Dynamic Green Products Inc.
Author Topic: LT15 Wide, LT70 Wide, where's the Wide Edger?  (Read 2105 times)
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« on: April 26, 2014, 06:56:30 PM »
My LT40 cuts 28" wide, but my ED26 only has a 25" opening. Even if the flitch will fit, it only cuts 15" wide boards. It's time for a Wide Edger. It needs about a 40" opening to accommodate a 34" flitch, and still have room to line up the cut. I have to edge a lot of lumber on the mill because it won't fit in the edger.
Offline GAB
Re: LT15 Wide, LT70 Wide, where's the Wide Edger?
« Reply #1 on: April 26, 2014, 07:38:37 PM »
That new edger is probably still on the drawing board.
Gerald
W-M LT40HDD34 w/6' ext & SLR, JD 420, JD 950w/loader and Woods backhoe, V3507 Fransguard winch, Cordwood Saw, 18' flat bed trailer, and other toys.
Offline tule peak timber
  • The Wizard of Crap
    • tule peak timber
« Reply #2 on: April 26, 2014, 07:49:11 PM »
Dave , look into a new or used SLR (straight line rip ) saw. You will need three phase power, and it is necessary to make two passes to catch both edges but it works for me.... cut any width you want.  Rob
Online stavebuyer
« Reply #3 on: April 27, 2014, 05:12:17 AM »
Cooks...
Offline customsawyer
    • The Custom Sawyer
« Reply #4 on: April 27, 2014, 12:21:32 PM »
WM makes one but it is green and about $35,000.   ;)
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
    • My homepage
« Reply #5 on: April 27, 2014, 01:08:26 PM »
The E430, or whatever they are calling it these days? Yes, that would be ideal, especially the fact that both blades move.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #6 on: March 23, 2018, 05:35:19 AM »
#gravedug
Boy, back in my day..
Offline PA_Walnut
« Reply #7 on: March 23, 2018, 06:16:03 AM »
Love my Baker edger, but frankly when I am sawing big slabs on my 40Wide, I'd rather edge them there to lessen the weight when handling...oh, my aching back!  :-\
Generally speaking, I also leave the BIG stuff live edged and allow the straight-lining choices to be made after drying, in order to squeeze every last 1/8" outta it!  :D
LT40HD Wide 35HP Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #8 on: March 23, 2018, 08:11:37 AM »
   Forget the wide edger - I want a planer that will plane about 3' or so. ;D
    • The Custom Sawyer
« Reply #9 on: March 23, 2018, 08:44:11 AM »
I just bought knifes for my 24" planer. No thanks on buying them for a 36" planer.
Offline Southside
    • White Oak Meadows
« Reply #10 on: March 25, 2018, 11:04:52 PM »
Riehl in Pennsylvania makes a wide one upon request.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #11 on: March 25, 2018, 11:53:41 PM »
I believe Riehl makes one without special order that opens up wide enough to take the 28" wide flitch or slab but I think the widest board it will cut is 20" or so. It also has a max thickness of 3" which is more than the orange edger.
1992 LT40HD
question
what mill to buy? lt15 wide or lt40 wide
Started by markymark on Sawmills and Milling
Last post January 28, 2019, 07:58:32 AM
by stanmillnc
Wide plank flooring...how wide can I go?
Started by lshobie on Sawmills and Milling
Last post January 13, 2016, 08:34:59 PM
by Rob in NC
LT70 wide head DCS Electric
Started by Cypress Man on Sawmills and Milling
Last post January 05, 2014, 06:48:54 PM
by JFarmer
Wide head LT70 Wood-Mizer
Started by Bibbyman on Sawmills and Milling
Last post June 07, 2013, 09:27:40 AM
by terrifictimbersllc
