Author Topic: wood treatment spray question  (Read 1082 times)
Offline yukon cornelius
« on: August 03, 2014, 11:45:46 PM »
ok don't yell at me, I know its been over a million times....I need to know a recipe and where to get the stuff. can I use just borax and water?  where we live has pretty limited shopping options without going to "the big city"
working with hardwoods and eastern red cedar. the problem is mainly the cedar. bugs in the sapwood.
thanks
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Offline Left Coast Chris
  • A day sawing is always a special day
Re: wood treatment spray question
« Reply #1 on: August 04, 2014, 12:37:15 AM »
I just bought a 5 gal pail of Timbor at Do My Own Pest Control.  Free shipping.  Came in 5 days normal snail mail.
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
Offline scsmith42
    • Whispering Pines Farm
« Reply #2 on: August 04, 2014, 02:14:22 PM »
I buy my Timbor off of e-bay and it ships in via UPS.  About $87.00 for a 25 lb pail.
WDH uses Solubor, but I have not been able to source it locally so I go the Timbor route instead.
Tom's 3638D Baker band mill
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: August 04, 2014, 08:34:02 PM »
Go to a place that sells fertilizer to farmers and ask them to get you some solubor.  About $50 for 50 pounds.  Mix 1 pound to a gallon of water.
« Reply #4 on: August 04, 2014, 09:31:18 PM »
do I just spray it on liberally as in saturating the surface? how far does a gallon go? is it dangerous for kids or pets? thanks for the help so far!
Offline WDH
« Reply #5 on: August 05, 2014, 07:22:13 AM »
Safe for kids and pets.  A gallon will spray about 250 BF.  Yes, spray it liberally until the surface is totally wet.
« Reply #6 on: August 05, 2014, 09:11:05 AM »
great! thanks a lot!
Offline WDH
« Reply #7 on: August 05, 2014, 10:06:34 PM »
Sorry, I messed up.  It takes about 3 gallons to spray 250 BF  :)
« Reply #8 on: August 06, 2014, 10:15:27 PM »
thanks for the correction. I would have thought I was putting in on too thick when it took me 3 times more for me than you.
Offline sawwood
« Reply #9 on: August 10, 2014, 09:36:09 AM »
We have had ants in our air dry lumber and want to use the Timbor on the lumber.
from what I read it leaves a white power on the wood, can this be brushed off when
we put it in the solar kiln ?
 Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Offline GeneWengert-WoodDoc
« Reply #10 on: August 10, 2014, 03:30:55 PM »
When declaring a chemical to be safe, it is best to refer to the MSDS sheet for that chemical.  Indeed, Timbor is fairly safe, with a few concerns regarding inhalation nd eye contact.
See
www.biconet.com/crawlers/infosheets/TimborMSDS.pdf
Offline WDH
« Reply #11 on: August 12, 2014, 07:17:50 AM »
The solution that I use does not leave a white powder on the lumber.
Offline sawwood
« Reply #12 on: August 12, 2014, 02:51:49 PM »
Found a store that sells Timbor and picked up a 1.5 pound bag. It was $10.50
and that was with tax. Now I need a sprayer to spray my stack as I build it. Thanks
WDH for the info.
Sawwood
18" planer/molder
« Reply #13 on: August 15, 2014, 12:21:31 AM »
See
thanks for adding that. I appreciate all the effort you guys put in to helping me out!
Powder or spray treatment?
Started by TimJr on Sawmills and Milling
Last post August 27, 2009, 10:04:15 AM
by backwoods sawyer
Question on spray bottle.
Started by gspren on Bluecreeper
Last post February 16, 2016, 09:31:32 AM
by Tam-i-am
Basal area spray question
Started by curdog on Ask The Forester
Last post May 16, 2014, 07:10:14 AM
by WDH
Introduction and treatment question
Started by Osric on Drying and Processing
Last post April 16, 2007, 09:35:03 AM
by thecfarm
