Dynamic Green Products Inc.
Author Topic: Woodmizer alternator issues  (Read 5880 times)
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
Re: Woodmizer alternator issues
« Reply #40 on: September 02, 2014, 10:57:59 PM »
Shortly after buying the mill I added a ground wire from alternator to ground in main box near the battery, also added an aditional positive lead to the battery. This summer I had another alternator go out (fried all components same as last one) had the battery tested and it fell flat on its face. Brass ground was gummed up with ATF and Pine Pitch, so we completed the circit by running a wire from the ground stud in the lower box thru the Agiss track and grounded to the frame.
Offline OlJarhead
    • Dartplayer
« Reply #41 on: May 02, 2016, 09:13:19 AM »
Bumping this thread since I seem to be having alternator issues after just 50 hrs of operation.
Mill quit on me 4 hrs into milling on Saturday (not happy) and after testing it appears to be the alternator.  I'm recharging the battery (it was up to 12.3v last night) which had dropped to 10.9v when the mill quit and will do some testing this afternoon after I call WM (and try not to yell since the mill does only have 50hrs on it)....
I'll report back
Offline Stephen1
    • muskoka Sawmill
« Reply #42 on: May 02, 2016, 09:28:20 AM »
Getting home from out of town tonight, and will work on the mill tomorrow and see if I can find a short somewhere. I am running the 105A alternator. Keeping a spare on hand sounds like an excellent idea. I should see if I can find one in a wrecking yard with the right clocking and rebuild it as a spare.
I don't think there has been an alternator light working on this mill since I bought it used over ten years ago. I have the light that shows that the key is on, but the other one never has worked. I did have to replace the alternator plug a few years back, and I think I left the wire to the light un connected and taped up, since the light didn't work. I'll sort through that again, too, and see what I can find.
I used to do this nearly full time, but in the past few years don't work it that often anymore, and it always seems like I need a battery, maybe an alternator, and probably another $100 thrown at it every time I have to take it on the road. Which makes me want to do that even less, of course...  :-\
I am no expert on Electrical, but I can tell you that alternator light is imperative to the running and charging of the mill. That is the 1st thing I look for when I have an electrical problem, and believe me I have electrical problems. I know now how to use a meter 8) . Get that light fixed 1st.
Offline Bandmill Bandit
« Reply #43 on: May 02, 2016, 10:21:50 AM »
IF no changes since 2007 on the woodmizer mills LT40 and lower;
The alternator is a Delco Remy CS130. You can pick one up at any good wreaking yard and swap your front cover with the one on your current alternator and set your clock position as required on reassembly. Quite a few car/pickups have a 1/4 inch smaller pulley on them IF its a single V groove pulley. I think it has to be pre 92 to have that pulley. The spare I have in my parts box is off of an 89 Chev 4x4 The one on the mill at the moment is off of a 90 GMC 1500 4X4. That spare has been in the box for 3 years since I did all the mods to fix the cooling issues. No problems since. I did install a new battery yesterday which is the 3rd battery since new in 2007 so 2 batteries in 9 years is pretty good id say.
COOLING is the number one issue to deal with and the BELT is the first step in that process. The pulley, I would say is the second.
 There are links above that will take you to a site that supplies an "iceberg" cooling back cover and every other part you could ever need to repair most alternators.
Offline OlJarhead
    • Dartplayer
« Reply #44 on: May 02, 2016, 05:58:46 PM »
Solved my problem.  Alternator is fine, the problem was the exciter wire was disconnected in the control panel....go figure!
Started by richie47 on Sawmills and Milling
Last post January 09, 2007, 07:44:02 AM
by richie47
Woodmizer Alternator
Started by barbender on Sawmills and Milling
Last post August 18, 2020, 09:43:02 PM
by Magicman
Woodmizer lt40 alternator Problem
Started by sawmillhand on Sawmills and Milling
Last post August 09, 2014, 10:32:14 PM
by Lacplesis
Woodmizer alternator current draw ??
Started by jcbrotz on Sawmills and Milling
Last post March 20, 2014, 09:06:30 AM
by sparks
