Author Topic: black walnut.....  (Read 2676 times)
Offline JamieT
black walnut.....
« on: March 10, 2014, 01:10:04 PM »
 Ok fellas, ive sawed up the walnut that I had laying around. It was dry, cut really nice. Had a guy wanting 300 bf. Told him I was out and would have to harvest a tree. He said that was fine, I explained to him that it will be very green. Again, he didn't seem to mind. So Sunday afternoon I took down a really nice walnut. While I was sawing it down, I noticed it was dripping. A LOT! Enough to soak the stump. Limbed out a 12ft section and took it home. Guy came out and looked it over and was excited about it. So here is my question.... being that wet am I more likely to ruin those boards? Or should I just cut and stack? And secondly, can I sticker with pine? Thanks for any helpful info....JT
Learned just about everything I know, from the greatest man ive ever known. My father! Everything else was self taught thru the school of HARD KNOCKS ;-)
Offline ayerwood
Re: black walnut.....
« Reply #1 on: March 10, 2014, 01:41:18 PM »
Just a few thoughts I had.  In your situation, and it happens more often than I would think, customers are fine with green lumber when it is understood ahead of time.  All of my lumber is green and very "wet" when it is milled.  I properly stack and dry with no problem.  I have even sent stickers, free of charge, with the customer so they can have the lumber right away and dry it at their place.  If this customer wants the lumber now, give him stickers and direction(timeline) for proper stacking to dry.  If no rush for customer to take possession, stack and dry as you normally would.  However, when green lumber is ok with the customer, I lean toward sending the lumber with stickers with them right away.  Then you don't have to worry about the customer changing their mind and not coming back later with your $$$.  Its happened a few times.
Offline GeneWengert-WoodDoc
« Reply #2 on: March 10, 2014, 04:15:24 PM »
Was the exudation only at the butt end, or did you see it further up the tree?
Offline JamieT
« Reply #3 on: March 10, 2014, 07:57:39 PM »
Thanks ayers, never thought of that! And Gene, it was only at the bottom. Your thoughts?
Offline mesquite buckeye
  • Trees are good- even ones with stickers
« Reply #4 on: March 10, 2014, 08:31:47 PM »
Good old wetwood.
I have cut trees that squirt like a hose when you hit it. ;D
Offline Don_Papenburg
  • I need money
« Reply #5 on: March 10, 2014, 10:08:31 PM »
Time to be making walnut syrup!!!
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #6 on: March 11, 2014, 12:04:17 AM »
Walnut dries nice.  Hard to mess it up if you have good air flow.
Like Red Oaks Lumber says, AIR FLOW, AIR FLOW, AIR FLOW.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #7 on: March 11, 2014, 08:24:00 AM »
R.O.is AIR FLOW…..HOT AIR FLOW.  :D
Online WDH
« Reply #8 on: March 11, 2014, 12:07:01 PM »
 popcorn_smiley
Offline JamieT
« Reply #9 on: March 12, 2014, 07:58:16 AM »
I have a building with a spot that I can stack wood in. No sunlight, think I.should stack in there and plug up a fan?
Offline chopperdr47
  • Frick 0, 190hp Propane Minneapolis Moline
« Reply #10 on: March 12, 2014, 08:53:02 AM »
I had 600 bf of pecan stickered up in my basement for nearly 2 years before it was really dry. It being 2" thick was part of the reason. If you have a place to stack it outside with a plastic barrier between the stack and the ground and then tin on top might get it quicker. Thats what Im doing until I can do something different.
If ya ain't got what ya need, use what ya got
Offline JamieT
« Reply #11 on: March 13, 2014, 08:51:32 AM »
Chopper, you just put a tarp down and stack on top of it? Have plenty of tin to cover with. Its the tin im using for the shed roof
« Reply #12 on: March 13, 2014, 09:14:49 AM »
The tree gets a bacterial infection that comes in through the roots and moves up the stem at about 1" a year.  It creates very high MCs, an unpleasant odor, and weakens the wood from an enzyme that the bacteria make.  There is methane gas produced.  This effect causes what you observed when you cut the tree.  When drying the wood, infected wood, being weaker, is prone to checking and splitting.
Offline JamieT
Re: black walnut..... Few pics.....
« Reply #13 on: March 13, 2014, 09:23:04 PM »
  Started on the walnut today. Im gonna attempt to post a few pics. Bare with me. The first pic is of my dad running the mill. He couldn't stand just watching! The next few are just the color starting to come out  it was dark when i quit  but ended up with a 12x16x11 cant.   Ill post a few more later.
Online WDH
« Reply #14 on: March 13, 2014, 09:25:18 PM »
I love the way fresh milled walnut smells.
Offline JamieT
« Reply #15 on: March 13, 2014, 09:45:10 PM »
Im partial to the cedar...
Offline 5quarter
    • Blue Harbor Refinishing
« Reply #16 on: March 13, 2014, 10:19:22 PM »
There's a handsome log. That's gonna give up some great lumber! Walnut dries pretty easy, but is prone to end splitting. seal up the ends and you'll be golden.  ;) Nice woods in the background, BTW
Offline Left Coast Chris
  • A day sawing is always a special day
« Reply #17 on: March 13, 2014, 11:36:34 PM »
Jamie, just curious, what HP and brand is your tractor?  My MF 135 is getting tired and I need to modernize.   Also, do you like it and how has the durability been?   I like the low profile and stout appearance.
It is amazing how important support equipment is. :)
Great looking log!
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
« Reply #18 on: March 14, 2014, 11:15:44 PM »
Walnut is purdy. ;D
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #19 on: March 14, 2014, 11:29:42 PM »
Was milling up a batch of WRC along with a short fat black walnut that was on the mill when the control panel started shuttering and the head slowed way down and it was a slow crawl to the end of the cut. Hit six small cables that had been wrapped around the tree many moons ago, the short block got shortened, found another wrap of the cable, shorted the chunk up some more. :-\
I like cedar ;D
Black Walnut
Started by Trax on Sawmills and Milling
Last post September 06, 2006, 06:09:26 PM
by metalspinner
Black Walnut(again)
Started by EZ on Sawmills and Milling
Last post August 31, 2003, 03:32:09 PM
by EZ
Black Walnut
Started by woodbe on Sawmills and Milling
Last post September 19, 2011, 04:33:16 PM
by shelbycharger400
What's the best way to saw Black Walnut?
Started by Gilman on Sawmills and Milling
Last post August 23, 2004, 10:41:43 PM
by beenthere
