Dynamic Green Products Inc.
Author Topic: Pics of DIY mill after upgrades  (Read 2550 times)
Offline BCsaw
  • Love to build, fabricate and make saw dust!
« on: August 09, 2014, 01:56:32 PM »
I finally got around to putting some pics of the mill up. I upgraded the saw head "slides" to rollers. It is much easier to move up and down with less issues. My mill sat for a while and the slides started to seize up. Hence the change. It received a new paint job while I was at it.
I am currently using an offshore 13hp to run the mill. I have a 14hp Kubota to retrofit onto the mill this winter. I could have done that now, but I have some lumber to get sawn before the snow flies!
The aluminum tank up top is the lube tank. I built it with a handle so I can remove it easily and carry it, especially in winter. I used a porta power as my hydraulic pump for my band tension system. There is a small single acting ram to provide the force. A hydraulic gauge lets me know what is being applied and I use an isolation valve to keep pressure on the ram while sawing and relax the pressure from the pump.
Inspiration is the ability to "feel" what thousands of others can't!
Homebuilt Band Sawmill, Kioti 2510 Loader Backhoe
Offline yukon cornelius
Re: Pics of DIY mill after upgrades
« Reply #1 on: August 09, 2014, 02:14:28 PM »
very nice! you will be making dust soon!
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Offline biggkidd
« Reply #2 on: August 09, 2014, 02:17:58 PM »
Wow great job! I am in the process of building a mill myself. So the more pics the better. Thanks for taking time and posting what you've done.
  Larry
Echo 330 T, Echo 510, Dolmar 7900, Jinma 354 W/ FEL, & TPH Backhoe
 Building a Band Mill  :)
Offline BigJim2185
« Reply #3 on: August 09, 2014, 02:47:21 PM »
Great work.  Thanks for posting the pics.
-Thomas 8020 w/10' extension
-New Holland TC45D w/ fel and farmi jl501
Offline leroy in kansas
  • Don't squat with your spurs on.
« Reply #4 on: August 09, 2014, 03:05:58 PM »
That's looking really good. Looks like the roller setup should do the trick.  Did it shorten your travel ?
Offline BCsaw
« Reply #5 on: August 09, 2014, 03:48:24 PM »
Thanks for the comments everybody.
I will post more pics soon. I still have to paint the track. It is still in primer.
Leroy, I did lose some travel, but it can still cut a 36" log......so I think I am good! :D
Biggkid, let me know exactly what you are interested in and I will be sure to get pictures.
Offline mad murdock
« Reply #6 on: August 09, 2014, 09:31:13 PM »
That is a VERY NICE DIY mill there!!
Offline 21incher
« Reply #7 on: August 09, 2014, 09:45:18 PM »
Great looking build. Are you just using a single roller for the blade guides?
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Offline biggkidd
« Reply #8 on: August 09, 2014, 09:50:32 PM »
  I'm interested in everything not just for myself but for all the DIYers out there. Your build looks to be one of the better DIY builds I've seen. Mine isn't going to be nearly as fancy but hopefully functional.
  Thanks for sharing.
 Larry
Offline BCsaw
« Reply #9 on: August 10, 2014, 12:18:40 AM »
21 incher, the band guides are a Linn Lumber Mills product. Simple with easy to find bearings should the need arise. I used their brass nuts/blocks for the acme threaded rod on the raise lower as well. I did not buy their whole raise/lower package, just the brass nuts. I had the acme rod turned on the ends down to 3/4" at a local machine shop. Getting stuff shipped across the border is murder with the duty taxes added.
Offline drobertson
« Reply #10 on: August 10, 2014, 08:24:51 AM »
Nice build!  very neat and tidy, I like your choice of color too, very attractive,
Offline WmFritz
« Reply #11 on: August 10, 2014, 04:37:59 PM »
Very nice upgrades BC.
I need to do a bunch to mine, too. My problem is when I got it built to the point I could saw, all my other planned features are still sitting on the shelf.  ;D
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
Offline MSSawmill
« Reply #12 on: August 11, 2014, 10:25:25 AM »
Great looking mill!
Home-built bandsaw mill
2004 Kubota M110 with LA1301 loader
Offline BCsaw
« Reply #13 on: August 11, 2014, 06:51:35 PM »
Wm fritz, that is the trap! The guy sitting on your other shoulder should be saying, "No don't do it".
After I had mine welded up solid, I even contemplated not painting it just so I could get sawing lumber again. :D
Offline BCsaw
« Reply #14 on: August 11, 2014, 06:52:24 PM »
Offline WmFritz
« Reply #15 on: August 11, 2014, 07:48:03 PM »
I'm glad you took the time for the new paint. It looks good.
I have the same porta-power waiting to go on. I have a 1/2" drive ratchet with socket sitting on the mill for the tensioner.  :-\
~Bill
Offline BCsaw
« Reply #16 on: August 11, 2014, 08:47:38 PM »
Wmfritz, Did you find it difficult to find the sweet spot for the tension?
Offline WmFritz
« Reply #17 on: August 11, 2014, 09:22:53 PM »
Not at all. I have no gauge, so my tension is by feel on the wrench. I've had good luck with it sawing flat and have never broken a band, so that has a bit to do with my procrastinating on the hydraulic tensioner.
I really wanted one of those nice units from Linn Lumber when I was putting my components together for the build. I just couldn't pull the trigger on the $700.00 or so those things cost. Hence the cheapo porta-power and gauge I bought and still sits on the shelf.
Jeff had a few blade tension gauges at the Pig Roast for door prizes and would've liked to won one (Tom). I should buy one to make sure my tension is consistent, but as of yet, the only time I get a wavy cut is from me leaving a dull blade on too long.
~Bill
Offline BCsaw
« Reply #18 on: August 12, 2014, 01:34:57 AM »
Well that just goes to show you that lots of times there can be more than one way to accomplish things.
That is the whole reason we do this.......flat square boards/timbers.
If your set up can do that well who is to say different.
We all might have our preferences. I'm sure you could have 10 people look at my mill and come up with 10 different things they would have changed or done different.
 ;D ;D
Online thecfarm
« Reply #19 on: August 12, 2014, 05:29:15 AM »
I don't do alot of sawing. I just guess at my tension. I must be a good guesser too.  ;D I just push down on the blade with my thumb.
Sawmill Upgrades and Bigbutt WRC beams(pics)
Started by Percy on Sawmills and Milling
Last post April 23, 2019, 09:03:41 AM
by Percy
Mill revamp and upgrades
Started by Happycamper on Sawmills and Milling
Last post July 05, 2013, 10:40:40 AM
by PC-Urban-Sawyer
new to us power unit and mill upgrades
Started by Gearbox on Sawmills and Milling
Last post July 05, 2015, 09:10:52 PM
by Gearbox
Woodmizer manual mill upgrades
Started by jb616 on Sawmills and Milling
Last post August 10, 2018, 10:46:42 AM
by pineywoods
