Dynamic Green Products Inc.
Author Topic: Slab Loss  (Read 1381 times)
Offline woodweasel
  • I'm No Longer New, But Green As A Gord
Slab Loss
« on: April 21, 2014, 04:39:45 PM »
How many inches will I lose off a 20" log just squaring up the cant? (Average off all 4 sides) Read this before someplace! Never really measured it while I was sawing? ???
Offline WellandportRob
Re: Slab Loss
« Reply #1 on: April 21, 2014, 04:47:13 PM »
With a perfectly straight log you will pull a 16" X 16" out of it.
2016 Wood-Mizer LT40HG 35 , Alaskan MKIII 60", Chev Duramax, Anderson logging trailer. Lucas DSM 23-19.
Offline dgdrls
  • Learning the Art of Milling Logs
Re: Slab Loss
« Reply #2 on: April 21, 2014, 05:33:41 PM »
Use the tool box lower left below sponsors choose "Log size for cants"option.
DGDrls
Offline landscraper
  • LT4H0DD47. Dyna SC14. Hudson Stake Sharpener.
Re: Slab Loss
« Reply #3 on: April 21, 2014, 05:44:31 PM »
I use .70*diameter as the rule of thumb for largest square (cant) that can be inscribed in a circle (log) and I estimate *down* from there.  Oval logs, sapwood, sweep, etc. cut into that yield a lot.  That's from the small end diameter too.   Realistically it is a good bit less, and varies by log.  Depends on if you edge jacket wood as to whether that is "loss" or not.  Neat cuts on a perfect round log with a 2' inside bark diameter would yield a 3.5" slab off each side and leave a 17" cant.  Rarely happens that way.  On your 20" log, .7 =14", so there would 3" loss to slab on each side.
Firewood is energy independence on a personal scale.
Offline woodweasel
Re: Slab Loss
« Reply #4 on: April 21, 2014, 08:44:22 PM »
I thought 4'' per side was close but wasnt for sure. thanks
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Slab Loss
« Reply #5 on: April 21, 2014, 08:48:23 PM »
There is at least one more narrower board inside each of those 4" slabs.   ;D
Offline drobertson
Re: Slab Loss
« Reply #6 on: April 21, 2014, 08:50:09 PM »
I ran into this today, on some cedar logs. He(customer) said wack em'.  I ended up with some nice 1" before it happened.  He said," glad you are doing my pine next"  the tool box will give you a great starting point, just plan on you outside lumber before you get there.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Slab Loss
« Reply #7 on: April 21, 2014, 08:52:17 PM »
Divide by 1.4141. You will get a 14.14" cant from a 20" diameter log.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Slab Loss
« Reply #8 on: April 21, 2014, 09:01:13 PM »
  Remember that any sweep in the log will affect what size cant can be sawed.  Also, just squaring it up looses the side lumber that I mentioned in Reply #5 so it need not all be a loss.
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
Re: Slab Loss
« Reply #9 on: April 21, 2014, 09:45:55 PM »
18"x18 with some wain. How much wain allowace is there? ;)
A 1" slab on the small end will give a square cant with about a 6" open face. Tapper and alignment minimize the effects of mild sweep.
If the target is 1x6 or 2x6 a six inch open face is all that is needed and a 1" slab will give you a six inch face.
Cant imagine off loading slabs that are 3" thick on the small end :) 3" slabs makes the firewood pile out grow the lumber pile  :o
    • My homepage
Re: Slab Loss
« Reply #10 on: April 21, 2014, 09:47:27 PM »
That's a lot of wane!
Offline ET
  • Still Learning!
Re: Slab Loss
« Reply #11 on: April 21, 2014, 10:02:06 PM »
With us Lucas millers that little piece of premium, under the bark, o defect wood, although small, is recovered. Takes a few more cuts but as long as the log does not have, wane, it will provide a very nice stick for sure.
Lucas 1030, Slabber attachment, Husky 550XP, Ford 555B hoe, Blaze King Ultra, Vermeer chipper, 70 acres with 40 acres Woods.
Offline woodmills1
  • the truth shall set you free
Re: Slab Loss
« Reply #12 on: April 22, 2014, 07:51:04 PM »
radical 2 or 1.414 is the number, and ifin ya try for a 16 by 16 it is gonna have a lotta bark.
Offline stumpy
  • I feel alot more like I do now than I did before
    • Rustic-woodfurniture/Stumpy's Wood Works
Re: Slab Loss
« Reply #13 on: April 23, 2014, 08:14:15 AM »
If you look up in extras, there's a tool box with a calculator for determining log diameter for a given cant size.
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Offline shelbycharger400
  • m14/04 0
Re: Slab Loss
« Reply #14 on: April 23, 2014, 12:44:47 PM »
Good logs,   24 or so big end cut live edge at 2 inch on a band mill,   two logs netted me 13 nice slabs,  two bench slabs and I left the dunnage
typical slab thickness, and practical slab lengths?
Started by forrestM on Sawmills and Milling
Last post December 30, 2018, 11:06:00 AM
by Bruno of NH
making a 5" slab into a 3" slab
Started by spencerhenry on Sawmills and Milling
Last post July 29, 2011, 09:18:53 PM
by Warren
MD. Mourns the loss of Wye Oak
Started by Gordon on General Board
Last post June 17, 2002, 07:36:24 PM
by Ron Scott
Kerf loss
Started by jim king on Sawmills and Milling
Last post June 13, 2010, 01:43:28 AM
by slohand
