Author Topic: clark 664c  (Read 3487 times)
Offline borecutter
clark 664c
« on: February 24, 2014, 03:59:18 PM »
Please help!!! I recently bought a 664c Clark skidder. The motor is running fine but the drivetrain is slow and lacking power. Even in low gear I can get the tires to stop and the rpm's stay up. I started by changing the fluid, filter and rebuilding the "pressure relief valve". I have replaced the hose from the tranny to the charge pump and charge pump. I checked the filter behind the drain plug and changed fluid and filter again. I am running about 230lbs at idle and 252lbs at 1/4 throttle and up. Tranny temp is fine. Fluids smell fine. The only other thing I can think of is the torque but I really don't want to get into the if it not the problem. Any advice is greatly appreciated.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: clark 664c
« Reply #1 on: February 24, 2014, 04:14:16 PM »
Welcome to the Forum, borecutter. I don't know anything about that machine, but I think the same problem has come up recently. I am sure someone with experience will be along.
Offline rockwall
Re: clark 664c
« Reply #2 on: February 24, 2014, 04:29:11 PM »
I don't think it is anything to do with the tranny. Was it acting fine before this problem happened or are you just getting your new 664 going? I suspect your rpms aren't high enough to kick in the torque converter. I have a 664 B with a 353 and was having the same problem. You think it is the tranny but usually not. I had a detroit mechanic come out and he did a complete tune up but the key was getting the rack set so it would turn up to the proper RPMs. Now I have all the power I use to have.
Offline borecutter
Re: clark 664c
« Reply #3 on: February 24, 2014, 05:59:02 PM »
Thanks for the reply Rockwell. I bought this machine with this issue. I am unfamiliar with the rack. I will do some more homework. I have been around several detroit's before and the engine RPM's seem fine "she screams".
Offline rick f
  • Location: Blueberry land- DownEast Maine ( Columbia Falls)
Re: clark 664c
« Reply #4 on: February 24, 2014, 06:29:00 PM »
Check to see that the lever in between your legs is in the work position not in the travel position. Mine is unhooked so I don't know what the position should be in.
664 clark skidder
1- 562 husky
1- 254xp husky
1 - 268xp husky
5040 kubota farm tractor
Offline treeslayer2003
Re: clark 664c
« Reply #5 on: February 24, 2014, 06:43:58 PM »
just because it sounds like it screams doesn't mean it is maintaining the required rpm under load to keep the converter from stalling. run it into a tree with the foot board out and mash her in low gear, if that shaft under your feet stops turning before the wheels spin then it is the engine tune.
Offline borecutter
Re: clark 664c
« Reply #6 on: February 24, 2014, 08:44:01 PM »
Thanks Rick F. That is interesting. When I put the lever in travel I really cant find a difference. If all that's wrong with it is the linkage I am going to be so happy and not happy at the same time."also the lever is on my left so when you told me to check the lever between my legs I had to look down and smile...the last time I got to use it, it was fine, married 15 years" Treeslayer2003...I haven't tested the instant stop but I have watched that shaft and when it stops the tires stop. Ill try it tomorrow
Offline rockwall
Re: clark 664c
« Reply #7 on: February 24, 2014, 09:05:17 PM »
I agree with Treeslayer.
Offline borecutter
Re: clark 664c
« Reply #8 on: February 24, 2014, 09:12:23 PM »
Thanks Treeslayer, I will try it tomorrow. It seems like the rpms stay up pretty good but maybe just not good enough.
    • My homepage
Re: clark 664c
« Reply #9 on: February 24, 2014, 09:23:08 PM »
A Detroit is up to proper rpm when it rattles your teeth like a teletype machine.  :D
Re: clark 664c
« Reply #10 on: February 24, 2014, 11:30:23 PM »
I bet that lever is unhooked. most are.
if the shaft stops turning, it cannot be the trans.
Offline rockwall
Re: clark 664c
« Reply #11 on: February 25, 2014, 05:39:36 AM »
This is what mine looks like in work mode.
Offline rockwall
Re: clark 664c
« Reply #12 on: February 25, 2014, 05:46:44 AM »
On the second page of Forestry forum is a thread called clark ranger paint job, on the bottom of the first page starts a discussion about his work/travel lever. I think it would be helpful to you.
Offline oldseabee
Re: clark 664c
« Reply #13 on: February 25, 2014, 11:53:17 AM »
664C stall speed: cable, with trans oil at 180 F, full throttle in high range with brakes locked  or machine against abig stump and hydraulics bottomed out at 1800 PSI, 1920-2080 RPM.
Grapple, same set up except Hydraulics at 2000 PSI, 1720-1920 RPM.
Offline rockwall
Re: clark 664c
« Reply #14 on: February 25, 2014, 12:55:11 PM »
here is my work/travel lever
Offline borecutter
Re: clark 664c
« Reply #15 on: February 25, 2014, 01:38:40 PM »
Thank you all so much. Calling around to get someone who knows how to properly tune a Detroit. Makes sense. its smoking pretty good and when you turn it dogs the motor down even more. I didn't realize those converters stalled a suck a high rpm. Ill keep you updated on the progress and pay the advice forward.
Offline rockwall
Re: clark 664c
« Reply #16 on: February 25, 2014, 02:58:41 PM »
Good luck!
Re: clark 664c
« Reply #17 on: February 25, 2014, 03:28:10 PM »
oldseabee, my time has only been with detroit powered machines. is it true that cummins powered machines have a different stall converter?
I ask because I would like to put a cummins where a Detroit is but I wouldn't want to buy a converter.
Offline oldseabee
Re: clark 664c
« Reply #18 on: February 25, 2014, 11:15:25 PM »
664C didn't come with a Cummins, only a 353N Detroit.
666C had a 453N Std or a v-378C Cummins, only with the Swamp Buggy option.
You could fit the Cummins into the 664C, the frames are the same but you would need a larger radiator and different motor mounts, change the throttle linkage, and probably different axles. The Trans. and convertor are the same for both models.
Bear in mind that parts for the 378 are hard to come by. A lot of expense for a little gain.
Re: clark 664c
« Reply #19 on: February 26, 2014, 08:43:35 AM »
mine is a B and if I did it would be a 4 BT. I  have seen 666s with the same axles. I saw some used converters advertised, it said some were for cummins and some for Detroit. maybe they meant what they took um out of?
I have a Detroit powered 666 B swamp buggy but I swapped 28s for the 34s.
Will a 664c Clark Tranny fit a 664b clark ranger skidder?
Started by delimberboy on Forestry and Logging
Last post December 22, 2015, 01:23:05 PM
by oldseabee
Clark 664C
Started by Chrbat33 on Forestry and Logging
Last post March 30, 2017, 09:58:10 AM
by ClarkF66
My new Skidder - new to me. Clark 664C
Started by lshobie on Forestry and Logging
Last post May 29, 2016, 06:06:25 AM
by timberlinetree
Clark 664C Tramsmission
Started by treefarm on Forestry and Logging
Last post September 18, 2019, 09:04:22 AM
by slakwire
