Dynamic Green Products Inc.
Author Topic: LT40 drive belt jumped over, only half of belt on pulley.  (Read 1180 times)
Offline Delawhere Jack
  • I ought to know better.....
« on: June 08, 2014, 05:36:53 PM »
I pulled all the covers off my mill this afternoon for painting and noticed that my drive belt had jumped forward. It's a twin V belt, and only half of it was engaging the pulleys. Any thoughts on why this may have happened? I put a straight edge on the edge of the pulley and sighted up towards the pulley on the motor. It appears that it may be very slightly out of alignment. Viewing the band position on the driven band wheel seems to confirm this, but it is very slight. (I will adjust it.)
I don't know when the belt moved, but shows wear from rubbing against the bracket that holds the lift chain idler sprocket.
In any case, I'll be ordering a bunch of little items from WM tomorrow, mostly due to posts I've read here on the FF in the last few days.  ::) I've got a big job coming up 150 miles away the end of next week, better safe than broke down.
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
Re: LT40 drive belt jumped over, only half of belt on pulley.
« Reply #1 on: June 08, 2014, 06:55:45 PM »
I've had that happen to me before as well. Normally it is because your brake strap is too loose and it's letting the engine drop down too much.
Or is it your turn buckle is too short?
Well, it's one or the other. You need to adjust them so that there isn't a lot of play in your drive belt. But beware that there are lots of adjustments to make once you change one thing you're going to need to re-adjust them all.
For example if you increase how high the turn buckle holds up your engine then the brake strap has to be tightened. If you move the engine up your throttle cable may be too tight and break when you pull down the clutch lever. So you may have to make it longer. Setting the engine high idle speed then becomes a necessity.
These things are all connected and change one and you have to adjust them all to get it back to working correctly. It isn't hard if you do it in the right sequence.
I don't know if I have told you the right sequence or not.
You're going to have to call WM and ask them which order to do what in. And write it down as I should have when I called them and asked them.
Or maybe someone here will tell you which order to adjust these things in so that you do it right.
Good luck.
Jim Rogers
Offline drobertson
« Reply #2 on: June 08, 2014, 07:01:31 PM »
Never seen it, but it sounds like Jim is on the right track.  Might check some of the bushings on the engine mounts, and even the drive pulley bearings,  not a lot of clearance in there,
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: June 08, 2014, 07:34:50 PM »
Mine has done that, but only once.
I put it back in both grooves and it's been running right every since.
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
« Reply #4 on: June 08, 2014, 09:17:05 PM »
Thanks Jim, I'll check the brake adjustment. I had replaced the hiem joints on the end of the turnbuckle a while back, and lengthened the turnbuckle not long ago.
Looks like I'll be in the phone with WM for a while tomorrow.
Offline pineywoods
« Reply #5 on: June 09, 2014, 12:30:22 PM »
Yeah, brake band adjustment.  If you run out of adjustment range, a piece of old 2 inch wide leather belt glued to the old friction lining will restore the adjustment range. Mine was done years ago, no idea how long that fix will last..
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #6 on: June 09, 2014, 12:54:58 PM »
Sighting a pully leaves a lot of room for variance ??? may want to get a straight edge ON the pullies just to confirm the alignment.
A worn streched belt will tend to jump groves more then a new belt.
Offline woodmills1
  • the truth shall set you free
« Reply #7 on: June 10, 2014, 08:20:25 PM »
common
Flat Belt Drive Pulley Needed
Started by Joe Lallande on Sawmills and Milling
Last post July 21, 2009, 12:22:54 PM
by Ironwood
Belt drive from engine to blade pulley
Started by Grower on Sawmills and Milling
Last post January 08, 2010, 05:50:27 PM
by eamassey
Need diesel info and looking for 10X10" flat belt pulley or 16-30" v belt pulley
Started by Trapper John on Sawmills and Milling
Last post July 07, 2016, 09:03:16 PM
by SCSawyer
WM LT40 Drive belt replacement
Started by GeorgeK on Sawmills and Milling
Last post November 19, 2014, 11:57:20 AM
by prittgers
