I HATE SAWING WHEN THE GROUND IS WHITE.
Started by Cypress Sam, February 11, 2014, 08:01:27 PM
Cypress Sam
Got more snow on the ground and sawin cypress just don't work as well when the logs are white on top.  I think that I'll just stay in in the morning.
SAM
Sam, think of it as dry band lube, I don't like it ether and your storm is heading our way. Frank C.
Cypress Sam
BandMiller: hats of to you northern guys!  Every year about this time I start thinking about visiting friend in south Mexico!
SAM
lyle niemi
I really doubt that you would like it where I am, think we had about 5 feet of snow so far
Nvfd3052
It was -8f when I started sawing this morning... I can deal with snow but that cold is sumthin else  :(
Woodmizer LT35HDD18 diesel
Stihl ms290
Deere 260 skid loader
01 Chevy 2500hd duramax
And a wife that loves me!
Cypress Sam,how often do you get snow?
bandmiller2,that must be the storm that will hit here Thursday. It will be all snow here. That is good. We can handle the snow part just fine.
Kingcha
I was not happy putting my mill to bed for the winter but since this has been the worst or best winter depending on ones point of view It's a good thing I did.   Not only has it been colder then normal we have had more then 200" of snow this season so far.
I am a skier but I am so over winter.
I hope summer does not take to long to get here.
Matt
a Wood-mizer LT15 10hp Electric, 45hp Kioti tractor, electric smoker, wood-fired brick oven & yes a custom built Solar Kiln
mikeb1079
QuoteI am so over winter.
amen brother.  i don't like to whine but i will now do so.   :D  as an outdoors worker i have to say that this winter (in wisconsin at least) has been absolutely brutal.  i really really want to not be cold anymore.   ::) 8) ::)
homebuilt 16hp mill
drobertson
No doubt, I think the  chicks and tigers have been knocked back enough here!  ready for some greenery!
Cypress Sam
Quote from: thecfarm on February 11, 2014, 09:52:49 PM
Arkansas is a strange place in winter.  I can be 9 degrees on Monday 80 degrees on Wednesday and back to 20 by Friday.  You don't have a chance to acclimate to the temp, and the snow and ice melt causing the ground to get bad.  Then it refreezes and thaws out worse.  This happens all winter.
  Do not think that I am complaining I like the warm breaks in February!!
  Half frozen logs are another story!!
SAM
pineywoods
Sam, I'm fairly sure the frozen log thing is a myth  ::) I'll probably never know for certain, because when the temp get below 40 °, I shut the mill down and go watch the fire in the woodstove  ;D They say that firewood splits better when frozen, don't know about that either. I split mine in april or may.. I'm about 60 miles southwest of Sam, across the state line, we got 2 inches of solid ice. I ain't getting out of the house except to go fetch some more wood from the barn..
Cypress Sam
Piney did you have to fire up the genny this morning.
Ice is the worst!!!!
SAM
Billbob
Yep, ice is no good.  I was sawing some spruce logs yesterday that had 3 inches of ice on one side.  When the blade hit the ice I actually saw a spark fly.  Now I have a dull blade to change.
Woodland Hm126 sawmill, LS 72hp tractor with FEL, homemade log winch, 8ft pulp trailer, Husqvarna 50, Husqvarna 353, homemade wood splitter, 12ft dump trailer, Polaris Sportsman 500 with ATV dump trailer
Kingcha
My last trip "Outback"
http://www.youtube.com/watch?v=LP1K69fezCM
Looking around
http://www.youtube.com/watch?v=Y4siZq5ke2g
Next trip I will have to get one of the mill
Here are some photos earlier in the winter, a lot more snow now.   https://forestryforum.com/gallery/thumbnails.php?album=5456
Corley5
A few years ago we made a trip to Arkansas about this time of year.  Just before we left there'd been 75 degree weather there.  We were sick of winter up here and figured we'd have a nice break with some spring like weather.  We had snow, ice, wind and cold the whole trip.  Biggest snowflakes I've ever seen were in Arkansas  ::) ;D :)  We were glad to get back to Michigan ;D
Seems the weather patterns are changing down south (its always been crappy cold up hear). Its good form to have an auxiliary heat supply be it wood or propane that doesn't require power. A standby genny is handy especially if you have a well. Week supply of food gasoline and diesel. Then hole up til the ice melts. Frank C.
Peter Drouin
Quote from: pineywoods on February 12, 2014, 10:28:10 AM
No myth  :D :D :D :D
A&P saw Mill LLC.
License NH softwood grader.
Bibbyman
It actually cracked the 32º mark for a few hours yesterday afternoon.   We sawed a couple of hours to finish up an order.  Sunshine and no wind made it feel like it was 60º.
It's been so bitter cold for so long the logs may stay frozen for months down in the stack. Some will thaw on the sunny side but be frozen on the bottom side.
It's hard to find anything good to say about winter. The only advantages I can see is that you don't have to check for ticks or watch out for snakes.
Sawing since '94
yukon cornelius
boy am I sick of winter too! its supposed to be better today here in south mo. our 7 day forecast looks like 40s 50s and 60s! it seems we have had snow on the ground since December. where our new house is built we have a much shorter day. when its dark at the house I can walk up to the road and its still bright out. that makes for a short thawing time. im ready to get sawing again. I don't think I have milled a board since December. send that poar vortex back north!!!
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
schakey
Sitting here in Long Island at Best Western watching the snow come down. I could have killed my dispatcher when they sent me here yesterday smiley_furious3! And the worst is to hit yet,I'll be here a day or two. This has been a bad winter for truck drivers also when it real cold it's hard to hook up anything.
Have a good day everyone and keep warm smiley_sun
Think-Dream-Plan-Do
backwoods sawyer
We had snow once back in december since then we have been keeping it up on the mountain :D
The rain has dumped on us, and a few of the 70 calfs needed shots pills and bands.
As you tell they are purty content so not a big chore.
The rain has the rivers on the rise and the ground is soft but
"NO SNOW" 8)
Backwoods Custom Milling Inc.
backwoods sawyer,not much elevation change like that on this side of the US. I know it happens,but I have never seen it up close. seems odd to me. A nice picture.
backwoods sawyer
scully
I have kept my mill plowed out just waiting for a day in the 30's ! I want to saw so bad I can't stand it ! I have a good size walnut log on the loader arms just waiting but I don't want to even start the engine while it's this cold ! I sawed some oak in Dec. for my neighbor and it wasn't bad ,but , I ain't sawing in single didget weather !
I bleed orange  .
scully
I bleed orange  .
