Sometimes the internet works
Started by just_sawing, March 07, 2014, 04:32:37 PM
just_sawing
Got a facebook that tooth paste would clean the plastic lense on a headlight. I thought there wouldn't be any difference with my display on my woodmizer. I guess the internet does have some good. I use regular Colgate toor paste.
You can follow me at
www.http://haneyfamilysawmill.com
POSTON WIDEHEAD
Great job. If it's on the internet, it has to be true.  ::)
Ga Mtn Man
Quote from: POSTONLT40HD on March 07, 2014, 04:45:39 PM
I've always suspected that was true and now that I've read in on the internet I know it IS true! 8)
Chuck White
Back in the day of the curved plastic chrystal on watches, we used tooth paste to polish the plastic and smooth any scratches.
Toothpaste being mildly abrasive is what does it!
And now their minty fresh too, so many expensive products today are just common old chemicals in a fancy container. Frank C.
Coon
TurtleWax and a good buffing wheel now that you have taken care of the initial scratches will do you wonders.  I have done this to countless vehicle headlights that were neglected for years and they come out like new.  The key is a little wax goes a long ways just take your time and use very light pressure. Several coats of wax and buffing may be needed.  It also works on snowmobile and motorcycle goggles and visors.  Other cheaper waxes don't work nearly as well as TurtleWax.
chopperdr47
They won't let you put anything on the internet if its not true.
If ya ain't got what ya need, use what ya got
marcusthgault
I know that to be true because Albert Einstein said anything on the internet had to be true.
Honest.
Theres nathing as wouldnay werk better fer been teighn asundry furst.
LeeB
And of course you can believe anything an Irishman tells you.  :D
marcusthgault
Yah What! ye tell me Uncle Albert was Irish ;D, an I nivver knew!
LeeB
