Dynamic Green Products Inc.
Author Topic: Back supports  (Read 2188 times)
Offline rooster 58
  • GRIZ, the sawmill mgr.
Back supports
« on: June 22, 2014, 01:17:58 PM »
        Well I was doing well. I have used the '70 for a little over a year without hitting the back supports with the blade.
     And I still haven't. But yesterday, while sawing some hemlock, I "shined" the top of the front one with the blade ;D
Offline goose63
Re: Back supports
« Reply #1 on: June 22, 2014, 01:23:24 PM »
Keep wax on it and it will stay shiny  :D
goose
thank you to all the vets
Offline Sixacresand
Re: Back supports
« Reply #2 on: June 22, 2014, 01:29:59 PM »
We all do it.  With esperience I do it do it less often, but it still happens.  The hardest part, and time consuming, is getting the blade out of the log once it is dulled.
Off your bottom and on your feet, out the shade and back in the heat! Back to work boys!
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Back supports
« Reply #3 on: June 22, 2014, 02:04:36 PM »
It just dulled and took the set out of the lower teeth.  Just flip it over... :D  And by the way, "shined" counts as a hit in my book.  ;D  Welcome to the infamous club.  :P
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Back supports
« Reply #4 on: June 22, 2014, 03:58:29 PM »
Magicman, what about shined, but not dulled? :D I had my second mill hit a couple of months ago and caught the top of the roller bolt on the backstop. I'm pretty sure I hit it, (heard something strange as I went by it) but it did not dull the band. 8)
Offline scully
  • Orange Mills Matter
Re: Back supports
« Reply #5 on: June 22, 2014, 07:25:36 PM »
I've shined and crashed hard ! It's all good !
I bleed orange  .
Offline drobertson
Re: Back supports
« Reply #6 on: June 22, 2014, 07:29:34 PM »
getting greedy with the backs is a good way of hitting them.  But will admit! even today, got so close, after getting off the strip, man it was close!  it happens, and will continue to get your attention,
Offline bandmiller2
Re: Back supports
« Reply #7 on: June 22, 2014, 08:04:27 PM »
There are two kinds of sawyers the ones that have hit a backstop and the ones that lie about it, I'am no liar.  Frank C.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Back supports
« Reply #8 on: June 22, 2014, 08:47:10 PM »
Don't forget the log clamp.  Sometimes the factory puts too much paint on them too.   ;D
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Back supports
« Reply #9 on: June 22, 2014, 09:56:06 PM »
Yep, if they wouldn't put it on so thick, I wouldn't have to thin it down.. ;D
YH
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  Dont burn the cookies.
Offline Don_Papenburg
  • I need money
Re: Back supports
« Reply #10 on: June 22, 2014, 10:08:35 PM »
You guys in the Shiners club ,have them little cars  ?  could you be available for our 4th of July parade?
Offline thecfarm
Re: Back supports
« Reply #11 on: June 22, 2014, 10:15:12 PM »
Ayup,I'm available July 4th,  :D  But I was edging and was sawing 6 inches and for some dumb reason thought 4 would be better. It was better for about 3 feet.  ::)  No reason to hit mine now. Mine are manaul and go straight up and down. I have inches marked on them. But when someone thinks a 4 inch board is better than a 6 inch board.....................
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
Re: Back supports
« Reply #12 on: June 23, 2014, 12:46:46 AM »
Got to say Little Jo has been sawing for over a year and knock on wood she has not hit the mill yet ;) she lets me make those cuts ::)
The other day she had a near miss cleaned the pile of sawdust off the clamp at full speed cutting 2x6, we had set a good pace in the morning and kept it up all day sawing over 50 small logs in seven hours.
Offline rooster 58
Re: Back supports
« Reply #13 on: June 23, 2014, 06:45:20 AM »
     Magicman, I agree. A hit is a hit. I was able to saw another half dozen or so loogs after that. Until I hit a big gnarly one with alot of knots. Hemlock knots are mean critters, especially in these 2 yr. old logs ;)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Back supports
« Reply #14 on: June 23, 2014, 07:34:37 AM »
I prolly should not say this but it has been years since I hit the sawmill,  :-X but leaving the toe board up.....not so long.  :-\
Offline John S
Re: Back supports
« Reply #15 on: June 23, 2014, 10:48:53 AM »
I did it again on my first job this year in April, just a shine, but definitely a hit.  MM, I am also guilty of making Paul Bunyan sized door stops by forgetting to lower a toe board roller.
2018 LT40HDG38 Wide
Offline drobertson
Re: Back supports
« Reply #16 on: June 23, 2014, 06:05:08 PM »
Toe rollers! this has to be another thread! ;D  they will eat your lunch,  ;D  speed has always been a killer ;D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Back supports
« Reply #17 on: June 23, 2014, 07:29:01 PM »
I had my off bearers cringing today.  I knew that I had ~2" above the clamp and was taking 1".    Neither of them realized that I knew where I was so they were waving to get me stopped.   :D
Of course I did stop out of respect for their concern.  Off bearers that care and pay attention are seldom found.
Offline bandmiller2
Re: Back supports
« Reply #18 on: June 23, 2014, 08:33:00 PM »
My band will clear 12" with the backstops up, before I go lower I always glance at the lever on the front of the mill to be sure their down. Frank C.
Offline Delawhere Jack
  • I ought to know better.....
Re: Back supports
« Reply #19 on: June 23, 2014, 10:01:48 PM »
Off bearers have spared me the embarrassment of striking metal twice. Funny thing is both times they were really young, 15-16 year olds. I'll gladly work with them any time.  ;)
Side supports
Started by D6c on Sawmills and Milling
Last post July 24, 2018, 09:14:01 PM
by Chuck White
beam overhanging two supports
Started by swmn on Timber Framing/Log construction
Last post June 30, 2020, 03:05:10 AM
by swmn
LT40 Side Supports
Last post January 28, 2020, 09:06:18 AM
by DR_Buck
Designing log dogs/supports
Started by Timberline on Sawmills and Milling
Last post August 24, 2016, 05:27:31 AM
by kelLOGg
