Author Topic: bunks  (Read 924 times)
Offline hogdogman
    • Hogdogman
bunks
« on: March 18, 2014, 01:38:43 PM »
I am building some new tracks for the hm126 and am wondering about the optimum spacing between the bunks
Offline dboyt
  • Log On!
Re: bunks
« Reply #1 on: March 18, 2014, 02:16:02 PM »
Distance between bunks depends a lot on the kind of milling you do, and how solid your track is.  Standard logging is even foot lengths, plus 4'. The Norwood mill I run has 4' spacing between bunks, which works well, especially since I can move the clamps to accommodate the odd sizes by moving the clamps.
Offline hogdogman
    • Hogdogman
Re: bunks
« Reply #2 on: March 18, 2014, 09:10:23 PM »
Thanks, the original deck has under 4' but i was leaning that way. I just want to do it within reason, thanks again.
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
Re: bunks
« Reply #3 on: March 18, 2014, 10:52:52 PM »
When you get to the lower cuts, if the ends are not suported it will droop, and when milling short logs having an extra bunk helps suport it, the more bunks the better but give yourself room for clamping and working on the mill as well.
Offline scrout
Re: bunks
« Reply #4 on: March 19, 2014, 12:22:24 PM »
My mill is set up a little different, but I made my bunks are movable, they just slide in the frame.
Looking at the WH126, you could extend out the mounting flanges on one bunk about 6-8 inches each side, then that bunk could just sit there without being bolted down.  Then you can move it where necessary depending on your log.
trip bunks
Started by treechopper40 on Forestry and Logging
Last post January 25, 2014, 07:04:52 PM
by Rick Alger
Log bunks that fold
Started by rjwoelk on General Board
Last post March 15, 2019, 11:31:10 PM
by rjwoelk
removable log bunks
Started by Joey Grimes on Sawmills and Milling
Last post February 22, 2016, 01:43:30 AM
by starmac
Trip Bunks
Started by Wallys World on General Board
Last post June 17, 2008, 06:12:40 AM
by york
