Author Topic: Cottonwood for flooring?  (Read 2991 times)
Offline shelbycharger400
  • m14/04 0
« on: March 17, 2014, 09:11:40 PM »
Has anyone here used cottonwood for flooring?  Im still trying to determine what im going to do with a 5 foot dia monster Straight for 15 feet.  Talking to another guy with a sawmill other side of town here , bout a mile from where im cutting said qtr it and he can mill it.  He got me thinking.    I dropped a 24 in dia today,   and have a 30 something to do  will get about 3 saw logs out of each one as well as  the rest of the pines and red cedars still their.     I have an addition to do for baby Jack.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Cottonwood for flooring?
« Reply #1 on: March 17, 2014, 09:19:13 PM »
It is rather soft for a hardwood and will dent easily.  Also, does not have a very good nail holding capacity.  I believe that flooring is not one of its better uses.
Offline 5quarter
    • Blue Harbor Refinishing
« Reply #2 on: March 18, 2014, 01:18:48 AM »
Member Kansas milled Cottonwood on a daily basis for pallet stock, which is about its only good use. I talked with him about drying cottonwood for other uses, like framing lumber; he suggested using it green and let it dry in place. old barns around here used a lot of cottonwood. I would not use it for any kind of flooring, even though there is probably someone out there who has, and has somehow managed to get good results.  ;)
edit: I should have mentioned that I hates cottonwood almost as much as Magicman hates sweetgum.
Offline woodyone.john
« Reply #3 on: March 18, 2014, 02:45:39 AM »
I have used it for truck decking,lasted about 5 years. was good in terms of its resilience to chucking heavy angular stuff on it .when the deck got wet again the 'bruise 'popped out and look almost new again.Probably make a reasonable workshop floor,it doesn't splinter like some of the harder woods.
Saw millers are just carpenters with bigger bits of wood
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #4 on: March 18, 2014, 06:29:12 AM »
Offline GeneWengert-WoodDoc
« Reply #5 on: March 18, 2014, 07:47:53 AM »
A large percentage of wood caskets are made from cottonwood.  Although soft, when dry, and if free from collapse, it is a wood that machines and glues fairly well.  Note that there are several species of cottonwood, some of which are poor.  Eastern cottonwood Populus deltoides is indeed widely used.
Offline Larry
« Reply #6 on: March 18, 2014, 10:14:46 AM »
Yes, Kansas milled a lot of cottonwood for framing lumber.  A lot of barns built out of it.
I like to mill it 4/4 for utility lumber.  I've used it for all kinds of shelving.  When it is ran through a planer some will fuzz up.  The amount varies from little to maybe at most 25% in my experience.
Offline LeeB
« Reply #7 on: March 18, 2014, 10:26:40 AM »
Quarter and rift sawn seems to help on the fuzz issue.
  • m14/04 0
« Reply #8 on: March 18, 2014, 12:40:35 PM »
I was thinking of making garage cabinets as well.  Ill have a lot left over, not shure what to do with it,    cottonwood dosnt sell very well
Offline GAB
« Reply #9 on: March 18, 2014, 01:37:08 PM »
shelbycharger400:
I was told by a sawmiller in IN that he sold some of it fresh sawn to an Amish fellow who claims that horses will not chew on cottonwood.  He wanted it for his horse stalls.  Note: I have no personal experience with cottonwood.  Gerald
Offline red oaks lumber
« Reply #10 on: March 18, 2014, 05:56:38 PM »
shelby
 we are in about the same region of the country, i think cottonwood will work fairly well for flooring. after its dry the wood seems sorta hard,  harder than a pine would be for sure. its a fairly stable wood in our area ,moves alittle with the seasons but, all in all i think you will be happy using it.
« Reply #11 on: March 18, 2014, 06:33:37 PM »
Fuzz, which is due to tension wood, is controlled by using sanding sealer or glue sizing and then sanding the stiffened fibers with sharp (fresh) sandpaper.
  • m14/04 0
« Reply #12 on: March 18, 2014, 07:55:09 PM »
Red oaks,     I'm not concerned with it moving,   the thin strip
 maple moves every season and its been in the house from 1960. I'm just wondering how it will hold up in a bedroom,   not high traffic area
« Reply #13 on: March 18, 2014, 08:11:43 PM »
i think it should hold up real well in your bedroom
Offline Bandmill Bandit
« Reply #14 on: March 18, 2014, 08:21:47 PM »
dont think I would put down cotton wood( the stuff called that around here) on a floor how ever I  have cut about 12000 BF of aspen that went down on floors in the last 3 years and have an order for another 3800 SqFt to cut in the next 2 weeks. It is a very good looking floor and seems to wear very well.
The first order I got was for a home that had Aspen flooring in the living and dinning room from original 1974 build. The complete 2011 reno on the house included new Aspen flooring through out on 3200 SqFt. The couple that built and reno'ed  the house are long time friends since high school.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4. 2018 F150
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built myself
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #15 on: March 18, 2014, 11:03:42 PM »
I had a customer use soft west red cedar for flooring in a bed room. He just turned big feet for the bed and dresser. If it is a boys room it may well get dented and show some wear  ;D
Offline ND rancher
  • I'm Learning!
« Reply #16 on: March 20, 2014, 03:33:20 PM »
I have a guy who wants random length boards 4" wide for his workshop wall.He is planing it smooth and nailing it to existing wall. Very pertly when planed.I turned a few small bowls and they are nice.Makes good framing lumber when covered from elements.
TimberKing B-20.  Have been bitten by the bug! Loving life !
cottonwood?
Started by cringo on General Board
Last post February 20, 2003, 04:39:25 AM
by Minnesota_boy
question
Why is cottonwood ignored?
Started by jrokusek on Sawmills and Milling
Last post June 07, 2007, 04:01:03 PM
by LeeB
cottonwood anyone?
Started by sandsawmill14 on Sawmills and Milling
Last post February 12, 2016, 07:17:12 AM
by mart
Is this to big to cut down.....cottonwood!
Started by ArnoldFarms on Sawmills and Milling
Last post March 23, 2014, 05:23:15 PM
by GAB
