Author Topic: learning to saw  (Read 2921 times)
Offline steamsawyer
  • I'm Antique
Re: learning to saw
« Reply #20 on: March 29, 2014, 05:16:27 PM »
Hey edger,
That's what I thought, I just forgot to put one of these,  ":D" at the end of the warranty comment. I was only goofing around.  :laugh:....  If you run a sawmill you will have those setbacks once in a while. I hope your setbacks are never quite so serious and costly as that.
I love those guys at BH Payne. When you deal with them they make you feel like a friend as well as a business associate.
Alan
J. A. Vance circular sawmill, 52" blade, powered by a 70 HP 9 1/2 x 10 James Leffel portable steam engine.
Inside this tired old mans body is just a little boy that wants to go out and play.
Great minds think alike.....  Does your butt itch too?
Alan Rudd
Steam Punk Extraordinaire.
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: learning to saw
« Reply #21 on: March 29, 2014, 05:23:17 PM »
Menominee Saw is a great source and ships saws and supplies all over the country and helps any forum member that gives them a call. And to top that, they are a long time supporter of the Forestry Forum and make this place possible.
Payne has inquired about sponsoring in the past, but never went past that.
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
Re: learning to saw
« Reply #22 on: March 29, 2014, 11:29:06 PM »
Well if you are itching to get back in the hot seat after a wreck like that, you got the bug alright.
Working night shift everything humming along when a 24 log missed the end dogging carriage in the hand off from the charger/scanner. As the carriage headed thru the block chippers the log was entering and exiting thru the saw shack, tipping up the sawyers chair that was welded down, and dumping him out the door. He was a seasoned sawyer but it took some time to talk him back into the hot seat.
Sounds like you have a good teacher, and you have the sawdust bug, listen, learn and always put safety first around these mills.
Offline saw man john
Re: learning to saw
« Reply #23 on: August 17, 2014, 12:54:52 PM »
can someone make me a cheat sheet, i saw 6x8,7x9 ties,lumber 11/8,11/4,2,and 4x6's
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: learning to saw
« Reply #24 on: August 17, 2014, 02:26:43 PM »
Hello saw man john, and Welcome to the Forestry Forum.  Not giving you a short answer and not knowing the accuracy that you require, but you really need to develop you own cheat sheet using your sawmill and the blades that you normally use.
That being said, since I do not have Accuset I had to develop a cheat sheet to give me various "starting points" on the sawmill scale for the different dimensions that I saw.  That way SetWorks will accurately drop down for each cut and the remaining cant/board will be the correct target thickness.  I input the number corresponding to my blade thickness/set, but I have also learned to set up on some of them "dead on" and others to "fudge up/down".  For that reason, my sheet probably would not work for someone else on another sawmill.
Other sawyer's mileage may differ and they may offer other solutions.
Re: learning to saw
« Reply #25 on: August 17, 2014, 03:05:57 PM »
ok thanks,im running a 60 inch circular saw just dont know how to make chart.
Re: learning to saw
« Reply #26 on: August 17, 2014, 03:19:05 PM »
good starting point would be measuring your accual kerf thickness, make a few start cuts in the end of a log keep them fairly shallow (1"-2") and take several measurments. now you have the distance between boards.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: learning to saw
« Reply #27 on: August 17, 2014, 05:17:17 PM »
Your question and my response is why adding your sawmill information to your profile is so useful.  The experienced sawyers can address the question as it pertains to that particular sawmill.  My response was of absolutely no value to you.  Adding your location also helps.   :)
edit:  In re-reading, this sounded critical which was not my intent.  I was just pointing out the value of your profile information to others as they attempt to respond to questions.
Re: learning to saw
« Reply #28 on: August 24, 2014, 11:40:45 AM »
I just needed a chart on 8/4 lumber,,i got 4/4 and ties down pretty good I start at 11 1/4 down to 7 ,were fixing to start cutting cypress logs into 2 1/8 inch we don't cut a lot of  8/4
Offline Jeff
  • Fearless Leader
Re: learning to saw
« Reply #29 on: August 28, 2014, 08:18:50 AM »
If you are going to be a sawyer, you really need to get this stuff in your head. Every log is different, so your cuts will need to be determined on the fly. If you use a cheat sheet because you are cutting 8/4 are you going to through the lesser dimensions away on the outside of your log? You will if you depend on a cheat sheet. You need to learn how to add and subtract those fractions on the fly. Plus add your kerfs in there as well.
Learning ones age! old now
Started by crowhill on General Board
Last post August 11, 2019, 03:52:08 AM
by Ianab
We're learning
Started by Ed_K on Sawmills and Milling
Last post July 20, 2003, 06:43:35 PM
by Ed_K
Learning....
Started by OlJarhead on Sawmills and Milling
Last post April 13, 2016, 05:24:22 PM
by Magicman
Learning as I go
Started by 123maxbars on Sawmills and Milling
Last post October 24, 2012, 11:49:53 PM
by WDH
