Chase shingle mill
Started by Ikemonroe, March 05, 2014, 05:48:10 PM
Ikemonroe
this is my first time on this forum, I was hoping you guys could help me. I have a chase shingle mill I recently acquired and am in the process of restoring. what I need to know is does the saw need to be dished to cut properly?. due to the fact I have not been able to find the specific saw for this mill I was wondering how a flat saw would work.
Ike.M
scotthelms
I have a Chase mill with a carbide saw. I had to have my timing gears (rachets) remade. Is you mill a vertical or merry go round style?
Two new members,Ikemonroe and scotthelms welcome to the forum.
someone just told me this was a Chase Mill
It's at Fryeburg Fair each year.
Ikemonroe,what part of Maine are you from?
Ike, not dished per say but a real taper from the cast iron collar to the teeth. Most I have seen were a spring set but some were swaged. How good condition is your saw in and whats the diameter.? The saw I had on my Chase  was 40" hammered for 1000 rpm. How much do you have to rebuild on the mill. The carriage slides on babbit. Frank C.
Ikemonroe
Ike.M
Ikemonroe
Im from the rockport area. I have seen this mill at this fair. its is indeed a chase.
Ike.M
Ikemonroe
The saw thats on it now is 32" id like to find a 40" saw.  when i got the mill the drop tray bracket section of the casting was missing,  im in the process of fabricating a new one. other then that its not in bad condition.all  the babit bearings have been replaced with roller bearings so i dont need to mess with pouring new babbit. ill get some pics on here of my progress soon.
Ike.M
Ike, I just sold my Chase shingle mill to a forum member, had it for many years. It came from Maine used to cut pine for fish boxes. When I spoke of babbit I mean its under the carriage that holds the chunk and travels in and out of the saw. Your right 32" is getting a little small. When I bought my mill the old fella that owned it sent an old sawmill saw down south to be converted, they Blanchard ground a taper from the collar to the teeth and repunched them. I drilled, countersunk and mounted the saw to the collar. My collar was a little out of wind (wobbled) so I took it to be trued on a brake disc lathe. Frank C.
Chuck White
Welcome to the Forestry Forum, Ike and Scott!
~Chuck~  Cooks Cat Claw sharpener and single tooth setter.  2018 Chevy Silverado and 2021 Subaru Ascent.  Recently purchased a 2020 Mahindra Roxor.
scotthelms
Ike, I have a vertical and merry go round mill. The carbide blade for my vertical mill I had made works great. I would be glad to let you have my patten for the rachets I had made. My saw is a straight saw with no taper. My merry go round mill only saws a straight board. I would like to see a taper set up for this mill. If anyone knows where one is please let me know.
Cutting shingles requires HP because its happening fast and the saw is turning fast usally around 1000 rpm. I have done it with a Farmall "C"but not quite enough, JD "B" had the moxie.  farmall H" would be fine or any tractor in that class with a flat pulley. Have cut shingles with steam but its hard with a recip. engine to get the RPM's Tried a gear reduction steam turbine that worked well but tough on steam. Those lusting after a shingle mill be aware it gets boring fast and is dangerous. A lot of old shingle makers have trouble ordering more than two beers. White cedar is premium product red cedar will turn black like white pine if not coated. Frank C.
loggah
I used a case model SC on my shingle mill and it had just about enough power,no extra to spare. I would think 40 H.P. would be about right, but more would be better. ;D
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
Don_Papenburg
Over at the Thresherman's Park in Pontiac  they have a shingle mill with a horizontal saw blade . The log sits ina carriage that drops the log onto the blade . then he turns the log end for end  with each cut .  The taper is set as the log is dropped into the carriage before entering the cut .  A lever that clamps the log is also used to move the carriage into the cut .  It looks safe enough that the shingle sawyer can order  a bunch of beers.  He runs it with a John Deere H  (about 12hp). But then he is cutting slow so he can show the  workings all day for the length of the 4day show.
