Author Topic: Processor Build, Home Made Firewood Processor  (Read 34275 times)
Offline Higgo
  • Processor Builder
Re: Processor Build, Home Made Firewood Processor
« Reply #100 on: March 21, 2016, 10:20:59 PM »
Good idea Lopet. I'll get some 12x12 square stock and weld it around the roller to give it some 'tread'!
Offline North River Energy
« Reply #101 on: March 22, 2016, 07:30:43 AM »
If you're adding some tooth to the roll, consider shaping it some to center the logs as they feed.
Keep up the good work.
Offline Higgo
  • Processor Builder
« Reply #102 on: November 17, 2016, 09:13:22 PM »
Sorry for the lack of updates lately, progress has somewhat stalled due to time constraints! I seem to always have a lot of engineering work and little spare time and resources to spend on the project. Anyway, about to make a start on some hydraulic work in the coming weeks... spare time permitting!
Offline gaproperty
  • Location: Back and forth between Nova Scotia and NewBrunswick Canada
  • From Riches to Rags.
    • Riches to Rags
« Reply #103 on: December 18, 2016, 08:15:52 PM »
Man there is some awesome builds.  I have a welder and if I get time I will try to build one myself. Until then I am doing things manually but use my kubota for hauling and moving wood.  Darn snow has put a damper on my operations these days but still at it.  You can look at my operations at http://www.youtube.com/c/LostCaper
Ray
lostcaper.ca
Offline Tony01
« Reply #104 on: July 09, 2017, 05:56:03 AM »
Hi guys newbie to the forum but been selling and cutting firewood for 5 years time to build a processor of my own as cant afford the $60 000 au for a basic processor in my gallery are the  pics of the motor and saw i will be using for the build set up on a trailer i am yet to build still getting all components together before the build begins  BTW i cant post my pics to this post as they are in jpg form and the post dont allow that to post
Offline lopet
  • Do not climb any higher your comportable falling !
« Reply #105 on: July 09, 2017, 09:41:01 PM »
Welcome to the forum.
What's your saw off ?
Always curious  to see other home made models.
It looks like Higgo had a pretty good start but somehow lost steam. :)
Offline Tony01
« Reply #106 on: July 10, 2017, 06:57:27 AM »
Hultdins Super Saw 550 S    its a grabble saw
Offline Higgo
  • Processor Builder
« Reply #107 on: September 14, 2018, 07:41:43 AM »
Hi guys,
A short update from a few months ago. @lopet you're right! I did lose some steam (albeit compounded by some extremly slow suppliers of a critical part!)
So...
I finally received a gearbox component that I ordered on at the very start of May 2017 and received.... wait for it.... in February 2018!
Basically a splitter shaft for the NP205 transfer case I'm using (splits the driveshafts for the pump and wheels)
Without going into to much other detail I also had some pretty significant "life milestones" I got out of the way!
However, I'm hoping I'll have some time toward the end of this year to do the final works on the machine.
**Pro tip**
Despite wanting to give up and fearing loosing my money on the parts I had ordered I stuck it out and eventually received them. I ignored advice from other forums about the manufacturer because they were the only person offering the parts. In hindsight I should have listened.... none the less I now have the parts I need to complete the pump drive!
A post on assembling the driveshaft splitter box is coming up!
Heres a couple of pics of the parts:
A pic of the shaft itself (boot for size comparison - yes I know it needs replacing!):
Lets hope these parts go together.... 8)
Offline TeaW
« Reply #108 on: September 15, 2018, 07:14:26 AM »
Glad to see you are still at it !
TeaW
Offline mike_belben
  • Pulp Friction
« Reply #109 on: September 15, 2018, 10:43:45 AM »
Nice build.
Revelation 3:20
Offline hedgerow
« Reply #110 on: September 17, 2018, 08:52:41 PM »
Higgo
Good to see you back hope that transfer case works like you want it to.
Home made Firewood Processor
Started by DR_Buck on General Board
Last post October 10, 2008, 11:29:39 PM
by DR_Buck
Home made firewood processor idea's
Started by Max sawdust on Drying and Processing
Last post August 15, 2006, 09:57:07 AM
by OneWithWood
New firewood processor build
Started by mjeselskis on Firewood and Wood Heating
Last post September 13, 2017, 01:07:53 PM
by Stinny
Firewood processor build
Started by muddstopper on Firewood and Wood Heating
Last post July 08, 2012, 06:10:37 PM
by muddstopper
