best way to air dry Arbutus (Madrone)
Started by Kasba, April 27, 2014, 11:11:27 PM
Kasba
has anyone had any luck air drying Arbutus (Madrone)? If so what is the best approach or am I wasting my time. I boil my bowl blanks but not sure about slabs.
Timbery M285 25hp, Husqvarna 570 auto tune, Alaskan sawmill, Nova 1624 wood lathe, Dogo Argentino
Den Socling
I have only limited experience with Madrone in vac kilns. What I had was gnarly and wanted to move in every direction. I would think that air drying would require a lot of sticks and weight on top.
GeneWengert-WoodDoc
Kasba
thank you for suggestions Gene and Den, I will give them a try.
redbeard
Kasba the big Madrone trees are the best. The smaller juvenile ones with the green sap wood are tough to air dry. I have had real good luck with the big ones. Nice Burgundy color. Even the dead or spalted trees are awesome.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Kasba
thank you Redbird I appreciate the pictures as it shows how big the trunks need to be.
5quarter
Hey Redbird...either you're just a little fellow, or that is one big, bad*$$ chainsaw.  ;) ;D ;D
Blue Harbor Refinishing
redbeard
That's little Redbeard he was posing for the pic. I don't let him use my big saw! I wish I could be 24 again.
redbeard
Yes that's Mt. Baker. Probably 50 miles away as crow flies. Takes about 90 min to make it to ski lifts  driving.
