it with a 555. Hope the 555 is as easy to start in the zero degree range, and is as reliable. The guy who has it  uses it to heat his house and it continues to be trouble free.
These 455's may be the Homelite xl-12's of our time.
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
SLawyer Dave
1982 Stihl 024 AV Woodboss.  Saw helped me put myself through college cutting and selling firewood.  Only thing I ever had to replace was the pull cord spring/return.  After 28 years of hard work, it started running really hot, so I finally set it aside.  I'm hoping to get it rebuilt, as I figure it would be a great saw for my 5 and 7 year old grandkids to learn on, (in a few more years).
Al_Smith
Two actually .A PM 610 McCulloch and an S-25 Poulan .I ran the dickens out of both for approx 9 years when I sold firewood .
They both run but due to the fact I have better saws now of days they see little action .
HolmenTree
My 1992 Stihl 066 Arctic Mag. I have thousands of hours on it to date and never had the cylinder off.
I started with a Stihl 032. Guess I'm not as lucky as been there. That was in '82. That was done in about 4-5 years. Moved on to a couple huskys since them days. I use to use my alot,but now just maintain my land and firewood.
This is almost like tractors. I get talking about the problems with mine tractor and some will say,I had my for 15 years and never had any trouble with it.Than I ask how many hours and they say,barely have 1300 on it.  ::)
Fatcougar
My Stihl 026.... I think I bought it in 1997 or so... I have done absoloutly nothing to it other than a new bar, airfilter and spark plug once just for the fun of it. Inside walls of cylinder almost look like new when looking through the exhaust port. Compression is still perfect. 92 octane fuel and Stihl mix with some Stabil. It has never ever failed to start once. Love that saw. ;D
Fatcougar
Stihl 461-R
Stihl 026
New Holland TC30
Rankin 3 point Splitter
martyinmi
024AVS Bought in '85 or so.
As much as I like my old Mac's and Homelites, I gotta say the 024 has been the most reliable.
One boot and fuel line(couple years ago) and a new coil last year. The coil was replaced for just the labor. That year Stihl put a lifetime warranty on the coil!
It is one of my four favorites that I positively WILL NOT loan out to my BIL. Things always seem to break on him and it's never his fault. ::)
No God, No Peace
Know God, Know Peace!
Knute
HolmenTree
Those early Stihl were tough. I had a 034AV and that little saw was tough, 40 below or 110F didn't matter.
But  I do have a 2007 Husky 372XP that may break my 22 yr old Stihl 066 record. That 372 has not so far gave me any trouble what's so ever to date and its been muffler modded and non rev limited module since new.
weimedog
thought about the 365 I bought in 2004 and did a lot of work....but the 455  never had the care, just lived in the barn, rolled around the back of the truck and bucket of the tractor....got ugly but never let me down.
Stihl 031 bought in 1976 never one minutes trouble and still running. Carb has never been rebuilt or adjusted from new. Frank C.
jdhacker
Quote from: treechopper40 on January 23, 2014, 03:15:24 PM
25 cords a week is a lot of firewood  ;)
stihl 044
STIHL ms 291
Homelite XL12 for 31 years
140 husqvarna
chucker
respect nature ! and she will produce for you !!  jonsered 625 670  2159 2171/28"  efco 147 husky 390xp/28" .375... 455r/auto tune 18" .58 gauge
deerslayer
My Stihl 026 purchased new in 1990 is still being used regularly. Has required very little attention. one spark plug, one isolator, an air filter, sprocket and some fuel lines.
Too many chainsaws, not enough wood.
Stihl, Husky, Craftsman, Mac, Homelite, Poulan. Some live here, some just passing through.
mad murdock
PM10-10, was my dad's saw, but we used it logging full time for 3 years.  Prior to the full time logging stint, it was used for firewood, about 20 cds per year, and after we used it full time, it was used for firewooding for years after.  During the logging stint we averaged about 3-4 log truck loads per week, cutting and hiring the skidding and trucking out. Newer saw- my 372 XPW. That is a very dependable saw.
BFay2172
My husky 353 has been the most trouble free saw for me. Been running it hard for 6 years and haven't had any real problems other than one clutch and a couple bars and chains. I have countless hours on the saw and is still runs strong.
OneWithWood
Stihl MS441.  Starts up easy, runs all day.  This saw has been used, abused, and put away wet. Just keeps coming back for more.
One With Wood
