Author Topic: Wild Canada Plum (native)  (Read 9537 times)
Offline SwampDonkey
  • Forester
  • Large Tooth
Re: Wild Canada Plum (native)
« Reply #20 on: April 05, 2009, 11:07:53 AM »
Seems a fungus has begun fruiting on my Stanley plum in the yard. Actually, looks like two different species of fungus by the looks of the shelf it's sending out the tree lenticels. On close inspection the bark looks green, but I found a couple holes the size of your finger and the wood inside is rotten. This fungal growth is almost from the ground up to 6 feet. Guess I gotta cut it down this spring. I first thought it was sapsucker pecks, but went out and sure enough decay fungus of some sort. Wasn't there last fall.  ::)
Move'n on.
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #21 on: April 05, 2009, 11:12:53 AM »
I found out what hits the leaves once in awhile to.
Pear Slug. It's actually a sawfly larva and is slimy like a slug in larval stage. Posted link in case someone might have it on their tree.
Move'n on.
Offline maanma
« Reply #22 on: July 25, 2012, 02:51:52 AM »
Is there available knowledge using Prunus americana var. nigra (P. nigra Wild Canada plum) as baseroot for other Prunus to get cold tolerance?
P. domestica's (common plum) in Finland, Europe can hardly seldom tolerate USDA 4 regions. P. nigra could extend this line up to USDA 2 regions for P. domestica, P. cerasifera and few other not so common species.
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #23 on: July 25, 2012, 03:03:10 AM »
You might have to check USDA for that.
This spring I was by an old cemetery and along the wooded edge was a grove of Canada plum in blossom. I know where I'm headed in September. ;D
Move'n on.
Offline maanma
« Reply #24 on: July 25, 2012, 03:20:52 AM »
Would love to do same too, but do so I'd need 100 seeds and 15 years.  8)
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #25 on: September 04, 2016, 04:47:02 PM »
Picked some wild Canada plum yesterday and mother washed them. Going to try some jelly.  smiley_bouncing_pinky food6
Move'n on.
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #26 on: September 05, 2016, 12:45:10 PM »
Jelly along with a sample.  ;D 8)
A sample for your pleasure. :D
Move'n on.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #27 on: September 05, 2016, 01:27:36 PM »
That is some pretty jelly.  Looks like it has already been sampled.   :)
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #28 on: September 05, 2016, 01:31:29 PM »
Mmm....yup!  :D
Move'n on.
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #29 on: September 05, 2016, 05:20:59 PM »
The benefits of being the jelly maker. You get to heavily sample what doesn't fit in the jar.
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #30 on: September 05, 2016, 05:35:20 PM »
I never made it, but I sampled.  I added some to a dish of real black cherry ice cream to. :D :D We have 2 cups of  juice left that we will be putting in with the cranberry juice for jelly.  8)  ;D
Move'n on.
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #31 on: May 22, 2020, 05:36:17 PM »
This little clump (of three) wild Canada Plum I planted 3 years ago. One of the three is flowering for the first time. This bush is 4 feet tall, and they grow really fast. I read that the flowers last a long time and a good cross pollinator for other plums. But they will self pollinate to. There was some black knot on some stems when I got it, and I cured that with WD-40. Yep, not a knot on it now. None.
Move'n on.
Cedar-apple rust and wild native fruit bearers...
Started by chain on Tree, Plant and Wood I.D.
Last post November 28, 2010, 08:08:37 PM
by SwampDonkey
Plum thickets
Started by sandhills on FOOD! FOOD! FOOD!
Last post August 29, 2010, 01:41:10 AM
by LeeB
Plum pathetic
Started by Beavertooth on Sawmills and Milling
Last post September 25, 2018, 03:53:46 PM
by WV Sawmiller
plum thickets---where are they?
Started by Banjo picker on Ask The Forester
Last post June 19, 2010, 08:29:10 AM
by Banjo picker
