well, I started on the kiln finally.
Started by hackberry jake, May 20, 2014, 02:23:42 PM
hackberry jake
A friend of mine came down this morning and we worked on the kiln some more. Got another wall up. I ran out of boat dock foam... now I'm gunna have to figure out how to insulate the back, top, and doors. Guess I will just go with how wdh did it with batt insulation and foam board.
pine
What size loads (BF) are you looking at putting in there?  Which Nyle unit are you considering?
Looking good so far.  Still need to start mine.
hackberry jake
Im thinkin itll hold around 800bf of 4/4. Yeah. I'm going to build a kiln cart. Load up the cart and then roll it into the kiln and shut the doors. Thats why its so tall. It comes out about ground level where I will be stacking lumber on the cart. I was considering the l-53 but I believe I will try a homebrew instead. It cant be that hard right?
You might check craigslist and look for used poultry house insulation.  Its 1 1/2" thick 4' X 16' (or longer) sheets.
hackberry jake
I have been leary about starting the back wall or roof because I didnt know what insulation I was going to be using. I needed to know what joist spacing to use. Well, I picked up 100 12x12x19 styrofoam blocks off of craigslist today. So the joist spacing will be 12". And ill need to cut a lot of 12" blocks to 8" thick.
JB Griffin
Looking good Jake, let us know what you do about the home brew dehumid unit, still thinkin bout buildin a kiln my self.
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
hackberry jake
I see a whack of styrofoam blocks  :).
hackberry jake
The roof and back wall haven't been insulated yet. I just threw some tin on the top temporarily until all this rain lets up. And I still have doors to build...
bedway
Looking great Jake, man i wish i had the energy you do. ;D Im gonna find me a lamp and rub it and wish i was 40 again with a healthy heart. :D
hackberry jake
I see less moldy, mildewed pine in your future  ;D.
hackberry jake
Some more progress pictures.
I remember Poston saying sweet gum makes pretty good siding, I cut the tree down, milled it, and screwed it up all within a few hrs. I have always wanted to try board and batten siding. This is the first time I have ever screwed up dripping boards too.
LeeB
I can't tell, is the door insulated?
hackberry jake
The door has 7" of styrofoam and two 1/2" plywood skins making it 8" thick. Heres a pic before I put the last skin on.
LeeB
I figured surely it did. I just couldn't tell from the picture.
Den Socling
I'm sorry but I find solar kilns as exciting as snails.  :D I pulled a load of fresh-off-the-saw 8/4 White Oak today. 7.5% in 10 days with no apparent degrade. That's exciting!
hackberry jake
That was the main deciding factor for me to go the way of electric. I should be able to dry lumber fairly quickly and year around.
Den Socling
I stacked that 8/4 White Oak today. I only had a few pieces in with 4/4 to see how it would react. It was dry but had too many surface checks. I should have kept the humidity higher. But the 4/4 was picture perfect. White Oak will dry from fresh to 7% in less than 10 days. Too bad a solar kiln schedule can't do it without the vacuum. BTW the 5" thick stuff was around 12% and had a lot of cracks but it was boxed heart. This is really getting off topic but the wood is for a 1949 dump truck somebody is restoring.
