Author Topic: Scored cylinder - please advice  (Read 5879 times)
Offline Coach
« on: January 28, 2014, 05:40:11 PM »
You chainsaw guys, can you advise me if this cylinder needs replacing? I'm really hoping not. It's scored a little just underneath the muffler outlet. It's off a Husky 375k
For some reason the piston had a piece break off.  I've replaced pistons, and taking this one apart it looks like it may have been installed back to front. I could be wrong on that though.
Offline Andyshine77
Re: Scored cylinder - please advice
« Reply #1 on: January 28, 2014, 06:03:57 PM »
What was the location of the ring pin? should have been the intake side of the cylinder, not the exhaust side. It looks like a piece of plating is chipped off on the bottom of the exhaust port, If so I looks like a pretty big chunk and may be a deal breaker. The bottom of the port looks rough as well, but a little blending would likely fix that, the rest of the scuffing is pretty light and should hone right out. Looks like she was running a bit hot and dry, so wherever you end doing with the saw, pressure and vac test after the rebuild.
Andre.
Offline Coach
« Reply #2 on: January 28, 2014, 06:22:05 PM »
Ring pin was on the exhaust side, that's what makes me think it was installed backwards.  Husky wouldn't do that, or?
Yeah, it is the chip I'm asking about. The large pic makes it look worst than it is.
Offline ehp
  • logger/chainsaw hack
« Reply #3 on: January 28, 2014, 06:45:59 PM »
Man she blew up pretty hard , you got a ton of crap in port transfer and ext. ports , combustion chamber as well , you need to polish where that piece is missing real good so the ring does not catch it and your ring pin should of been on the intake side and being a 371 it should of been a single ring  My rule of thumb is after cleaning the cylinder up if I can feel any kind of grooves or anything that my finger nails catch the cylinder is most likely junk , But if you were to have a piece of chrome missing in your cylinder you got the right place to miss it , if it was on the top side of the ext. port that changes things alot . Check your crankshaft over before putting it back together to and make sure none of the crap got into the lower rod bearing or crank bearing , but from what I can see in the picture , yes clean the cylinder up real good and put a piston in it and you should be good to go , that piece missing will not hurt the power of the saw but make sure its polished so the ring does not catch in it
Offline Coach
« Reply #4 on: January 28, 2014, 08:37:19 PM »
Aside from the chip, the cylinder is smooth. Doesn't look to have damage otherwise. I think i'll go with it.
This is the piston. It's off a Husky 371K cutoff saw. (Correction, 375k)
Offline ehp
« Reply #5 on: January 28, 2014, 10:30:32 PM »
where is the piston ring pin  ;D ?  make sure you clean all the junk out before putting it back together
Offline Andyshine77
« Reply #6 on: January 29, 2014, 03:34:00 AM »
Looks like the pin is sitting on the crank lobe. :)
Andre.
Offline Al_Smith
« Reply #7 on: January 29, 2014, 04:14:12 AM »
That does seem odd .Usually the ring gap rides on one side or the other between the intake and the tranfers .
Offline joe_indi
  • The older I get the more I learn
« Reply #8 on: January 29, 2014, 04:26:06 AM »
If you examine the inlet side of the piston on the skirt, probably it will be polished.
Exhaust side piston top as shown in the picture and a polished inlet side skirt indicates (IMHO) that the saw was under a bit of overload. At TDC the piston kind of wriggles under load and too much of this wriggle(my term) and the top gets damaged on the edge. In a twin ring piston the bit of aluminum between the rings snaps off.
Smoothen the edges of that 'crater on the cylinder wall and its good to go, with a new piston.
Joe
Offline ZeroJunk
« Reply #9 on: January 29, 2014, 07:54:01 AM »
When you finish working on the cylinder if there is anything about it that you don't like I would consider one of the aftermarket kits. They may not be OEM quality but for the price it might be better than a jug you don't trust.
Offline bandmiller2
« Reply #10 on: January 29, 2014, 08:09:05 AM »
I'am with Zerojunk your jug is a temporary fix at best get an aftermarket jug and piston and be done with it.  I have had good luck with them and their not that expensive. Frank C.
Offline Andyshine77
« Reply #11 on: January 29, 2014, 03:23:04 PM »
A lot of modern Husky's have the ring gap right in the middle of the intake, especially single ring saws.
Andre.
Offline Andyshine77
« Reply #12 on: January 29, 2014, 03:26:55 PM »
Blended correctly the saw will run fine for a long time, which is better than most of the AF stuff I've dealt with.
Andre.
Offline coxy
« Reply #13 on: January 29, 2014, 04:44:21 PM »
wow cant believe some of you would put that back together that way if I did that it would run for 30 sec and blow up again and brake some thing else  some people have all the luck :D :D :D :D 8)
Offline sharkey
« Reply #14 on: January 29, 2014, 11:31:50 PM »
Maybe if it were my own I would try it, but not for anyone else.
Offline Andyshine77
« Reply #15 on: January 30, 2014, 12:34:37 AM »
The ring doesn't have to seal there, as long as it doesn't catch it shouldn't be a problem. Again the scuffing is very light an will completely hone out.
Experience plays a big role here, myself and others like Al and EHP have made do with much worse. Sometimes parts are no longer available, too expensive and so on.
Andre.
Offline chainsawr
    • The Chainsawr
« Reply #16 on: January 30, 2014, 06:17:44 AM »
I think that chip on the bottom edge of the exhaust port is bad news.  Lot of plating gone there.  Then again, if you clean it up and put an inexpensive aftermarket piston in there, if it blows up again right away you're not exactly out a huge fortune, and it may just work for a while.
It's scary how often we find backwards installed pistons in saws that come in for service  :o
www.chainsawr.com
Over 50,000 parts in stock.
Selling excellent Dolmar chainsaws and power equipment.
High volume Oregon bar and chain dealer.
Offline ZeroJunk
« Reply #17 on: January 30, 2014, 08:17:25 AM »
I suspect they would not. I mean you might suggest it to somebody and honestly believe it would be OK, but if it was yours you would do it right.
Offline Al_Smith
« Reply #18 on: January 30, 2014, 03:57:24 PM »
In my haste of grancing at the picture I failed to realize that in fact the danged thing is in backwards ,duh .In looking at it this morning at work I noticed the exhaust port higher than the transfers then in dawned on my pea brain what had happened .
I dunno if you  can clean up the cylinder and use craytex or something to buff out the missing plating so the ring will bridge over it you night be able to save it .Now I can't help but wonder how in the world the piston got turned around .
Offline JohnG28
« Reply #19 on: January 30, 2014, 06:27:15 PM »
In the first picture it looks like either the piston or the piece that broke off hit the squish band and top of the cylinder also.  :-\
stihl 056 scored cylinder
Started by JohnnyTom on Chainsaws
Last post September 15, 2008, 06:48:57 PM
by dancan
262xp Scored Piston and Cylinder
Started by ickirby on Chainsaws
Last post December 27, 2009, 10:30:54 AM
by Cut4fun
stihl 056 scored piston/cylinder [update]
Started by wood monger on Chainsaws
Last post March 13, 2010, 07:18:25 PM
by Dalden
Scored
Started by sawwhat on Chainsaws
Last post April 01, 2018, 07:44:22 PM
by decableguy2000
