Author Topic: Sharpening bandsaw blades on my radial arm saw  (Read 8643 times)
Offline Kcwoodbutcher
  • Startin' to get the hang of it
Re: Sharpening bandsaw blades on my radial arm saw
« Reply #40 on: June 05, 2014, 09:09:12 PM »
Finally getting around to posting pics of the cam lock.
The construction is simple. The movable block has an oversized hole which the bolt goes through, it is not tight . The block is held captive between the two pieces of 7/8" bar stock. The cam is simply a piece of bar stock with the hole drilled off center with a handle welded on. You can put a lot of pressure on the blade with little effort. Using this setup I've eve taken a fine tooth blade for my vertical bandsaw and converted it to a coarse tooth blade (don't recommend this,way too much trouble).
My job is to do everything nobody else felt like doing today
Offline 36 coupe
« Reply #41 on: June 06, 2014, 05:44:32 AM »
It was too heavy. If you grind too heavy the blade will bow from the heat and will have a less than straight edge. First try at it though. Next time I dull them out I will definately use a lighter grind.
My planer knife grinder has a pressure screw every 2.5 inches.That keeps the knife straight while grinding.Takes longer to light grind but results are better.
Offline 36 coupe
« Reply #42 on: June 06, 2014, 05:53:55 AM »
I had read about sharpening bandsaws on a radial arm saw on here so I decided to give it a try. I ordered a grinding stone wide enough to get the whole profile in one pass. An extra 4x6 with a groove cut in it holds the band. And I put together an indexer with random parts I found in the shop.
Here's a pic just before I started shaping the stone:
And here's the stone pretty close to ready:
And here's a video putting a blade in it and sharpening a few teeth.
It seems to work well and only takes a few minutes to do one blade. I haven't decided if I'm going to put some kind of shield between me and the stone or just always stand to the side when I start it.
I have found many grinding wheels that are out of balance.Not out of round but out of balance.Wheels like this will have a lot of vibration at 3450 rpm.I use a mower knife balancer  to check all wheels .
Offline WillWarner
  • Woodland Mills HM 126
« Reply #43 on: June 10, 2014, 05:43:39 PM »
where did you get your tools for shaping the grinding stone and how long does it take to form the stone profile?
Ephesians 2:8-10
« Reply #44 on: June 10, 2014, 08:18:22 PM »
You use a diamond dressing tool. It's just a small diamond brazed on the end of a metal rod. I got mine at ENCO. They are not very expensive.
Offline red
  • we will never forget
« Reply #45 on: January 03, 2016, 08:59:10 PM »
Has there been any new ideas ?
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #46 on: January 03, 2016, 11:37:18 PM »
First I've seen this and I like it.
I do all my sharpening on bandsaw blads with my dremel.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline OffGrid973
  • Off Grid
« Reply #47 on: November 04, 2019, 11:43:58 PM »
Didnt see any replies to the ...stand in the middle... so just wanted to say Bad Idea.
I gave away my radial when it caught a piece and took off (old school model) and after that I grabbed a new sliding chop saw instead (which has limits).
Be safe, but great build, very impressive.
Your Fellow Woodworker,
- Off Grid
Offline luap
  • Not as good as I once was
« Reply #48 on: November 06, 2019, 04:07:17 PM »
Before digital readout technology any time you were using a milling machine or lathe and you wanted to move the table or carriage a precise amount a magnetic base with a dial indicator was setup and used. You could do the same with your radial saw sharpener to control your depth setting.
Offline bwstout
« Reply #49 on: November 06, 2019, 05:13:52 PM »
I use a radial arm saw, I bought one of the CBN wheels from the sponsor here on FF that match my blades and added a mist cooler on and I just match the wheel to the blade and use the depth of the saw and eye when it makes a few sparks start and adjust as I go. Sometime I make two rounds at the same depth so for no glitches band cut as good as new.
home built mill
sharpening bandsaw blades for others
Started by Gere Flewelling on Sawmills and Milling
Last post July 15, 2020, 04:16:20 PM
by Chuck White
Sharpening .055 x 1 1/4 bandsaw blades
Started by Cypress Man on Sawmills and Milling
Last post October 19, 2006, 10:24:05 PM
by Bibbyman
Bandsaw blades... stock up and/or learn manual sharpening...
Started by texican on Sawmills and Milling
Last post February 04, 2011, 12:22:46 AM
by texican
Looking for Planer Blades and Bandsaw Blade Sharpening Info
Started by cloair on Sawmills and Milling
Last post January 02, 2008, 10:52:06 AM
by jpgreen
