Author Topic: advice needed  (Read 590 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
advice needed
« on: March 22, 2014, 10:17:16 PM »
I am building two structures. One is a carport and the other is a lean to building. I plan on using timber frame joinery as much as possible with this build. Neither of the buildings will be enclosed on any sides. Looking for advice on what species to use for the post. I had originally planned on Red Oak but my research has pushed me in the other direction. The beams will be sawed on my LT 35 and here is a list of the logs I have right now that I can use for post.
Poplar.ERC,Red Oak,White Oak,Hemlock, Which would be the right species for my post? The post will be covered with a roof on both structures,
Thanks in advance,
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: advice needed
« Reply #1 on: March 23, 2014, 09:44:15 AM »
White oak for posts would be the most rot resistant, I believe.
But I don't have much experience with Poplar or ERC.
Jim Rogers
Offline 123maxbars
Re: advice needed
« Reply #2 on: March 23, 2014, 11:42:55 AM »
Thanks Jim, I will go with my white oak an hopefully a sealer ever now and then will insure longevity.
outofthewoods
Youtube page
Out of the
Offline VictorH
Re: advice needed
« Reply #3 on: March 23, 2014, 02:33:24 PM »
The ERC would be very rot resistant for the posts as well.  Not sure weather they would make good beams strength-wise.  Around here most of the ERC is very knotty which would make cutting the joints more challenging.
Advice needed
Started by Faron on General Board
Last post January 04, 2008, 08:52:19 AM
by fstedy
question
Tax advice needed
Started by Larry on Forestry and Logging
Last post July 10, 2011, 10:04:31 PM
by shelbycharger400
Advice needed!
Started by brownHRFC on Job Opportunities
Last post June 14, 2011, 11:09:15 PM
by JHBC
a little advice and some help needed please
Started by SFires on General Woodworking
Last post July 07, 2013, 08:54:31 AM
by Magicman
