Author Topic: WM Resaw attachment  (Read 992 times)
Offline John S
WM Resaw attachment
« on: June 17, 2014, 05:56:18 PM »
Has anyone here used the resaw attachment?  I have an LT40 hydraulic.  A customer just called, he wants some 2in. cherry resawed to in for some Shaker boxes he is making.  He will then plane them to 3/8 in.
I am not seriously looking to spend $2500 at this time, but was wondering if anyone on FF has experience with it. It can also cut lapped siding and shingles apparently.  Thanks
2018 LT40HDG38 Wide
Online PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
Re: WM Resaw attachment
« Reply #1 on: June 17, 2014, 06:51:58 PM »
Sounds like you want to build an Arky Resaw Jig
 http://www.forestryforum.com/board/index.php/topic,38180.msg550131.html#msg550131
Seems like it'd work fine to do what you want to do and be a lot cheaper...
Offline GAB
« Reply #2 on: June 17, 2014, 07:23:41 PM »
John:
Are you sure about the dimensions you mentioned?
I have sawed some cherry for Shaker boxes and the customer wanted 5/32" for the sides and 5/16" for the tops and bottoms.
As an FYI the resaws attachement and the SLR are two different accessories.
I have an SLR which I used to cut shakes and can be used to cut sideing.  I do not have a resaws attachment and I do not know if you can cut siding or shakes with one of those.
Yes sawing 5/32" thick with a 3/32" kerf make a lot of sawdust.
Gerald
Offline customsawyer
    • The Custom Sawyer
« Reply #3 on: June 18, 2014, 03:27:05 AM »
I have the resaw attachment and it does a decent job. I would not want to do resawing on a regular basis with it but for what I bought it for it does fine. You can do lap siding with it, all you have to do is tilt the bed and you will be making two pieces at a time.
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
Online woodyone.john
« Reply #4 on: June 18, 2014, 05:12:39 AM »
If the job pays for the 30 odd minutes to set it up and put away then it does a really good job.I have used mine to turn cants into weather boards, cut shingles,[same as weather boards but much thinner and then docked to length], and recently to cut 6mm [1/4"] for a laminated serpentine hand rail. Mine came with the WM when i bought it 2nd hand. I dont think I would pay too much to buy one as an extra unless you got a lot of resaw jobs to do.
cheers john
Saw millers are just carpenters with bigger bits of wood
Offline GAB
« Reply #5 on: June 18, 2014, 09:44:55 AM »
customsawyer & woodyone.john:
Thanks for the info on how you folks saw siding using a resaws accessory.
Gerald
Offline Gadrock
  • I'm new! But older than many trees!
« Reply #6 on: June 18, 2014, 09:49:47 AM »
What type blades might one consider when doing a resaw job?
How about hard dry wood vs non-dried wood?
What about the quality of the saw tracks?
Carry on
LT40 G18,   bent Cresent wrench,   broken timing light
Prentice 280 loader, Prentice 2432 skidder, Deere 643J fellerbuncher, Deere 648H skidder, Deere 650H Dozer
« Reply #7 on: June 18, 2014, 03:53:34 PM »
Because I sharpen and reset my own blades I only keep 1 profile and that is WM 10 degree 1 1/2  doublehards and a couple of stellite tipped.The double hards saw almost every thing I saw and if they dont [and thats rare] then stellite does.
Looking for a RS2 Resaw Attachment
Started by boonesyard on For Sale
Last post November 19, 2019, 12:02:47 PM
by thechknhwk
Resaw attachment
Started by rs1626 on Sawmills and Milling
Last post May 14, 2010, 12:28:10 PM
by rs1626
Woodmizer resaw attachment
Started by Okrafarmer on For Sale
Last post August 06, 2013, 09:37:38 PM
by Okrafarmer
WoodMizer resaw attachment
Started by D6c on Sawmills and Milling
Last post January 11, 2018, 01:46:38 PM
by D6c
